uclinux-2.6为什么能看到shell了还有问题!
3003|12
letter|  楼主 | 2007-2-1 19:56 | 显示全部楼层 |阅读模式
经过一段时间的煎熬,终于看到shell了,可是shell总是过几分钟输出:
init: /bin/sh respawning too fast
我看了启动信息,发现运行脚本rc时,/bin/expand命令出错:
Command: /bin/expand /etc/ramfs.img /dev/ram1
/bin/expand: Bad command or file name
认为shell出错和这个有关,望高指点,多谢。
以下是我的启动信息:
U-Boot 1.1.4 (Jan 22 2007 - 16:40:53)
U-Boot code: 0C700000 -> 0C719EF8  BSS: -> 0C71E99C
RAM Configuration:
Bank #0: 0c000000  8 MB
Flash:  2 MB
In:    serial
Out:   serial
Err:   serial
Hit any key to stop autoboot:  0
## Booting image at 00040000 ...
   Image Name:   Linux-2.6.9
   Created:      2007-01-26   2:50:16 UTC
   Image Type:   ARM Linux Kernel Image (uncompressed)
   Data Size:    659816 Bytes = 644.4 kB
   Load Address: 0c008000
   Entry Point:  0c008000
   Verifying Checksum ... OK
OK
Starting kernel ...
Uncompressing Linux................................................ done, bootin
g the kernel.
Linux version 2.6.9-hsc0 (root@localhost.localdomain) (gcc version 2.95.3 200103
15 (release)(ColdFire patches - 20010318 from http://fiddes.net/coldfire/)(uClin
ux XIP and shared lib patches from http://www.snapgear.com/)) #48 Fri Jan 26 10:
47:23 CST 2007
CPU: Samsung-S3C44B0x [44b07700] revision 0 (ARMv4T)
Machine: S3C44B0X Development Board
Built 1 zonelists
Kernel command line: root=/dev/ram0 initrd=0x0c13c53c,120k console=ttyS0,115200
PID hash table entries: 64 (order: 6, 1024 bytes)
Dentry cache hash table entries: 2048 (order: 1, 8192 bytes)
Inode-cache hash table entries: 1024 (order: 0, 4096 bytes)
Memory: 8MB = 8MB total
Memory: 6592KB available (1297K code, 132K data, 56K init)
Mount-cache hash table entries: 512 (order: 0, 4096 bytes)
checking if image is initramfs...it isn't (ungzip failed); looks like an initrd
Freeing initrd memory: 120K
NET: Registered protocol family 16
init_module
Samsung S3C44B0 Rtl8019as driver version 0.1 (2002-02-20) <hzh12@163.net>
init
eth0: 12:34:56:78:90:ab
get_stats
devfs: 2004-01-31 Richard Gooch (rgooch@atnf.csiro.au)
devfs: boot_options: 0x1
ttyS0 at I/O 0x1d00000 (irq = 3) is a Samsung S3C44B0 Internal UART
ttyS1 at I/O 0x1d04000 (irq = 2) is a Samsung S3C44B0 Internal UART
RAMDISK driver initialized: 16 RAM disks of 1024K size 1024 blocksize
loop: loaded (max 8 devices)
Using anticipatory io scheduler
nbd: registered device at major 43
NET: Registered protocol family 2
IP: routing cache hash table of 512 buckets, 4Kbytes
TCP: Hash tables configured (established 512 bind 512)
NET: Registered protocol family 17
RAMDISK: romfs filesystem found at block 0
RAMDISK: Loading 120KiB [1 disk] into ram disk... done.
VFS: Mounted root (romfs filesystem) readonly.
Mounted devfs on /dev
Freeing init memory: 56K
Shell invoked to run file: /etc/rc
Command: hostname Samsung
Command: mount -t proc proc /proc
Command: mount -t ext2 /dev/ram1 /var
mount failed: No such file or directory
Command: mkdir /var/config
/var/config: Read-only file system
Command: mkdir /var/tmp
/var/tmp: Read-only file system
Command: mkdir /var/log
/var/log: Read-only file system
Command: mkdir /var/run
/var/run: Read-only file system
Command: mkdir /var/lock
/var/lock: Read-only file system
Command: mkdir /var/empty
/var/empty: Read-only file system
Command: cat /etc/motd
Welcome to
          ____ _  _
         /  __| ||_|
    _   _| |  | | _ ____  _   _  _  _
   | | | | |  | || |  _ \| | | |\ \/ /
   | |_| | |__| || | | | | |_| |/    \
   |  ___\____|_||_|_| |_|\____|\_/\_/
   |_|
For further information check:
http://www.uclinux.org/
Command: ifconfig lo 127.0.0.1
ifconfig: Bad command or file name
Command: route add -net 127.0.0.0 netmask 255.255.255.0 lo
route: Bad command or file name
Command: dhcpcd &
dhcpcd: Bad command or file name
sh 10: Child 14 died
[14]
Execution Finished, Exiting
init: exec rc failed
init: /bin/firewall failed!init: exec rc failed
Sash command shell (version 1.1.1)
/>init: /bin/sh respawning too fast
wangkj| | 2007-2-1 20:28 | 显示全部楼层
文件系统的问题
letter|  楼主 | 2007-2-1 20:52 | 显示全部楼层
该如何解决?内核是2.6.9的。
wangkj| | 2007-2-1 21:10 | 显示全部楼层
换个文件系统,可能是inittab的问题或者init的问题
letter|  楼主 | 2007-2-1 21:44 | 显示全部楼层
我的inittab是空的。
inittab:
#inet:unknown:/bin/inetd
#boa:unknown:/bin/boa
wangkj| | 2007-2-2 08:32 | 显示全部楼层
我只是给你提示
问题还需要你自己解决,这是一个常见问题。
我是直接换的文件系统,没找具体原因。
letter|  楼主 | 2007-2-2 16:03 | 显示全部楼层
今天换了一个文件系统,还是expand有问题。
今天自己做了一ramdisk, Read-only file system问题没了,但是还是有二处问题。
第一处:
Can't open expanded file /dev/ram1
pid 11: failed 768
第二处:
都和ram1有关,我想ram1是不是有问题?
