[ARM7]
怎么就是读不出来啊??
1128|4
gmccamen|  楼主 | 2015-9-1 11:10 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
// lora.cpp : Defines the entry point for the console application.
#include <stdlib.h>
#include "stdafx.h"
#include <afx.h>
#include "lora.h"
#include "usbspi.h"
#include <string>
#include <string.h>
#include "usbio.h"
#include "SPI_RW.h"
#include "stdafx.h"
#include "lora.h"
#include "usbspi.h"
#ifdef _DEBUG
#define new DEBUG_NEW
#undef THIS_FILE
static char THIS_FILE[] = __FILE__;
#endif
// The one and only application object
CWinApp theApp;
using namespace std;
bool SPI_READ(LPVOID lpComBuffer,BYTE byComSize, LPVOID lpBuffer, WORD wBuffSize)
lpComBuffer,      //用来保存在读SPI数据之前要写入的命令
byComSize,         //要写入的命令长度,如果不需要写入,设为0
lpBuffer,         //写入数据缓存
wBuffSize            //请求写入数据长度
        return USBIO_SPIRead(0,lpComBuffer,byComSize,lpBuffer,wBuffSize);
bool SPI_WRITE(LPVOID lpComBuffer,BYTE byComSize,LPVOID lpBuffer,WORD wBuffSize)
//BYTE是自定义的类型
//WORD是微软SDK中的类型,WORD的意思为字,是2byte的无符号整数
//LPVOID是一个没有类型的指针,也就是说你可以将任意类型的指针赋值给LPVOID类型的变量
        return USBIO_SPIWrite(0,lpComBuffer,byComSize,lpBuffer,wBuffSize);
typedef unsigned char uint8_t;
void SX1276ReadBuffer( uint8_t addr, uint8_t *buffer, uint8_t size )
        LPVOID lpComBuffer = &addr;
        LPVOID lpBuffer = (LPVOID)buffer;
        SPI_READ(lpComBuffer,2 , lpBuffer, 16);
void SX1276WriteBuffer( uint8_t addr, uint8_t *buffer, uint8_t size )
        LPVOID lpBuffer = buffer;
        SPI_WRITE(lpComBuffer,1,lpBuffer,16);
int _tmain(int argc, TCHAR* argv[], TCHAR* envp[])
        USBSPI spi;
        spi.USBSPI_INIT();
        spi.USBSPI_OPEN();
        spi.USBSPI_SET();
        //写
        uint8_t addr = 0x82;
        uint8_t size = 1;
        uint8_t write_buffer = 0x1B;
        uint8_t *buffer = &write_buffer;
        SX1276WriteBuffer( addr, buffer, size );
        printf("写入的结果是:%02x\r\n", *buffer);
//读
        uint8_t addr1 = 0x02;
        uint8_t size1 = 1;
        uint8_t *buffer1 = new BYTE[16];
        printf("读之前的结果是:%02x\r\n", (*buffer1));
        SX1276ReadBuffer( addr1, buffer1, size1 );
        printf("读出的结果是:%02x\r\n", (*buffer1));
        delete []buffer1;
        char Temp[1] = {0x02};
        BYTE comLen = 1;
        DWORD dwReadLen = 16;
        BYTE* pTmpBuff = new BYTE[dwReadLen];
        SPI_READ(Temp,comLen,pTmpBuff,dwReadLen);
        printf("读出的结果是:%02x\r\n", (*pTmpBuff));
        delete []pTmpBuff;
        return 0;
gmccamen|  楼主 | 2015-9-1 11:11 | 只看该作者
下面那个读是可以的
上面那个读不对啊
gmccamen|  楼主 | 2015-9-1 11:30 | 只看该作者
哪位大侠帮帮我啊
mini1986| | 2015-9-2 08:47 | 只看该作者
没在win平台下搞过spi,只在linux下搞过,怀疑你同步的问题,你看看时序......
永洪| | 2015-9-2 23:25 | 只看该作者
学习中,同求
