[技术问答]
请问:谁有M541和W5500的spi例程,谢谢!-
2320|11
caoqing|  楼主 | 2015-12-6 19:40 | 显示全部楼层 |阅读模式
一直没写成功
gejigeji521| | 2015-12-6 20:16 | 显示全部楼层
提出一种基于新唐ARM M0和W5500芯片的智能型数据网关的设计与实现。以ARM(M052)和W5500为硬件核心,以前后台系统和TCP/IP协议为软件核心设计用于多类型小数据传输的网关,实现对各类采集终端的数据无线传输、格式转化和上传服务器等功能。论述了网关的硬件设计、TCP/IP协议的裁剪与实现和软件设计,并用调试工具对硬件进行测试,符合与远程服务器通讯的协议要求。
gejigeji521| | 2015-12-6 20:17 | 显示全部楼层
我不上学了,没法帮你下载:http://www.cnki.com.cn/Article/CJFDTotal-SZZY201501003.htm
知网的东西,你可以找人帮你下载。不知道这些人是不是忽悠人的。。觉得你还是最好按照协议自己写比较好
仙女山| | 2015-12-6 20:47 | 显示全部楼层
时序不对吧,照着芯片资料里面的来
caoqing|  楼主 | 2015-12-7 09:42 | 显示全部楼层
顶一下
huangcunxiake| | 2015-12-7 20:28 | 显示全部楼层
* [url=home.php?mod=space&uid=288409]@file[/url]     main.c
* [url=home.php?mod=space&uid=895143]@version[/url]  V1.0
* $Revision: 7 $
* $Date: 15/09/02 10:04a $
* @brief
*           Configure SPI0 as Master mode and demonstrate how to communicate with an off-chip SPI Slave device.
*          Needs to work with SPI_SlaveMode sample code.
* @note
* Copyright (C) 2014~2015 Nuvoton Technology Corp. All rights reserved.
#include <stdio.h>
#include "M451Series.h"
#define TEST_COUNT 16
uint32_t g_au32SourceData[TEST_COUNT];
uint32_t g_au32DestinationData[TEST_COUNT];
volatile uint32_t g_u32TxDataCount;
volatile uint32_t g_u32RxDataCount;
/* Function prototype declaration */
void SYS_Init(void);
void SPI_Init(void);
/* Main function */
int main(void)
    uint32_t u32DataCount;
    /* Unlock protected registers */
    SYS_UnlockReg();
    /* Init System, IP clock and multi-function I/O. */
    SYS_Init();
    /* Lock protected registers */
    SYS_LockReg();
    /* Configure UART0: 115200, 8-bit word, no parity bit, 1 stop bit. */
    UART_Open(UART0, 115200);
    /* Init SPI */
    SPI_Init();
    printf("\n\n");
    printf("+--------------------------------------------------------+\n");
    printf("|             SPI Master Mode Sample Code                |\n");
    printf("\n");
    printf("Configure SPI0 as a master.\n");
    printf("Bit length of a transaction: 32\n");
    printf("The I/O connection for SPI0:\n");
    printf("    SPI0_SS (PB.4)\n    SPI0_CLK (PB.2)\n");
    printf("    SPI0_MISO0 (PB.3)\n    SPI0_MOSI0 (PB.5)\n\n");
    printf("SPI controller will transfer %d data to a off-chip slave device.\n", TEST_COUNT);
    printf("In the meanwhile the SPI controller will receive %d data from the off-chip slave device.\n", TEST_COUNT);
    printf("After the transfer is done, the %d received data will be printed out.\n", TEST_COUNT);
    printf("The SPI master configuration is ready.\n");
    for(u32DataCount = 0; u32DataCount < TEST_COUNT; u32DataCount++)
        /* Write the initial value to source buffer */
        g_au32SourceData[u32DataCount] = 0x00550000 + u32DataCount;
        /* Clear destination buffer */
        g_au32DestinationData[u32DataCount] = 0;
    printf("Before starting the data transfer, make sure the slave device is ready. Press any key to start the transfer.");
    getchar();
    printf("\n");
    /* Set TX FIFO threshold, enable TX FIFO threshold interrupt and RX FIFO time-out interrupt */
    SPI_SetFIFO(SPI0, 4, 4);
    SPI_EnableInt(SPI0, SPI_FIFO_TXTH_INT_MASK | SPI_FIFO_RXTO_INT_MASK);
    g_u32TxDataCount = 0;
    g_u32RxDataCount = 0;
    NVIC_EnableIRQ(SPI0_IRQn);
    /* Wait for transfer done */
    while(g_u32RxDataCount < TEST_COUNT);
    /* Print the received data */
    printf("Received data:\n");
        printf("%d:\t0x%X\n", u32DataCount, g_au32DestinationData[u32DataCount]);
