紧急求助:SmartRF Studio不会用
2631|3
ATmega32L|  楼主 | 2008-6-5 16:56 | 只看该作者
生成的代码不对
[0X01]   =    0x0B,   // IOCFG1    GDO1 output pin configuration.
[0X02]   =    0x06,   // IOCFG0D   GDO0 output pin configuration. Refer to SmartRF?Studio User Manual for detailed pseudo register explanation.
生成的代码杂回事?
IOCFG1和IOCFG0明明是0x2e,怎么生成出来的代码变成0x0b和0X06??
const unsigned char  rfSettings[] = {
[0X0B]   =    0x00,   // FSCTRL1   Only for compatibility with CCxx00.
[0X0C]   =    0x00,   // FSCTRL0   Only for compatibility with CCxx00.
[0X0D]   =    0x21,   // FREQ2     Frequency control word, high byte.
[0X0E]   =    0x65,   // FREQ1     Frequency control word, middle byte.
[0X0F]   =    0x6A,   // FREQ0     Frequency control word, low byte.
[0X10]   =    0x8E,   // MDMCFG4   Modem configuration.
[0X11]   =    0x3B,   // MDMCFG3   Modem configuration.
[0X12]   =    0x73,   // MDMCFG2   Modem configuration.
[0X13]   =    0x42,   // MDMCFG1   Modem configuration.
[0X14]   =    0xF8,   // MDMCFG0   Modem configuration.
[0X0A]   =    0x00,   // CHANNR    Channel number.
[0X15]   =    0x00,   // DEVIATN   Modem deviation setting (when FSK modulation is enabled).
[0X21]   =    0x00,   // FREND1    Only for compatibility with CCxx00
[0X22]   =    0x10,   // FREND0    Front end RX configuration.
[0X18]   =    0x18,   // MCSM0     Main Radio Control State Machine configuration.
[0X19]   =    0x00,   // FOCCFG    Only for compatibility with CCxx00.
[0X1A]   =    0x00,   // BSCFG     Only for compatibility with CCxx00.
[0X1B]   =    0x00,   // AGCCTRL2  Only for compatibility with CCxx00.
[0X1C]   =    0x00,   // AGCCTRL1  Only for compatibility with CCxx00.
[0X1D]   =    0x00,   // AGCCTRL0  Only for compatibility with CCxx00.
[0X23]   =    0xEA,   // FSCAL3    Frequency synthesizer calibration.
[0X24]   =    0x2A,   // FSCAL2    Frequency synthesizer calibration.
[0X25]   =    0x00,   // FSCAL1    Frequency synthesizer calibration.
[0X26]   =    0x1F,   // FSCAL0    Frequency synthesizer calibration.
[0X29]   =    0x59,   // FSTEST    Frequency synthesizer calibration.
[0X2C]   =    0x88,   // TEST2     Various test settings.
[0X2D]   =    0x31,   // TEST1     Various test settings.
[0X2E]   =    0x09,   // TEST0     Various test settings.
[0X03]   =    0x07,   // FIFOTHR   RXFIFO and TXFIFO thresholds.
[0X07]   =    0x00,   // PKTCTRL1  Only for compatibility with CCxx00.
[0X08]   =    0x05,   // PKTCTRL0  Packet automation control.
[0X09]   =    0x00,   // ADDR      Only for compatibility with CCxx00.
[0X06]   =    0xFF    // PKTLEN    Packet length.
dengwolf| | 2008-6-26 20:44 | 只看该作者
这个东西我天天玩
CC1100,找高手讨论!
