MLX90614红外测温问题
8816|39
lgq1542380129|  楼主 | 2015-8-12 15:50 | 显示全部楼层 |阅读模式
最近在调试MLX90614红外模块,写了一个测试程序,发现应答不成功(SDA一直为高),看了下时序没有看出啥问题(能力有限)。移植了官方程序,也是应答不成功。具体代码如下。没来得及注释。希望各路大神看看。
static void rx_mlx90614_start(void)
    MLX90614_SCKOUT_0;
    delay_ms(10);
    MLX90614_SCKOUT_1;
    MLX90614_SDA_OUT;
    MLX90614_SDA_OUT_1;
//   delay_ms(1);
    MLX90614_SCKOUT_1;
    delay_us(46);
    MLX90614_SDA_OUT_0;
    delay_ms(29);
static void rx_mlx90614_write_onebyte(uchar com)
    uchar i = 0;
    MLX90614_SDA_OUT;
    MLX90614_SCKOUT_0;
    delay_ms(29);
    for (i=0; i<8; i++)
        if ((com & 0x80) == 0x80)
          MLX90614_SDA_OUT_1;
        else
          MLX90614_SDA_OUT_0;
        MLX90614_SCKOUT_1;
        delay_us(46);
        MLX90614_SCKOUT_0;
        delay_ms(29);
        com <<= 1;
static void rx_mlx90614_write_ack(uchar ack_noack)
     MLX90614_SDA_OUT;
     MLX90614_SCKOUT_0;
  //   delay_ms(29);
     if (ack_noack == 0)
         MLX90614_SDA_OUT_0;
     else
         MLX90614_SDA_OUT_1;
   //  delay_ms(1);
     MLX90614_SCKOUT_1;
  //   delay_us(46);
     MLX90614_SCKOUT_0;
  //   delay_ms(29);
   //  MLX90614_SDA_OUT_1;
static ack_result rx_mlx90614_read_ack(void)
     uint i = 0;
     ack_result ack_temp = ACK_OK;
     MLX90614_SDA_IN;
     MLX90614_SCKOUT_1;
   //  delay_us(1);
     while ((MLX90614_SDA_READ == BIT1))
        i++;
        if (i == 100)
          break;
        printf("\r\n NO ACK !");
     MLX90614_SCKOUT_0;
  //   delay_ms(3);
     if (i == 100)
       return  ACK_FAILURE;
     return ack_temp;
static uchar rx_mlx90614_read_onebyte(void)
    uchar i = 0, data = 0;
    MLX90614_SDA_IN;
    MLX90614_SCKOUT_1;
    delay_us(46);
    for (i=0; i<8; i++)
        data <<= 1;
        data += (uchar)((MLX90614_SDA_READ == BIT1) ?  1 : 0);
        MLX90614_SCKOUT_0;
        delay_ms(29);
        MLX90614_SCKOUT_1;
        delay_us(46);
    return data;
static void rx_mlx90614_stop(void)
     MLX90614_SDA_OUT;
     MLX90614_SCKOUT_1;
    // delay_ms(30);
     MLX90614_SDA_OUT_0;
     delay_us(46);
     MLX90614_SDA_OUT_1;
     MLX90614_SCKOUT_0;
     delay_ms(29);
uint rx_mlx90614_eeprom_or_ram_read(uchar adr, uchar com)
     uchar data_high8_bit = 0, data_low8_bit = 0, data_pec = 0;
     rx_mlx90614_rst:
                     rx_mlx90614_start();
                     rx_mlx90614_write_onebyte((adr << 1) | MLX90614_W_BIT);
                     if (rx_mlx90614_read_ack() == ACK_FAILURE)
                       goto rx_mlx90614_rst;
                     rx_mlx90614_write_onebyte(MLX90614_RAM_COM(com));
                     rx_mlx90614_write_onebyte((adr << 1) | MLX90614_R_BIT);
     data_low8_bit = rx_mlx90614_read_onebyte();
     rx_mlx90614_write_ack(ACK);
     data_high8_bit = rx_mlx90614_read_onebyte();
     data_pec = rx_mlx90614_read_onebyte();
     rx_mlx90614_write_ack(NACK);
     rx_mlx90614_stop();
     return (uint)((data_high8_bit << 8) | data_low8_bit);
dirtwillfly| | 2015-8-12 21:10 | 显示全部楼层
时序问题建议用逻辑分析仪或者示波器来观察一下,然后和手册里的对比,才有可能找出问题
lgq1542380129|  楼主 | 2015-8-12 21:30 | 显示全部楼层
dirtwillfly 发表于 2015-8-12 21:10
时序问题建议用逻辑分析仪或者示波器来观察一下,然后和手册里的对比,才有可能找出问题 ...