    /* Disable TX FIFO threshold interrupt and RX FIFO time-out interrupt */
    SPI_DisableInt(SPI0, SPI_FIFO_TXTH_INT_MASK | SPI_FIFO_RXTO_INT_MASK);
    NVIC_DisableIRQ(SPI0_IRQn);
    printf("The data transfer was done.\n");
    printf("\n\nExit SPI driver sample code.\n");
    /* Reset SPI0 */
    SPI_Close(SPI0);
    while(1);
void SYS_Init(void)
    /* Init System Clock        */
    /* Enable external 12MHz XTAL */
    CLK_EnableXtalRC(CLK_PWRCTL_HXTEN_Msk);
    /* Waiting for clock ready */
    CLK_WaitClockReady(CLK_STATUS_HXTSTB_Msk);
    /* Switch HCLK clock source to HXT and HCLK source divide 1 */
    CLK_SetHCLK(CLK_CLKSEL0_HCLKSEL_HXT, CLK_CLKDIV0_HCLK(1));
    /* Select HXT as the clock source of UART0 */
    CLK_SetModuleClock(UART0_MODULE, CLK_CLKSEL1_UARTSEL_HXT, CLK_CLKDIV0_UART(1));
    /* Select PCLK0 as the clock source of SPI0 */
    CLK_SetModuleClock(SPI0_MODULE, CLK_CLKSEL2_SPI0SEL_PCLK0, MODULE_NoMsk);
    /* Enable UART peripheral clock */
    CLK_EnableModuleClock(UART0_MODULE);
    /* Enable SPI0 peripheral clock */
    CLK_EnableModuleClock(SPI0_MODULE);
    /* Update System Core Clock */
    /* User can use SystemCoreClockUpdate() to calculate PllClock, SystemCoreClock and CyclesPerUs automatically. */
    SystemCoreClockUpdate();
    /* Init I/O Multi-function        */
    /* Set PD multi-function pins for UART0 RXD and TXD */
    SYS->GPD_MFPL &= ~(SYS_GPD_MFPL_PD0MFP_Msk | SYS_GPD_MFPL_PD1MFP_Msk);
    SYS->GPD_MFPL |= (SYS_GPD_MFPL_PD0MFP_UART0_RXD | SYS_GPD_MFPL_PD1MFP_UART0_TXD);
    /* Set SPI0 multi-function pins */
    SYS->GPB_MFPL &= ~(SYS_GPB_MFPL_PB2MFP_Msk | SYS_GPB_MFPL_PB3MFP_Msk | SYS_GPB_MFPL_PB4MFP_Msk | SYS_GPB_MFPL_PB5MFP_Msk);
    SYS->GPB_MFPL |= (SYS_GPB_MFPL_PB2MFP_SPI0_CLK | SYS_GPB_MFPL_PB3MFP_SPI0_MISO0 | SYS_GPB_MFPL_PB4MFP_SPI0_SS | SYS_GPB_MFPL_PB5MFP_SPI0_MOSI0);
void SPI_Init(void)
    /* Init SPI        */
    /* Configure SPI0 as a master, SPI clock rate 2 MHz,
       clock idle low, 32-bit transaction, drive output on falling clock edge and latch input on rising edge. */
    SPI_Open(SPI0, SPI_MASTER, SPI_MODE_0, 32, 2000000);
    /* Enable the automatic hardware slave selection function. Select the SPI0_SS pin and configure as low-active. */
    SPI_EnableAutoSS(SPI0, SPI_SS, SPI_SS_ACTIVE_LOW);
void SPI0_IRQHandler(void)
    /* Check RX EMPTY flag */
    while(SPI_GET_RX_FIFO_EMPTY_FLAG(SPI0) == 0)
        /* Read RX FIFO */
        g_au32DestinationData[g_u32RxDataCount++] = SPI_READ_RX(SPI0);
    /* Check TX FULL flag and TX data count */
    while((SPI_GET_TX_FIFO_FULL_FLAG(SPI0) == 0) && (g_u32TxDataCount < TEST_COUNT))
        /* Write to TX FIFO */
        SPI_WRITE_TX(SPI0, g_au32SourceData[g_u32TxDataCount++]);
    if(g_u32TxDataCount >= TEST_COUNT)
        SPI_DisableInt(SPI0, SPI_FIFO_TXTH_INT_MASK); /* Disable TX FIFO threshold interrupt */
    /* Check the RX FIFO time-out interrupt flag */
    if(SPI_GetIntFlag(SPI0, SPI_FIFO_RXTO_INT_MASK))
        /* If RX FIFO is not empty, read RX FIFO. */
/*** (C) COPYRIGHT 2014~2015 Nuvoton Technology Corp. ***/
史迪威将军| | 2015-12-7 20:54 | 显示全部楼层
很大可能是由于时序不对造成的
IversonCar| | 2015-12-8 20:24 | 显示全部楼层
用示波器测试一下看看现在的时序是什么样的,和要求有啥区别
C洛达尔多| | 2015-12-9 20:31 | 显示全部楼层
我也是写iic没有成功,不知道哪里出了问题了
wanduzi| | 2017-8-26 19:43 | 显示全部楼层
成功了吗,分享一下啊。
wanduzi| | 2017-8-26 19:44 | 显示全部楼层
是M451吧?
mintspring| | 2017-9-17 09:39 | 显示全部楼层
官方提供了驱动,需要自己移植
