[VHDL] 小弟写的程序,求大神看一下
1160|0
 楼主| 2268380631 发表于 2015-8-25 17:13 | 显示全部楼层 |阅读模式
我要写一个64K的正弦信号和32K的基带信号。 用的EPM240
LIBRARY IEEE;
USE IEEE.STD_LOGIC_1164.ALL;
USE IEEE.STD_LOGIC_UNSIGNED.ALL;
ENTITY CH IS
        PORT(CLK,CLR:IN STD_LOGIC;
             D:OUT INTEGER RANGE 0 TO 255;
                 BSOUT: OUT STD_LOGIC);
END ENTITY CH;
ARCHITECTURE ART OF CH IS
        COMPONENT SIN IS
                        D:OUT INTEGER RANGE 0 TO 255);
        END COMPONENT SIN;
        COMPONENT FP IS
                PORT(CLK:IN STD_LOGIC;
                        CTRL1,CTRL2:OUT STD_LOGIC);
        END COMPONENT;
        COMPONENT BS IS
                         BSOUT:OUT STD_LOGIC);
        END COMPONENT;
SIGNAL S1:STD_LOGIC;
SIGNAL S2:STD_LOGIC;
BEGIN
U0: FP PORT MAP(CLK=>CLK,CTRL1=>S1,CTRL2=>S2);
U1: SIN PORT MAP(CLK=>S1,CLR=>CLR,D=>D);
U2: BS PORT MAP (CLK=>S2,CLR=>CLR,BSOUT=>BSOUT);
END ARCHITECTURE ART;
------------------------分频64k32k
LIBRARY IEEE;
USE IEEE.STD_LOGIC_ARITH.ALL;
ENTITY FP IS
END;
ARCHITECTURE ONE OF FP IS
SIGNAL CLK1:STD_LOGIC;
SIGNAL CLK2:STD_LOGIC;
BEGIN
PROCESS (CLK)
VARIABLE CNT:INTEGER RANGE 0 TO 388;  ----64K
BEGIN
        IF CLK'event and CLK='1' THEN
                IF CNT=388 THEN
                        CNT:=0;
                        CLK1<=NOT CLK1;
                ELSE
                        CNT:=CNT+1;
                END IF;
    END IF;
END PROCESS;
CTRL1<=CLK1;
PROCESS (CLK)
VARIABLE CNT:INTEGER RANGE 0 TO 776;   ------32K
BEGIN
                IF CNT=776 THEN
                        CNT:=0;
                        CLK2<=NOT CLK2;
                ELSE
                        CNT:=CNT+1;
                END IF;
    END IF;
END PROCESS;
CTRL2<=CLK2;
END;
------------------------------sin
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_unsigned.all;
use ieee.std_logic_arith.all;
entity sin is  port(clk,clr:in std_logic;
       d:out integer range 0 to 255);
end entity;
architecture behav of sin is
begin
process(clk,clr)
variable tmp:integer range 0 to 63;
begin
   if clr='0' then
      d<=0;
   elsif clk'event and clk='1' then
   if tmp=63 then
        tmp:=0;
   else
    tmp:=tmp+1;
    end if;
      case tmp is
        when 00=>d<=255; when 01=>d<=254; when 02=>d<=252;
        when 03=>d<=249; when 04=>d<=245; when 05=>d<=239;
        when 06=>d<=233; when 07=>d<=225; when 08=>d<=217;
        when 09=>d<=207; when 10=>d<=197; when 11=>d<=186;
        when 12=>d<=174; when 13=>d<=162; when 14=>d<=150;
        when 15=>d<=137; when 16=>d<=124; when 17=>d<=112;
        when 18=>d<=99;  when 19=>d<=87;  when 20=>d<=75;
        when 21=>d<=64;  when 22=>d<=53;  when 23=>d<=43;
        when 24=>d<=34;  when 25=>d<=26;  when 26=>d<=19;
        when 27=>d<=13;  when 28=>d<=8;   when 29=>d<=4;
        when 30=>d<=1;   when 31=>d<=0;   when 32=>d<=0;
        when 33=>d<=1;   when 34=>d<=4;   when 35=>d<=8;
        when 36=>d<=13;  when 37=>d<=19;  when 38=>d<=26;
        when 39=>d<=34;  when 40=>d<=43;  when 41=>d<=53;
        when 42=>d<=64;  when 43=>d<=75;  when 44=>d<=87;
        when 45=>d<=99;  when 46=>d<=112; when 47=>d<=124;
        when 48=>d<=137; when 49=>d<=150; when 50=>d<=162;
        when 51=>d<=174; when 52=>d<=186; when 53=>d<=197;
        when 54=>d<=207; when 55=>d<=217; when 56=>d<=225;
        when 57=>d<=233; when 58=>d<=239; when 59=>d<=245;
        when 60=>d<=249; when 61=>d<=252; when 62=>d<=252;
        when 63=>d<=255;
        when others=>null;
     end case;
  end if;
end process;
end behav;
------------------------------BS
library ieee;
entity BS is
        bsout:out std_logic);
end BS;
architecture bhv of BS is
signal ddout:std_logic_vector(3 downto 0);
begin
process(clk,clr)
begin
        if clr='0'  then
                ddout(3)<='1';
                ddout(2 downto 0)<="000";
    ddout(3)<=ddout(3)xor ddout(0);
        ddout(2)<=ddout(3);
        ddout(1)<=ddout(2);
        ddout(0)<=ddout(1);
    end if ;
  end process;
bsout<=ddout(0);
end bhv;
