[STM32] Keil编译出现如下错误,网上找不到解决办法,请求大佬帮助
273|4
 楼主 | 2018-6-27 17:45 | 显示全部楼层 |阅读模式
*** Using Compiler 'V5.06 update 5 (build 528)', folder: 'H:\MDK5\ARM\ARMCC\Bin'
Build target '多彩流水灯'
assembling startup_stm32f429_439xx.s...
startup_stm32f429_439xx.s: Error: A9511E: Unable to determine the current toolkit. Check that ARM_TOOL_VARIANT is set correctly.
startup_stm32f429_439xx.s: Check that your license details are correct in the License Management dialog of MDK. Additional information is available at:
startup_stm32f429_439xx.s:  http://www.keil.com/support/man/docs/license/license_management.htm
startup_stm32f429_439xx.s:  If you need further help, provide this complete error report to your supplier or license.support@arm.com.
startup_stm32f429_439xx.s:  - ARMLMD_LICENSE_FILE: unset
startup_stm32f429_439xx.s:  - LM_LICENSE_FILE: unset
startup_stm32f429_439xx.s:  - ARM_TOOL_VARIANT: unset
startup_stm32f429_439xx.s:  - ARM_PRODUCT_PATH: unset
startup_stm32f429_439xx.s:  - Product location: product not found
startup_stm32f429_439xx.s:  - Toolchain location: H:\MDK5\ARM\ARMCC\Bin
startup_stm32f429_439xx.s:  - Selected tool variant: mdk_cm_pro
startup_stm32f429_439xx.s: Product: unknown
startup_stm32f429_439xx.s: Component: ARM Compiler 5.06 update 5 (build 528)
startup_stm32f429_439xx.s: Tool: ArmAsm [4d35e1]
compiling system_stm32f4xx.c...
Error: C9511E: Unable to determine the current toolkit. Check that ARM_TOOL_VARIANT is set correctly.
Product: unknown
Tool: ArmCC [4d3621]
compiling misc.c...
| 2018-6-27 19:53 | 显示全部楼层
你破解了吗?
| 2018-6-28 09:02 | 显示全部楼层
一看就是没有破解或没有破解成功
| 2018-7-5 12:01 | 显示全部楼层
楼上说的没错,软件环境没搞好
| 2018-7-6 09:22 | 显示全部楼层
找个 keil 注册机,给keil注册一下。或者打个path。
扫描二维码,随时随地手机跟帖
快速回复
您需要登录后才可以回帖
登录 | 注册
高级模式
我要创建版块 申请成为版主
论坛热帖
关闭
热门推荐上一条 /6 下一条
分享 快速回复 返回顶部 返回列表