手头没有逻辑分析仪。按照数据手册的时序写的,是SMBUS总线,原理跟IIC一样的
yuluabc| | 2015-8-20 10:00 | 显示全部楼层
调试成功了吗,用的单片机吗
lgq1542380129|  楼主 | 2015-8-20 15:01 | 显示全部楼层
yuluabc 发表于 2015-8-20 10:00
调试成功了吗,用的单片机吗
成功了。用的430
yuluabc| | 2015-8-20 17:03 | 显示全部楼层
我在用430F5系列调试,还没有成功,能发我你的成果吗,我参考一下,万分感谢。
lgq1542380129|  楼主 | 2015-8-20 19:18 | 显示全部楼层
yuluabc 发表于 2015-8-20 17:03
我在用430F5系列调试,还没有成功,能发我你的成果吗,我参考一下,万分感谢。 ...
您的邮箱是多少?
评分
参与人数 1威望 +2 收起 理由
yuluabc + 2 很给力!
yuluabc| | 2015-8-20 19:45 | 显示全部楼层
1152637976@qq.com,最好带个电路图哈,谢谢!
lgq1542380129|  楼主 | 2015-8-20 20:49 | 显示全部楼层
yuluabc 发表于 2015-8-20 19:45
,最好带个电路图哈,谢谢!
已发。
chen665666| | 2015-9-8 13:51 | 显示全部楼层
您好,,你现在还在计量读研究生吗?我看到您对;硬件非常熟悉,想有些问题请教下您。
lgq1542380129|  楼主 | 2015-9-8 14:36 | 显示全部楼层
chen665666 发表于 2015-9-8 13:51
您好,,你现在还在计量读研究生吗?我看到您对;硬件非常熟悉,想有些问题请教下您。 ...
我也是小菜鸟的。你可以发帖的。论坛里大牛很多的。
chen665666| | 2015-9-10 08:48 | 显示全部楼层
呵呵,太谦虚了哈,你做过那种红外寻迹的送餐机器人吗?用stm32控制,我对stm32太不熟悉了,,,
lgq1542380129|  楼主 | 2015-9-10 13:19 | 显示全部楼层
chen665666 发表于 2015-9-10 08:48
呵呵,太谦虚了哈,你做过那种红外寻迹的送餐机器人吗?用stm32控制,我对stm32太不熟悉了,,, ...
没有做过的,你参考下其他厂家同类的机器人看看。
chen665666| | 2015-9-11 08:53 | 显示全部楼层
一般都找不到其他厂家的资料,,你知道在哪里可以找到详细点的吗
复仇之矛| | 2016-1-15 09:45 | 显示全部楼层
您好,我现在也在做MLX90614的试验,总是没有数值显示,这个是我的QQ1138016726,能加一下么?咨询一下问题,谢谢
lgq1542380129|  楼主 | 2016-1-15 20:14 | 显示全部楼层
复仇之矛 发表于 2016-1-15 09:45
您好,我现在也在做MLX90614的试验,总是没有数值显示,这个是我的QQ1138016726,能加一下么?咨询一下问题 ...
你发我下邮箱,我把.c和.h文件发你吧。
复仇之矛| | 2016-1-19 11:02 | 显示全部楼层
QQ邮箱1138016726@qq.com
mdc9| | 2016-1-19 14:58 | 显示全部楼层
你好! 我现在正在做这个,总是不应答,地址都找不到,没反应。大神这是用什么做的呢?51么,能不能把电路图和程序发给我,425254810@qq.com,谢谢!!
lgq1542380129|  楼主 | 2016-1-19 17:15 | 显示全部楼层
mdc9 发表于 2016-1-19 14:58
你好! 我现在正在做这个,总是不应答,地址都找不到,没反应。大神这是用什么做的呢?51么,能不能把电路 ...
用的430,我当时主要是时间延时的问题,我发你下.c和.h吧,我没有注释,望见谅啊。
mdc9| | 2016-1-20 08:53 | 显示全部楼层
lgq1542380129 发表于 2016-1-19 17:15
用的430,我当时主要是时间延时的问题,我发你下.c和.h吧,我没有注释,望见谅啊。 ...
非常感谢谢!:handshake
