[STM32F4]
【f446re开发板试用】+修改UART+flash模拟EEROM
2171|8
boming|  楼主 | 2015-10-26 07:47 | 显示全部楼层 |阅读模式
关闭发送中断,打开接收中断,待收到数据
HAL_StatusTypeDef HAL_UART_APP_INIT_Receive_IT(UART_HandleTypeDef *huart)
PLC_UART_RECEIVE_CNT=0;
    /* Enable the UART Parity Error Interrupt */
    __HAL_UART_ENABLE_IT(huart, UART_IT_PE);
    /* Enable the UART Error Interrupt: (Frame error, noise error, overrun error) */
    __HAL_UART_ENABLE_IT(huart, UART_IT_ERR);
    /* Enable the UART Data Register not empty Interrupt */
    __HAL_UART_ENABLE_IT(huart, UART_IT_RXNE);
    return HAL_OK;
中断函数
  * @brief  This function handles UART interrupt request.
  * @param  huart: pointer to a UART_HandleTypeDef structure that contains
  *                the configuration information for the specified UART module.
  * @retval None
void HAL_UART_APP_IRQHandler(UART_HandleTypeDef *huart)
  uint32_t tmp1 = 0, tmp2 = 0;
  tmp1 = __HAL_UART_GET_FLAG(huart, UART_FLAG_PE);
  tmp2 = __HAL_UART_GET_IT_SOURCE(huart, UART_IT_PE);
  /* UART parity error interrupt occurred ------------------------------------*/
  if((tmp1 != RESET) && (tmp2 != RESET))
    __HAL_UART_CLEAR_PEFLAG(huart);
    huart->ErrorCode |= HAL_UART_ERROR_PE;
  tmp1 = __HAL_UART_GET_FLAG(huart, UART_FLAG_FE);
  tmp2 = __HAL_UART_GET_IT_SOURCE(huart, UART_IT_ERR);
  /* UART frame error interrupt occurred -------------------------------------*/
    __HAL_UART_CLEAR_FEFLAG(huart);
    huart->ErrorCode |= HAL_UART_ERROR_FE;
  tmp1 = __HAL_UART_GET_FLAG(huart, UART_FLAG_NE);
  /* UART noise error interrupt occurred -------------------------------------*/
    __HAL_UART_CLEAR_NEFLAG(huart);
    huart->ErrorCode |= HAL_UART_ERROR_NE;
  tmp1 = __HAL_UART_GET_FLAG(huart, UART_FLAG_ORE);
  /* UART Over-Run interrupt occurred ----------------------------------------*/
    __HAL_UART_CLEAR_OREFLAG(huart);
    huart->ErrorCode |= HAL_UART_ERROR_ORE;
  /* UART in mode Receiver ---------------------------------------------------*/
  while((__HAL_UART_GET_FLAG(huart, UART_FLAG_RXNE) != RESET)&&(__HAL_UART_GET_IT_SOURCE(huart, UART_IT_RXNE)!=RESET))
    huart->ErrorCode = HAL_UART_ERROR_NONE;
    /* Check if a transmit process is ongoing or not */
    if(huart->State == HAL_UART_STATE_BUSY_TX)
      huart->State = HAL_UART_STATE_BUSY_TX_RX;
    else
      huart->State = HAL_UART_STATE_BUSY_RX;
    if(huart->Init.WordLength == UART_WORDLENGTH_9B)
      if(huart->Init.Parity == UART_PARITY_NONE)
         PLC_UART_BUFFER[PLC_UART_RECEIVE_CNT]=(uint8_t)(huart->Instance->DR & (uint8_t)0x00FF);
         PLC_UART_RECEIVE_CNT+=1;
      else
    else
      else
         PLC_UART_BUFFER[PLC_UART_RECEIVE_CNT]=(uint8_t)(huart->Instance->DR & (uint8_t)0x007F);
      if(huart->State == HAL_UART_STATE_BUSY_TX_RX)
        huart->State = HAL_UART_STATE_BUSY_TX;
      else
        huart->State = HAL_UART_STATE_READY;
  tmp1 = __HAL_UART_GET_FLAG(huart, UART_FLAG_TXE);
  tmp2 = __HAL_UART_GET_IT_SOURCE(huart, UART_IT_TXE);
  /* UART in mode Transmitter ------------------------------------------------*/
    UART_APP_Transmit_IT(huart);
  tmp1 = __HAL_UART_GET_FLAG(huart, UART_FLAG_TC);
  tmp2 = __HAL_UART_GET_IT_SOURCE(huart, UART_IT_TC);
  /* UART in mode Transmitter end --------------------------------------------*/
UART_APP_EndTransmit_IT(huart);
  if(huart->ErrorCode != HAL_UART_ERROR_NONE)
    /* Set the UART state ready to be able to start again the process */
    HAL_UART_ErrorCallback(huart);
主函数
/* USER CODE END 0 */
int main(void)
/* STM32F4xx HAL library initialization:
       - Configure the Flash prefetch, instruction and Data caches
       - Configure the Systick to generate an interrupt each 1 msec
       - Set NVIC Group Priority to 4
       - Global MSP (MCU Support Package) initialization
  HAL_Init();
  /* Configure the system clock to 180 MHz */
  SystemClock_Config();
  MX_GPIO_Init();//初始化PLC IO
  MX_USART1_UART_Init();//初始化串口9600 7 evee 1
MX_USART2_UART_Init();//初始化串口9600 7 evee 1
  /* Unlock the Flash to enable the flash control register access *************/
  HAL_FLASH_Unlock();
  /* Erase the user Flash area
    (area defined by FLASH_USER_START_ADDR and FLASH_USER_END_ADDR) ***********/
  /* Get the 1st sector to erase */
  FirstSector = GetSector(FLASH_USER_START_ADDR);
  /* Get the number of sector to erase from 1st sector*/
  NbOfSectors = GetSector(FLASH_USER_END_ADDR) - FirstSector + 1;
  /* Fill EraseInit structure*/
  EraseInitStruct.TypeErase = FLASH_TYPEERASE_SECTORS;
  EraseInitStruct.VoltageRange = FLASH_VOLTAGE_RANGE_3;
  EraseInitStruct.Sector = FirstSector;
  EraseInitStruct.NbSectors = NbOfSectors;
  if(HAL_FLASHEx_Erase(&EraseInitStruct, &SectorError) != HAL_OK)
      Error occurred while sector erase.
