[技术求助] 到底是怎么设置参考电压
1154|83
 楼主 | 2018-7-9 18:48 | 显示全部楼层 ||阅读模式
对参考电压的选择有很多疑问,比如下面这个例子我在很多地方都看到过 void main(void)
        WDTCTL = WDTPW+WDTHOLD;
        ADC12CTL0 = ADC12ON+SHT0_8+MSC;
        ADC12CTL1 = SHP+CONSEQ_2;
        ADC12IE = 0x01;
        ADC12CTL0 |= ENC;
        ADC12CTL0 |= ADC12SC;
在上面的这段代码里,我不知道他到底是怎么设置参考电压的
| 2018-7-9 18:50 | 显示全部楼层
寄存器怎么说的
| 2018-7-9 18:53 | 显示全部楼层
在ADC12CTL0寄存器中, 有一个REF2_5V,和REFON,说是选择内部参考电压的就是2.5V和1.5V
但是在ADC2MCTLx寄存器中SREF 又有6中情况
 楼主 | 2018-7-9 18:55 | 显示全部楼层
应该是选择外部参考电压的
| 2018-7-9 18:57 | 显示全部楼层
如何知道VR+和VR-呢
 楼主 | 2018-7-9 19:00 | 显示全部楼层
怎么计算测量的电压
| 2018-7-9 19:02 | 显示全部楼层
内部参考电压呢
 楼主 | 2018-7-9 19:04 | 显示全部楼层
测量430内部的温度传感器的温度,一下的初始化设置对不对啊
ADC12CTL0=ADC12ON+SHT0_15+MSC+REF2_5V;
ADC12CTL1=SHP+CONSEQ_2;
ADC12MCTL0=INCH_10;
ADC12IE=0x01;
ADC12CTL0|=ENC;
ADC12CTL0|=ADC12SC;
| 2018-7-9 19:07 | 显示全部楼层
Setting REFON=1 enables the internal reference. When REF2_5V = 1, the internal reference is 2.5 V, the
reference is 1.5 V when REF2_5V = 0.
REFON=1时,如果REF2_5V=0,那么内部参考电压为1.5V,REF2_5V=1时内部参考电压为2.5V
选择外部参考电压通过SREFx,从datasheet里可以看到有很多种选择,Vref这种是内部参考电压,Veref这种是外部参考电压。
| 2018-7-9 19:10 | 显示全部楼层
下面是一个内部温度传感器的测量程序
//  MSP430G2x33/G2x53 Demo - ADC10, Sample A10 Temp and Convert to oC and oF
//  Description: A single sample is made on A10 with reference to internal
//  1.5V Vref. Software sets ADC10SC to start sample and conversion - ADC10SC
//  automatically cleared at EOC. ADC10 internal oscillator/4 times sample
//  (64x) and conversion. In Mainloop MSP430 waits in LPM0 to save power until
//  ADC10 conversion complete, ADC10_ISR will force exit from any LPMx in
//  Mainloop on reti. Temperaure in oC stored in IntDegC, oF in IntDegF.
//  Uncalibrated temperature measured from device to device will vary with
//  slope and offset - please see datasheet.
//  ACLK = n/a, MCLK = SMCLK = default DCO ~1.2MHz, ADC10CLK = ADC10OSC/4
//         /|\|              XIN|-
//          --|RST          XOUT|-
//            |A10              |
//  D. Dang
//  Texas Instruments Inc.
//  December 2010
//   Built with CCS Version 4.2.0 and IAR Embedded Workbench Version: 5.10
#include  "msp430g2553.h"
long temp;
long IntDegF;
long IntDegC;
void main(void)
  WDTCTL = WDTPW + WDTHOLD;                 // Stop WDT
  ADC10CTL1 = INCH_10 + ADC10DIV_3;         // Temp Sensor ADC10CLK/4
  ADC10CTL0 = SREF_1 + ADC10SHT_3 + REFON + ADC10ON + ADC10IE;
  __enable_interrupt();                     // Enable interrupts.
  TACCR0 = 30;                              // Delay to allow Ref to settle
  TACCTL0 |= CCIE;                          // Compare-mode interrupt.
  TACTL = TASSEL_2 | MC_1;                  // TACLK = SMCLK, Up mode.
  LPM0;                                     // Wait for delay.
  TACCTL0 &= ~CCIE;                         // Disable timer Interrupt
  __disable_interrupt();
  while(1)
    ADC10CTL0 |= ENC + ADC10SC;             // Sampling and conversion start
    __bis_SR_register(CPUOFF + GIE);        // LPM0 with interrupts enabled
    // oF = ((A10/1024)*1500mV)-923mV)*1/1.97mV = A10*761/1024 - 468
    temp = ADC10MEM;
    IntDegF = ((temp - 630) * 761) / 1024;
    // oC = ((A10/1024)*1500mV)-986mV)*1/3.55mV = A10*423/1024 - 278
    temp = ADC10MEM;
    IntDegC = ((temp - 673) * 423) / 1024;
    __no_operation();                       // SET BREAKPOINT HERE
// ADC10 interrupt service routine
#pragma vector=ADC10_VECTOR
__interrupt void ADC10_ISR (void)
  __bic_SR_register_on_exit(CPUOFF);        // Clear CPUOFF bit from 0(SR)
#pragma vector=TIMER0_A0_VECTOR
__interrupt void ta0_isr(void)
  TACTL = 0;
  LPM0_EXIT;                                // Exit LPM0 on return
| 2018-7-9 19:13 | 显示全部楼层
这个上边还没有看到参考电压的设置的
| 2018-7-9 19:16 | 显示全部楼层
不会写的话,就使用参考的程序就行的
| 2018-7-9 19:18 | 显示全部楼层
这一句倒是有参考电压的设置的。
| 2018-7-9 19:21 | 显示全部楼层
从datasheet里可以看到,Vref这是内部参考电压,Veref是外部参考电压
 楼主 | 2018-7-9 19:23 | 显示全部楼层
哦,懂了,结贴
| 2018-7-14 11:33 | 显示全部楼层
使用内部2.5V参考电压
| 2018-7-14 11:34 | 显示全部楼层
430AD可以外部提供参考电压
默认的参考电压为3.3V
默认的VREF为VCC
| 2018-7-14 11:35 | 显示全部楼层
ADC12CTL0|= REFON+REF2_5V;
扫描二维码,随时随地手机跟帖
快速回复
您需要登录后才可以回帖
登录 | 注册
高级模式
我要创建版块 申请成为版主
论坛热帖
快速回复 返回顶部 返回列表