全部信息:
RAM Configuration:
Flash:  2 MB
In:    serial
Out:   serial
Err:   serial
=>  bootm 40000 140000
   Created:      2007-02-02  18:21:43 UTC
   Data Size:    605444 Bytes = 591.3 kB
OK
## Loading Ramdisk Image at 00140000 ...
   Image Name:   Ramdisk
   Created:      2007-02-02  19:02:09 UTC
   Image Type:   ARM Linux RAMDisk Image (gzip compressed)
   Data Size:    77798 Bytes = 76 kB
   Load Address: 0c600000
   Entry Point:  0c600000
Starting kernel ...
Uncompressing Linux............................................ done, booting the kernel.
Linux version 2.6.9-hsc0 (root@localhost.localdomain) (gcc version 2.95.3 20010315 (release)(ColdFire patches - 20010318 from http://fiddes.net/coldfire/)(uClinux XIP and shared lib patches from http://www.snapgear.com/)) #62 Fri Feb 2 13:08:52 EST 2007
Built 1 zonelists
Kernel command line: root=/dev/ram0 rw initrd=0x0c600000,800k console=ttyS0,115200
Memory: 5864KB available (1194K code, 164K data, 56K init)
checking if image is initramfs...it isn't (no cpio magic); looks like an initrd
Freeing initrd memory: 800K
init_module
init
get_stats
RAMDISK driver initialized: 16 RAM disks of 2048K size 1024 blocksize
RAMDISK: Compressed image found at block 0
VFS: Mounted root (ext2 filesystem).
pid 11: failed 768
Welcome to
          ____ _  _
         /  __| ||_|
   |_|
Command: ifconfig lo 192.168.1.8
Command: route add -net 192.168.1.1 netmask 255.255.255.0 lo
/> init: /bin/sh respawning too fast
wangkj| | 2007-2-2 16:33 | 显示全部楼层
4510-romfs.tgz
试试看吧。
qq
letter|  楼主 | 2007-2-2 22:03 | 显示全部楼层
好的。wangkj,非常感谢你。
wangkj| | 2007-2-3 09:15 | 显示全部楼层
如果运行几个命令后core dump不要奇怪
这个好像没也没完全作好,但也可能是内核的问题(这个和sst flash有关,可能)。
letter|  楼主 | 2007-2-7 16:04 | 显示全部楼层
原来是配置不对
原来是配置不对而以至文件系统有问题,具体问题我还不知道出在那里。我导入一个现成的内核配置文件就好了,可是shell不能输入任何字符,这又是什么原因?串口驱动(因为串口驱动是自己搞上去的)?
bootm 0x0c500000
## Booting image at 0c500000 ...
   Created:      2007-02-07  20:51:00 UTC
   Data Size:    1088276 Bytes =  1 MB
OK
Starting kernel ...
Uncompressing Linux......................................................................... done, booting the kernel.
Linux version 2.6.9-hsc0 (root@localhost.localdomain) (gcc version 2.95.3 20010315 (release)(ColdFire patches - 20010318 from http://fiddes.net/coldfire/)(uClinux XIP and shared lib patches from http://www.snapgear.com/)) #62 Wed Feb 7 15:43:21 EST 2007
Built 1 zonelists
Kernel command line: root=/dev/ram0 initrd=0x0c136600,969k console=ttyS0,115200
Memory: 5776KB available (2126K code, 122K data, 52K init)
Freeing initrd memory: 969K
init_module
init
get_stats
RAMDISK: Loading 969KiB [1 disk] into ram disk... done.
Freeing init memory: 52K
Command: hostname senglen
Welcome to
          ____ _  _
         /  __| ||_|
   |_|
/> (不能接受任何字符,怪)
letter|  楼主 | 2007-2-8 10:24 | 显示全部楼层
原来是串口驱动问题
现在问题解决了,是串口的中断的接收入口不对,改为正确的就好了。谢谢wangkj的帮助。
RAM Configuration:
Flash:  2 MB
In:    serial
Out:   serial
Err:   serial
   Created:      2007-02-08  14:54:44 UTC
   Data Size:    1086152 Bytes =  1 MB
OK
Starting kernel ...
Linux version 2.6.9-hsc0 (root@localhost.localdomain) (gcc version 2.95.3 20010315 (release)(ColdFire patches - 20010318 from http://fiddes.net/coldfire/)(uClinux XIP and shared lib patches from http://www.snapgear.com/)) #63 Thu Feb 8 09:36:06 EST 2007
Built 1 zonelists
Kernel command line: root=/dev/ram0 initrd=0x0c136600,968k console=ttyS0,115200
Memory: 5776KB available (2125K code, 123K data, 52K init)
Freeing initrd memory: 968K
init_module
init
get_stats
RAMDISK: Loading 968KiB [1 disk] into ram disk... done.
Command: hostname ucan
Welcome to
          ____ _  _
         /  __| ||_|
   |_|
route: netmask and route address conflict
pid 15: failed 256
init: Booting to single user mode
/> ls
bin
dev
etc
home
lib
mnt
proc
sbin
tmp
usr
var