      User can add here some code to deal with this error.
      SectorError will contain the faulty sector and then to know the code error on this sector,
      user can call function 'HAL_FLASH_GetError()'
        FLASH_ErrorTypeDef errorcode = HAL_FLASH_GetError();
     while(1)
   HAL_GPIO_WritePin(GPIOA,GPIO_PIN_5, GPIO_PIN_SET);
  /* Note: If an erase operation in Flash memory also concerns data in the data or instruction cache,
     you have to make sure that these data are rewritten before they are accessed during code
     execution. If this cannot be done safely, it is recommended to flush the caches by setting the
     DCRST and ICRST bits in the FLASH_CR register. */
  __HAL_FLASH_DATA_CACHE_DISABLE();
  __HAL_FLASH_INSTRUCTION_CACHE_DISABLE();
  __HAL_FLASH_DATA_CACHE_RESET();
  __HAL_FLASH_INSTRUCTION_CACHE_RESET();
  __HAL_FLASH_INSTRUCTION_CACHE_ENABLE();
  __HAL_FLASH_DATA_CACHE_ENABLE();
  /* Program the user Flash area word by word
  Address = FLASH_USER_START_ADDR;
  while (Address < FLASH_USER_END_ADDR)
    if (HAL_FLASH_Program(FLASH_TYPEPROGRAM_WORD, Address, DATA_32) == HAL_OK)
      Address = Address + 4;
    else
      /* Error occurred while writing data in Flash memory.
         User can add here some code to deal with this error */
    while(1)
  /* Lock the Flash to disable the flash control register access (recommended
     to protect the FLASH memory against possible unwanted operation) *********/
  HAL_FLASH_Lock();
  /* Check if the programmed data is OK
      MemoryProgramStatus = 0: data programmed correctly
      MemoryProgramStatus != 0: number of words not programmed correctly ******/
  MemoryProgramStatus = 0x0;
    data32 = *(__IO uint32_t*)Address;
    if (data32 != DATA_32)
      MemoryProgramStatus++;
HAL_UART_APP_INIT_Receive_IT(&huart1);
  /* Check if there is an issue to program data */
  if (MemoryProgramStatus == 0)
  {while(1)
for(tem1=0;PLC_UART_RECEIVE_CNT>tem1;tem1++)
        PLC_UART_RECEIVE_CNT=0; HAL_Delay(tem);
HAL_UART_Transmit_IT(&huart1,(uint8_t*)PLC_UART_BUFFER, tem1);
//HAL_UART_Transmit_IT(&huart2,(uint8_t*)aTxBuffer,  (sizeof(aTxBuffer) / sizeof(*(aTxBuffer)))-1);
    HAL_GPIO_TogglePin(GPIOA,GPIO_PIN_5);
  else
  {while(1)
    /* Error detected. Switch on LED4 */
PLC.tar (314 KB)
boming|  楼主 | 2015-10-26 07:48 | 显示全部楼层
UART功能是接收待机,定时用中断发送数据。
有哪位能讲解例程中的设备思想吗?????????????
谢谢
zhuotuzi| | 2015-10-26 15:37 | 显示全部楼层
全是代码,来点电路图,或者拓扑图好不好呢。
734774645| | 2015-10-26 16:11 | 显示全部楼层
获取标志,获取中断源?
wahahaheihei| | 2015-10-26 18:37 | 显示全部楼层
  HAL_FLASH_Lock();
好多人问,问什么写不进去,没看到这个闪存锁住了吗
boming|  楼主 | 2015-10-27 09:33 | 显示全部楼层
tmp2 = __HAL_UART_GET_IT_SOURCE(huart, UART_IT_PE); ...
boming|  楼主 | 2015-10-27 09:34 | 显示全部楼层
     to protect the FLAS ...
要解锁才能擦、写
Snow7| | 2015-10-28 22:05 | 显示全部楼层
HAL_FLASH_Lock(); 这个就是解锁函数吗
boming|  楼主 | 2015-10-29 07:21 | 显示全部楼层
这个是加锁。
