有关AD7799的配置
已有 3261 次阅读2017-1-5 18:05
|个人分类:ICCAVR|系统分类:单片机
#include <iom64v.h>
#include <macros.h>
#include "delay.h"
//#include <stdint.h>
//#include <stdio.h>
//#include <string.h>
//#include "timeout.h"
//#include "avr_compat.h"
#include "eeprom.h"
#define uchar unsigned char
#define uint unsigned int
//unsigned char SPDAT ;
//#define ADC_VREF_TYPE 0xC0
#define ADC_CSACTIVE PORTB &= ~(1<<PORTB0); /* CS=0 */
#define ADC_CSPASSIVE PORTB |= (1<<PORTB0); /* CS=1 */
#define VER_H 1
#define VER_L 1
unsigned char CONH=0x10; /*CONFIGURATION REGISTER[00,BO(1),U/B(1),0(0),G2(0),
G1(0),G0(0),0,0,REF_DET(0),BUF(1),0(0),CH2(0),CH1(0),CH0(0)]*/
unsigned char CONL=0x00; /* GAIN: 1x, AIN1 */
//SPCR SPI控制寄存器
//SPSR SPI状态寄存器
//SPDAT SPI数据寄存器
void SPImasterInit(void)
SPCR=0x5C;//SPI控制寄存器,中断禁止,SPI使能,高位在前,主机模式,时钟空闲时为高,后沿触发移位,时钟分频64
SPSR=0x00;//清中断标志位
/* Write byte 2 AD7799 */
void WriteByteToAd7799(unsigned char data)
ADC_CSACTIVE;
//DDRB|=(1<<PB1)|(1<<PB2); //设置SCK,MOSI为输出,其他为输入
//DDRB&=~(1<<PB3); //设置MISO为输入
//PORTB|=(1<<PB3); //设置输入上拉
//SPCR|=(1<<SPE)|(1<<MSTR)|(1<<SPR1)|(1<<SPR0);//使能SPI,主模式,Fck/128
//SPDAT= data;
SPDR = data;
//while(~SPSR&0x80); //等待数据发送完
//SPSR=0x00; //清中断标志位
while(!(SPSR & (1<<SPIF))); //等待数据发送完
ADC_CSPASSIVE;
/* Read byte from AD7799 */
unsigned char ReadByteFromAd7799(void)
unsigned char returnData;
ADC_CSACTIVE;
SPDR = 0x00;
while((SPSR & (1<<SPIF))==0);
returnData = SPDR;
ADC_CSPASSIVE;
return (returnData);
/* Reset AD7799 */
void AD7799_RESET(void){
WriteByteToAd7799(0xff);
/* Init AD7799 */
void AD7799_INIT(void)
WriteByteToAd7799(0x10); //b0001 0000
/* Writes to Communications Register Setting Next Operation
as Write to CONFIGURATION Register*/
WriteByteToAd7799(37); //B0011 0111
WriteByteToAd7799(30); //B0011 0000
/*CONFIGURATION REGISTER[00,BO(0),U/B(0),0(0),G2(1),G1
(1),G0(1),0,0,REF_DET(0),BUF(1),0(0),CH2(0),CH1(0),CH0(0)]*/
WriteByteToAd7799(0x08);
//b0000 1000
as Write to Mode Register*/
WriteByteToAd7799(0x90);
WriteByteToAd7799(0x0F);
/* Writes to Mode Register Initiating Internal Zero-Scale
Calibration*/
//WaiteRDY();
DelayMs(5);
/* Wait for RDY pin to go low to indicate end of
calibration cycle*/
WriteByteToAd7799(0xb0);
/* Writes to Mode Register Initiating Internal Full-Scale
Calibration*/
//WaiteRDY();
DelayMs(5);
calibration cycle*/
WriteByteToAd7799(0x08);//b0000 1000
WriteByteToAd7799(0x00); //00010000
WriteByteToAd7799(0x0F); //00001111 (16.7HZ65dB)
/* Mode Register[MD2(0),MD1(0),MD0(0),PSW(0),0(0),0(0),0
(0),0(0),(0),(0),0(0),0(0),FS3(1),FS2(0),FS1(1),FS0(0)]*/
/* Continuous-Conversion Mode. Fadc=16.7HZ;*/
/* Wait for READY from AD7799 */
void WaiteRDY(void)
unsigned int iint ;
iint=0 ;
//while(~AD7799_RDY)
//while(bit_is_set(PINB,PB3))
while((PINA&0x08)==0)
iint++;
if(iint>20000)
//reset ad7799
AD7799_RESET();
AD7799_INIT();
break;
/* Read 24-bit of data from AD7799 */
unsigned long ReadAd7799ConversionData(void)
unsigned long ConverData;
unsigned char ADSAT ;
unsigned char ErrNUM=0;
WaiteRDY();
WriteByteToAd7799(0x40); //写通信寄存器设置下一个操作为读状态STATUS寄存器
WriteByteToAd7799(0xff); //伪写通信寄存器,为读状态寄存器提供时钟
//ADSAT=SPDAT; //读取接收到的数据
ADSAT=SPDR;
while((ADSAT&0x40)||(!(ADSAT&0x08))) //出错或者读写异常
//reset ad7799
/*----------防止时序混乱,重新同步----------*/
AD7799_INIT();
WaiteRDY();
ADSAT=SPDR;
ErrNUM++;
if(ErrNUM>5)break;
WriteByteToAd7799(0x58); //写通信寄存器设置下一个操作为连续读数据寄存器
WaiteRDY();
/* Wait for RDY pin to go low to indicate end of calibration cycle*/
//if(!AD7799_RDY)
//if(bit_is_clear(PINB,PB3))
if((PINA&0x08)==0x80)
ConverData=0 ;
/*-----------------Read Conversion Result from AD7799's Data Register----------------*/
WriteByteToAd7799(0xff); //伪写通信寄存器,为读数据寄存器寄存器提供时钟
//ConverData=SPDAT;
ConverData=SPDR;
ConverData=ConverData<<8 ;
//ConverData=ConverData+SPDAT;
ConverData=ConverData+SPDR;
if(ErrNUM>5)return(0);
else return(ConverData);
