请教:STM32定时器中的预分频参数疑问
2573|1
新注册用户|  楼主 | 2009-9-30 09:42 | 显示全部楼层 |阅读模式
    TIM2 Configuration: Output Compare Timing Mode:
    TIM2CLK = 36 MHz, Prescaler = 4, TIM2 counter clock = 36/(1+4)=7.2 MHz
    CC1 update rate = TIM2 counter clock / CCR1_Val = 146.48 Hz
    CC2 update rate = TIM2 counter clock / CCR2_Val = 219.7 Hz
    CC3 update rate = TIM2 counter clock / CCR3_Val = 439.4 Hz
    CC4 update rate = TIM2 counter clock / CCR4_Val =  878.9 Hz
  /* Time base configuration */
  TIM_TimeBaseStructure.TIM_Period = 65535;
  TIM_TimeBaseStructure.TIM_Prescaler = 0;这里有一个预分频参数
  TIM_TimeBaseStructure.TIM_ClockDivision = 0;
  TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
  TIM_TimeBaseInit(TIM2, &TIM_TimeBaseStructure);
  /* Prescaler configuration */
  TIM_PrescalerConfig(TIM2, 4, TIM_PSCReloadMode_Immediate);这里也有一个预分频参数
请问两个预分频参数区别在哪里?
还有TIM_TimeBaseStructure.TIM_ClockDivision = 0;这个参数具体作用是什么?
新注册用户|  楼主 | 2009-10-9 17:52 | 显示全部楼层
顶一下
