不错的**-120楼有更新:双通道触摸感应芯片使用介绍
35844|131
Go_PSoC|  楼主 | 2009-11-16 12:19 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
准备用这个帖子不定期的帮大家发一些不错的文章,哪位大侠发现了好文章也可以在这里跟贴,这样可以保持不断更新,呵呵。
第一篇:Design Best Practices for Seamless 8-bit to 32-bit Transition - Article (8MCU升级至32MCU的最佳设计)
The age old embedded design question, do you use an 8-bit or 32-bit core in your new design.
If you ask your fellow engineers, you will probably find that their opinions are very polar.
Like it or not, 32-bit cores are here to stay.
So what does this mean?
It means that inevitably one day, no matter how hard you try not to, you will need to migrate from your loveable 8-bit core, to one of those new and complex 32-bit cores.
But does that migration have to be painful?
Not with the right tips and tricks.
huhuyadong| | 2009-11-16 19:09 | 只看该作者
为什么点击出来的是没有找到?
dewlife| | 2009-11-16 19:10 | 只看该作者
怎么都是英文啊!看起来有点吃力呀!
dewlife| | 2009-11-16 19:14 | 只看该作者
好像是介绍单片机的发展现状
agwtpcbox| | 2009-11-16 20:16 | 只看该作者
看不了
Go_PSoC|  楼主 | 2009-11-16 20:43 | 只看该作者
为什么点击出来的是没有找到?
huhuyadong 发表于 2009-11-16 19:09
直接另存为即可
Go_PSoC|  楼主 | 2009-11-16 20:44 | 只看该作者
为什么点击出来的是没有找到?
等中文得出来了再贴中文的,呵呵
god_like| | 2009-11-16 23:52 | 只看该作者
恩,我怎么打不开啊?限制教育网吗
love_life| | 2009-11-16 23:56 | 只看该作者
挺好,支持
Go_PSoC|  楼主 | 2009-11-17 10:57 | 只看该作者
恩,我怎么打不开啊?限制教育网吗
god_like 发表于 2009-11-16 23:52
我用附件方式上传应该没问题了吧,呵呵
abbr_b18cfd239c6f50e1c6b1388910c7b7e9.pdf
267.05 KB
Go_PSoC|  楼主 | 2009-11-17 11:12 | 只看该作者
第二篇:The Joy of Precision Analog: True System-on-Chip Performance(精密模拟的一件幸事:真正的片上系统性能)
As systems increase in complexity, engineers have a need to incorporate more components, both analog and digital, into a single device while maintaining the integrity of the design.
New mixed-signal microcontrollers are emerging which integrate more precision analog components than previous generations.
Utilizing these next generation mixed-signal microcontrollers allow for designs which reduce BOM costs, save board space, protect IP, and provide more flexibility for change throughout the design process.
Now mixed-signal microcontrollers have ADCs with a precision upwards of 20-bits, amplifiers with lower offset voltages, and 0.1% voltage references.
Precision Analog Integration - article.pdf
58.2 KB
suoma| | 2009-11-17 14:30 | 只看该作者
关于PSOC的东西
楼主应该发帖的时候简要介绍一下发的内容吧?
kanke100| | 2009-11-17 16:32 | 只看该作者
广告贴
zhongce09| | 2009-11-17 16:38 | 只看该作者
汗,纯英文的,看来LZ英文水平不错哟!!顶哇!!
god_like| | 2009-11-18 10:47 | 只看该作者
谢谢楼主,LZ辛苦了
Go_PSoC|  楼主 | 2009-11-18 10:52 | 只看该作者
第三篇:触摸按键的电磁炉设计
http://article.**/CE/20090203022228.htm
1.引言
电容感应方式的触摸按键有很多优点,由于不需要机械结构,相比传统的机械按键和薄膜按键,触摸式按键有着不可比拟的优势,并由此带来了时尚美观的外观设计。目前已经广泛应用于各种消费类电子产品。越来越多的家电产品也开始采用触摸按键,电磁炉是其中一个典型的应用。
Cypress的触摸技术Capsense是基于PSoC产品上的一种应用。PSoC(可编程片上系统)包含有8位微处理器核和数字与模拟混合信号阵列的可编程片上系统。不仅具有MCU的可编程序能力,还包含了部分可编程逻辑运算功能,同时也提供了可编程模拟阵列,集三种可编程能力与一体。在大多数家电的触摸应用中,一般包括触摸感应处理和系统控制处理。PSoC可提供该类应用中所需要的资源,并简化了系统。
陈林1206| | 2009-11-18 11:09 | 只看该作者
尽量弄中文版的吧!谢谢
beny5566| | 2009-11-18 13:38 | 只看该作者
版主大大辛苦了,
多看英文的也很好,
学的更快
Go_PSoC|  楼主 | 2009-11-19 11:11 | 只看该作者
第四篇:CyFi 无线解决方案及其开发
http://www.eetchina.com/ART_8800560879_617687_TA_966a1442.HTM
本文主要阐述了Cypress公司新推出的2.4GHz低功耗无线解决方案的特点、体系结构、协议内容和开发过程,并简要介绍了Cypress提供的辅助工具以帮助用户快速开发。
hulan1985| | 2009-11-19 18:39 | 只看该作者
这是什么啊……
