机械电子行业专用英语
5686|1
 楼主| liulg2153 发表于 2007-5-18 22:15 | 显示全部楼层 |阅读模式
axis&nbsp;轴<br />reserve&nbsp;保存<br />specification&nbsp;说明书<br />panel&nbsp;主板<br />workpiece&nbsp;工件<br />AUX=auxiliary&nbsp;辅助的<br />RDP=radar&nbsp;data&nbsp;processing&nbsp;雷达数据处理<br />power&nbsp;steering&nbsp;switch&nbsp;动力转向开关<br />line&nbsp;switch&nbsp;行程开关<br />compression&nbsp;ratio&nbsp;压缩比<br />monitor&nbsp;监视器<br />temperature&nbsp;温度<br />command&nbsp;控制&nbsp;指挥&nbsp;指令<br />reaction&nbsp;反应<br />sequence&nbsp;顺序<br />current&nbsp;电流<br />constant&nbsp;一致<br />alarm&nbsp;警报<br />no.=number&nbsp;数字<br />machining&nbsp;centers&nbsp;加工中心<br />lay&nbsp;out&nbsp;布置&nbsp;安排<br />incorrect&nbsp;operation&nbsp;误操作<br />danger&nbsp;危险<br />caution&nbsp;小心警告<br />enter&nbsp;进入<br />original&nbsp;value&nbsp;初始值<br />shock&nbsp;触电<br />cause&nbsp;引起&nbsp;原因<br />warm-up&nbsp;预热<br />sliding&nbsp;滑行<br />electric&nbsp;control&nbsp;cabinet&nbsp;电气柜<br />display&nbsp;显示<br />initialize&nbsp;初始化<br />periodically&nbsp;定期性的<br />flexible&nbsp;柔性的<br />arbor&nbsp;刀杆<br />emergency&nbsp;stop&nbsp;紧急停止<br />chamfer&nbsp;倒角<br />hone&nbsp;珩磨<br />seal&nbsp;密封<br />filter&nbsp;过滤<br />leak&nbsp;test&nbsp;试漏<br />operation&nbsp;工序<br />spring&nbsp;弹簧<br />valve&nbsp;seat&nbsp;气门坐圈<br />valve&nbsp;guide&nbsp;气门导杆<br />balance&nbsp;shaft&nbsp;平衡轴<br />robot&nbsp;机器人<br />function&nbsp;功能<br />battery&nbsp;电池<br />turn&nbsp;over&nbsp;翻转<br />locate&nbsp;定位<br />manual手动<br />automatic&nbsp;自动<br />flange&nbsp;法兰<br />controller&nbsp;控制器<br />select&nbsp;选择<br />PLC=programmable&nbsp;logic&nbsp;controller&nbsp;可编程逻辑控制器<br />fuel&nbsp;injector&nbsp;喷油器<br />fuel&nbsp;distributor&nbsp;燃油分配器<br />sensor&nbsp;传感器<br />ECU=electronic&nbsp;control&nbsp;unit&nbsp;电子控制模块<br />bus&nbsp;数据线<br />extension&nbsp;扩展<br />communication&nbsp;通讯<br />diagnosis&nbsp;诊断&nbsp;分析<br />accommodation&nbsp;兼容<br />transmission&nbsp;传递&nbsp;输送<br />isolation&nbsp;绝缘<br />fuel&nbsp;tank&nbsp;油箱<br />oil&nbsp;pressure&nbsp;indicator&nbsp;汽油压力表<br />oil&nbsp;supply&nbsp;机油供给<br />IV=intake&nbsp;valve&nbsp;进气门<br />EV=exhaust&nbsp;valve&nbsp;排气门<br />heat&nbsp;exchanger&nbsp;热交换器<br />oil&nbsp;passage&nbsp;油道<br />OHC=overhead&nbsp;camshaft&nbsp;顶置式凸轮轴<br />firing&nbsp;point&nbsp;着火点<br />combustion&nbsp;燃烧<br />crank&nbsp;radius&nbsp;曲柄半径<br />crank&nbsp;angle&nbsp;曲柄角<br />reduction&nbsp;gear&nbsp;set&nbsp;齿轮减速器<br />oil&nbsp;skimmer&nbsp;刮油器<br />chain&nbsp;链条<br />drain&nbsp;pit&nbsp;排水沟<br />nozzle&nbsp;喷油嘴&nbsp;<br />restriction&nbsp;节气阀<br />oil&nbsp;pan&nbsp;油底壳<br />oil&nbsp;seal&nbsp;油封<br />rocket&nbsp;cover&nbsp;缸盖护罩<br />intake&nbsp;进气口<br />outtake&nbsp;排气口<br />assembly&nbsp;line&nbsp;总装线<br />clamp&nbsp;夹紧<br />unclamp&nbsp;松开<br />coolant&nbsp;冷却<br />transfer&nbsp;传送<br />conveyor传送装置<br />cycle&nbsp;循环<br />servo&nbsp;&nbsp;伺服<br />transformmer&nbsp;变压器<br />inverter&nbsp;逆变器<br />rectifier&nbsp;整流器<br />alternator&nbsp;发电机<br />miller&nbsp;machine&nbsp;铣床<br />planer&nbsp;machine&nbsp;刨床<br />driller&nbsp;machine&nbsp;钻床<br />boring&nbsp;machine&nbsp;镗床<br />grinding&nbsp;machine&nbsp;磨床<br />lathe&nbsp;车床<br />reamer&nbsp;绞刀<br />chip&nbsp;碎屑<br />feedrate&nbsp;进给率<br />fixture&nbsp;夹具<br />counter&nbsp;计数器<br />override&nbsp;补偿<br />spindle&nbsp;主轴<br />balancing&nbsp;平衡<br />measure&nbsp;测量<br />contactor&nbsp;电流接触器<br />voltage&nbsp;电压<br />stocker&nbsp;储料器<br />shift&nbsp;转换<br />reset&nbsp;复位<br />intake&nbsp;stroke&nbsp;进气冲程<br />compressoin&nbsp;stroke&nbsp;压缩冲程<br />power&nbsp;stroke&nbsp;做功冲程<br />exhaust&nbsp;stroke&nbsp;排气冲程<br />chuck&nbsp;卡盘<br />turret&nbsp;转塔<br />buzzer倒角<br />lap&nbsp;抛光<br />station&nbsp;工位<br />hydraulic&nbsp;液压<br />pump&nbsp;泵<br />return&nbsp;返回<br />intensity&nbsp;强度<br />reference&nbsp;提供&nbsp;参考<br />encorder&nbsp;编码器<br />housing&nbsp;套壳<br />lead-screw&nbsp;丝杆<br />safety-device&nbsp;安全装置<br />specified&nbsp;特定的<br />state&nbsp;状态<br />MDI=manual&nbsp;data&nbsp;input&nbsp;手动数据输入<br />mode&nbsp;模式<br />DC=direct&nbsp;current&nbsp;直流<br />AC=alternate&nbsp;current&nbsp;交流<br />over&nbsp;ride&nbsp;补偿<br />component&nbsp;零件&nbsp;组件<br />abstacle&nbsp;障碍<br />oil&nbsp;mist&nbsp;油雾<br />diameter&nbsp;直径<br />maximum&nbsp;最大<br />horsepower&nbsp;马力<br />max&nbsp;HP=maximum&nbsp;horse&nbsp;power&nbsp;最大马力<br />grease&nbsp;油脂<br />vernier&nbsp;caliper&nbsp;游标卡尺<br />torque&nbsp;扭矩<br />rust&nbsp;铁锈<br />rust&nbsp;preventive&nbsp;oil&nbsp;除锈油<br />warranty&nbsp;保修期内<br />non&nbsp;warranty&nbsp;保修期外<br />installation&nbsp;安装&nbsp;调试<br />finished&nbsp;goods&nbsp;成品<br />hoist&nbsp;吊车<br />scraper&nbsp;刮板<br />malfuunction&nbsp;故障<br />power&nbsp;source&nbsp;功率<br />press&nbsp;压力<br />compressor&nbsp;压缩机<br />frequency&nbsp;频率<br />switch&nbsp;开关<br />button&nbsp;按钮<br />circuit&nbsp;电路<br />solenoid&nbsp;电磁阀<br />cylinder&nbsp;block&nbsp;缸体<br />cylinder&nbsp;head&nbsp;缸盖<br />connecting&nbsp;rod&nbsp;连杆<br />crank&nbsp;shaft&nbsp;凸轮轴<br />camshaft&nbsp;曲轴<br />flywheel&nbsp;飞轮<br />piston&nbsp;活塞<br />carburetor&nbsp;化油器<br />spark&nbsp;plug&nbsp;火花塞<br />valve&nbsp;气门<br />gasoline&nbsp;engine&nbsp;汽油机<br />diesel&nbsp;engine&nbsp;柴油机<br />accelerator&nbsp;油门<br />bearing轴承<br />bolt&nbsp;螺栓<br />nut&nbsp;螺母<br />inpulse&nbsp;脉冲<br />maintenance&nbsp;维修保养<br />volume&nbsp;容积<br />radiator&nbsp;散热器<br />system&nbsp;系统<br />rotation&nbsp;旋转<br />process&nbsp;处理过程<br />deburr&nbsp;倒角<br />pallet&nbsp;托盘<br />cancel&nbsp;取消<br />inclined&nbsp;engine&nbsp;斜置式发动机<br />inverted&nbsp;engine&nbsp;倒置式发动机<br />reciprocating&nbsp;engine&nbsp;反复式发动机<br />pulley&nbsp;带轮<br />tensioner&nbsp;张紧器<br />clutch&nbsp;离合器<br />pneumatic&nbsp;气动的<br />dimension&nbsp;尺寸<br />accuracy&nbsp;精密精确度<br />interface&nbsp;接口<br />digital&nbsp;数字化<br />terminal&nbsp;终端<br />input&nbsp;&nbsp;输入<br />output&nbsp;输出<br />lubrication&nbsp;润滑油<br />feedback&nbsp;mechanism&nbsp;反馈机构<br />facility&nbsp;management&nbsp;设备管理<br />master&nbsp;control&nbsp;主控<br />frequency&nbsp;modulation&nbsp;调频<br />field&nbsp;magnet&nbsp;磁极<br />power&nbsp;box&nbsp;电源箱<br />plug&nbsp;board&nbsp;插板<br />central&nbsp;transfer&nbsp;point&nbsp;中央转移点<br />per&nbsp;second&nbsp;&nbsp;每秒<br />calling&nbsp;rate&nbsp;呼叫率<br />advance&nbsp;高级的<br />press&nbsp;压力<br />capacitance-resistance&nbsp;阻容<br />coherent&nbsp;rotation&nbsp;相关转动<br />damage&nbsp;埙坏<br />parameter&nbsp;参数<br />piston&nbsp;travel&nbsp;活塞行程<br />oil&nbsp;filter&nbsp;机油滤清器<br />spark&nbsp;ignition&nbsp;engine&nbsp;点燃式发动机<br />timing&nbsp;belt&nbsp;正时齿带<br />NC=numerical&nbsp;control&nbsp;数控<br />position&nbsp;位置<br />horizontal&nbsp;水平的<br />vertical&nbsp;垂直的<br />ejector&nbsp;放出器&nbsp;排出器<br />6.13<br />acceleration&nbsp;加速度<br />parallel&nbsp;平行<br />alphabetical&nbsp;字母<br />branch&nbsp;分支<br />synchronization&nbsp;同步<br />subroutine&nbsp;子程序<br />incremental&nbsp;增加的<br />registration&nbsp;注册&nbsp;报到<br />scan&nbsp;扫描<br />velocity&nbsp;速率<br />commissioning&nbsp;试运转&nbsp;试车<br />terminate&nbsp;停止&nbsp;结束<br />execute&nbsp;执行&nbsp;实行<br />variables&nbsp;变量<br />conversion&nbsp;变换&nbsp;转化<br />expandable&nbsp;可扩展的&nbsp;<br />disrupt&nbsp;使分裂&nbsp;使中断<br />eliminate&nbsp;排除&nbsp;消除<br />tacho&nbsp;转速计&nbsp;转速器<br />ventilation&nbsp;通风<br />ambient&nbsp;周围的<br />6.21<br />behavior&nbsp;举止&nbsp;行为<br />fatal&nbsp;重大的&nbsp;致命的<br />processor&nbsp;处理器<br />persist&nbsp;**&nbsp;连续<br />attributes&nbsp;品质&nbsp;特征<br />watchdog&nbsp;看门狗<br />firmware&nbsp;固件&nbsp;软硬件结合体<br />remedy&nbsp;矫正&nbsp;修补<br />offset&nbsp;偏移量<br />stiffness&nbsp;坚硬&nbsp;硬度<br />blocking&nbsp;调度设计&nbsp;模块化<br />polarity&nbsp;极性<br />acquisition&nbsp;获得&nbsp;获得物<br />standstill&nbsp;停止&nbsp;&nbsp;停顿<br />shielding&nbsp;防护&nbsp;屏蔽的<br />hardware&nbsp;硬件&nbsp;部件<br />interlock&nbsp;互锁<br />quasi&nbsp;类似的<br />compatible&nbsp;谐调一致的&nbsp;&nbsp;兼容的<br />tolerance&nbsp;公差&nbsp;宽容&nbsp;容忍<br />abrasive&nbsp;研磨剂
oljp987 发表于 2007-6-24 10:11 | 显示全部楼层
Thank you.
