FPGA设计经典书籍-资料汇总下载
23084|246
 楼主 | 2013-1-29 12:51 | 显示全部楼层 |阅读模式
分享,创造美好世界!
您需要 登录 才可以下载或查看,没有帐号?注册 手机登录
x
评分
参与人数 10威望 +28 收起 理由
icekoor + 3 强大
Death格雷尔 + 1 很给力!
bitshiyan + 3 赞一个!
503454911 + 3 赞一个!
luyaker + 1 这么……么……多……多
查看全部评分
 楼主 | 2013-1-29 12:52 | 显示全部楼层
继续
x
 楼主 | 2013-1-29 12:53 | 显示全部楼层
继续
x
 楼主 | 2013-1-29 12:55 | 显示全部楼层
继续
| 2013-1-29 13:39 | 显示全部楼层
额,好多啊。。。有没有网盘或者打包的连接啊
 楼主 | 2013-1-29 14:09 | 显示全部楼层
刚刚上传的,抱歉没有用过网盘
| 2013-1-29 14:14 | 显示全部楼层
| 2013-1-29 14:23 | 显示全部楼层
 楼主 | 2013-1-29 14:30 | 显示全部楼层
x
 楼主 | 2013-1-29 14:33 | 显示全部楼层
x
| 2013-1-29 14:37 | 显示全部楼层
FPGA设计指南:器件、工具和流程.part1.rar少了。。。另外,感谢阿
 楼主 | 2013-1-29 14:43 | 显示全部楼层
arm7官方源码
ar
x
 楼主 | 2013-1-29 14:47 | 显示全部楼层
OR1200 开发相关资料
已经重新上传 谢谢
The OpenRISC 1200 is an implementation of OpenRISC 1000 processor family.
The OR1200 is a 32-bit scalar RISC with Harvard microarchitecture, 5 stage integer pipeline, virtual memory support (MMU) and basic DSP capabilities.
Default caches are 1-way direct-mapped 8KB data cache and 1-way direct-mapped 8KB instruction cache, each with 16-byte line size. Both caches are physically tagged. By default MMUs are implemented and they are constructed of 64-entry hash based 1-way direct-mapped data TLB and 64-entry hash based 1-way direct-mapped instruction TLB. Supplemental facilities include debug unit for real-time debugging, high resolution tick timer, programmable interrupt controller and power management support.
General Microarchitecture
  • Central CPU/DSP block
  • IEEE 754 compliant single precision FPU
  • Direct mapped data cache
  • Direct mapped instruction cache
  • Data MMU based on hash-based DTLB
  • Instruction MMU based on hash-based ITLB
  • Power management unit and power management interface
  • Tick timer
  • Debug unit and development interface
  • Interrupt controller and interrupt interface
  • Instruction and Data WISHBONE B3 compliant interfaces
[edit]Status
x
| 2013-1-29 14:54 | 显示全部楼层
看了楼主的图片也不敢不回贴啊
| 2013-1-29 14:57 | 显示全部楼层
。。。。。。。太分散了
| 2013-1-29 15:23 | 显示全部楼层
有打包就好了,这样下着太累了。。。
| 2013-1-29 15:34 | 显示全部楼层
谢谢分享,lz
| 2013-1-29 15:54 | 显示全部楼层
真多啊
| 2013-1-29 16:17 | 显示全部楼层
很强大
| 2013-1-29 16:32 | 显示全部楼层
这样的帖子真得顶
评分
参与人数 1威望 +1 收起 理由
菜鸟003 + 1 很给力!
扫描二维码,随时随地手机跟帖
您需要登录后才可以回帖 登录 | 注册 手机登录
快速回复
您需要登录后才可以回帖
登录 | 注册 手机登录
高级模式
论坛热帖
关闭
热门推荐上一条 /4 下一条
分享 快速回复 返回顶部 返回列表
