[Atmel] SensorTape是一个封装在胶带上的传感器网络
1028|0
 楼主| ddllxxrr 发表于 2016-3-24 16:16 | 显示全部楼层 |阅读模式
SensorTape是一个封装在胶带上的传感器网络,由MIT媒体实验室的互动环境小组发明。该平台由互联且可编程的传感器节点组成,安装在灵活的电子基板上。基于模块化的特性,该平台能够实现连续传感器的快速原型设计和部署。
February 25th, 2016 by Atmel Team
Developed by students from MIT Media Lab’s Responsive Environments group, SensorTape is a sensor network in the form factor of masking tape. Inspired by the emergence of modular platforms throughout the Maker community, it consists of interconnected and programmable sensor nodes on a flexible electronics substrate. In other words, it’s pretty much a roll of circuits that can be cut, rejoined and affixed to various surfaces.
And what’s even cooler is that it’s a completely self-aware network, capable of feeling itself bend and twist. It can automatically determine the location of each of its nodes and the length of the tape, as it is cut and reattached.
As the neighboring nodes talk to one another, they can use their information to assemble an accurate, real-time 3D model of their assumed shape. Tapes with different sensors can also be connected for mixed functionality, while an intuitive graphical interface is employed for programming.
SensorTape’s architecture is made up of daisy-chained slave nodes and a master. The master is concerned with coordinating the communication and shuttling data to a computer, while each slave node features an ATmega328P, three on-board sensors (an ambient light sensor, an accelerometer, and a time-of-flight distance sensor), two voltage regulators and LEDs. The master contains the same AVR MCU, as well as serial-to-USB converter and a Bluetooth transceiver. The tape can be clipped to the master without soldering using a flexible circuit connector.
In terms of communication protocol, the team chose a combination of I²C and peer-to-peer serial. Whereas I²C supports most of the data transmissions from the master to slave, addresses are ‘assigned dynamically’ over peer-to-peer serial. This enables a fast transfer rate of 100 KHz via I²C with a protocol initialization sequence that accommodates chains of various lengths, up to 128 units long. (For testing, the MIT Media Lab crew developed a 2.3-meter prototype with 66 sensor nodes.)
Aside from its hardware, SensorTape has black lines that instruct where it’s okay to cut and break the circuits using a pair of scissors. As you can see in the image above, this can be either in a straight line or on a diagonal, which allows you to piece together the tape into 2D shapes just as you would when forming a picture frame.
Although still in its infancy, sample use cases of SensorTape include everything from posture-monitoring wearables to inventory tracking to home activity sensing. What’s more, the team has created an intuitive graphical interface for programming the futuristic tape, and it’s all Arduino-friendly so Makers will surely love getting their hands on it and letting their imaginations run wild. You read all about the project in the MIT group’s paper, as well as onFast Company.
个人签名:http://shop34182318.taobao.com/ http://shop562064536.taobao.com
2404
