430f149超声测距
1584|22
 楼主| 开始吧 发表于 2016-8-24 19:24 | 显示全部楼层 |阅读模式
以下是超声测距的程序,大神们能解释一下,其中测距部分的语句么?应该是这部分吧,求解释
//#pragma vector=PORT1_VECTOR
__interrupt void port1_int(void)
    if((P1IN&BIT5)==BIT5)
        TACTL|=MC_1+TACLR;
        P1IES|=BIT5;
    else
        TACTL&=~MC_3;
        P1IES&=~BIT5;
        distance=TAR*5/3;
        //P2OUT=TAR;
        P1IFG&=~BIT5;
#include "msp430f149.h"
#define uint unsigned int
#define uchar unsigned char
/**************宏定义***************/
#define DataDir     P2DIR
#define DataPort    P2OUT
#define Busy            0x80
#define CtrlDir     P6DIR
#define CLR_RS P6OUT&=~BIT3;        //RS = P6.3
#define SET_RS P6OUT|=BIT3;
#define CLR_RW P6OUT&=~BIT4;        //RW = P6.4
#define SET_RW P6OUT|=BIT4;
#define CLR_EN P6OUT&=~BIT5;        //EN = P6.5
#define SET_EN P6OUT|=BIT5;
//   Trig-->P1.0     Echo-->P1.1    下载时断开P1.1口,下载后在连接P1.1
void DispStr(unsigned char x,unsigned char y,unsigned char *ptr);
void DispNChar(unsigned char x,unsigned char y, unsigned char n,unsigned char *ptr);
void LocateXY(unsigned char x,unsigned char y);
void Disp1Char(unsigned char x,unsigned char y,unsigned char data);
void LcdReset(void);
void LcdWriteCommand(unsigned char cmd,unsigned char chk);
void LcdWriteData( unsigned char data );
void WaitForEnable(void);
void Delay5ms(void);
void timeinit();
void delay(uint y);
long static uint distance;
uchar table[]={"Distance:"};
void main()
   WDTCTL = WDTPW + WDTHOLD;
   P1DIR|=BIT4;
   P2DIR=0XFF;
   timeinit();
   LcdReset();
   P1IE=BIT5;
   P1IES&=~BIT5;  //上升沿触发
   DispNChar(0,0, 9,table);
   while(1)
      P1OUT|=BIT4;
      delay(1);
      P1OUT&=~BIT4;
     // delay(10);
      Disp1Char(2,1,(distance/100000)%10+0x30);
      Disp1Char(3,1,(distance/10000)%10+0x30);
      Disp1Char(4,1,(distance/1000)%10+0x30);
      Disp1Char(5,1,(distance/100)%10+0x30);
      Disp1Char(6,1,'.');
      Disp1Char(7,1,(distance/10)%10+0x30);
      Disp1Char(8,1,distance%10+0x30);
      Disp1Char(9,1,'c');
      Disp1Char(10,1,'m');
void timeinit()
    TACTL=TASSEL_2+ID_3+MC_1;   //ID_2表示八分频!  MC_1表示连续计数模式!
    BCSCTL2=0x88;               //选择SMCLK的信号源XT2CLK(8MHz)
    CCR0=65535;
    _EINT();                    //打开总中断!
        TACTL|=MC_1+TACLR;
        P1IES|=BIT5;
    else
        TACTL&=~MC_3;
        P1IES&=~BIT5;
        distance=TAR*5/3;
        //P2OUT=TAR;
        P1IFG&=~BIT5;
void delay(uint y)
     uint x;
     for(;y>0;y--)
       for(x=100;x>0;x--);   //用8MHz的总频率!!!
函数名称:DispStr
功    能:让液晶从某个位置起连续显示一个字符串
参    数:x--位置的列坐标
          y--位置的行坐标
          ptr--指向字符串存放位置的指针
void DispStr(uchar x,uchar y,uchar *ptr)
    uchar *temp;
    uchar i,n = 0;
    temp = ptr;
    while(*ptr++ != '\0')   n++;    //计算字符串有效字符的个数
    for (i=0;i<n;i++)
        Disp1Char(x++,y,temp[i]);
        if (x == 0x0f)
           x  = 0;
           y ^= 1;
函数名称:DispNchar
功    能:让液晶从某个位置起连续显示N个字符
参    数:x--位置的列坐标
          y--位置的行坐标
          n--字符个数
          ptr--指向字符存放位置的指针
返回值  :无
void DispNChar(uchar x,uchar y, uchar n,uchar *ptr)
    uchar i;
    for (i=0;i<n;i++)
        Disp1Char(x++,y,ptr[i]);
        if (x == 0x0f)
           x = 0;
           y ^= 1;
函数名称:LocateXY
功    能:向液晶输入显示字符位置的坐标信息
参    数:x--位置的列坐标
          y--位置的行坐标
返回值  :无
void LocateXY(uchar x,uchar y)
    uchar temp;
    temp = x&0x0f;
    y &= 0x01;
    if(y)   temp |= 0x40;  //如果在第2行
    temp |= 0x80;
    LcdWriteCommand(temp,1);
函数名称:Disp1Char
功    能:在某个位置显示一个字符
参    数:x--位置的列坐标
          y--位置的行坐标
          data--显示的字符数据
返回值  :无
void Disp1Char(uchar x,uchar y,uchar data)
    LocateXY( x, y );
    LcdWriteData( data );
函数名称:LcdReset
功    能:对1602液晶模块进行复位操作
参    数:无
返回值  :无5
void LcdReset(void)
    CtrlDir |= 0x38;                 //控制线端口设为输出状态
    DataDir  = 0xFF;                 //数据端口设为输出状态
    LcdWriteCommand(0x38, 0);            //规定的复位操作
    Delay5ms();
    Delay5ms();
    Delay5ms();
    LcdWriteCommand(0x38, 1);                 //显示模式设置
    LcdWriteCommand(0x08, 1);                 //显示关闭
    LcdWriteCommand(0x01, 1);                //显示清屏
    LcdWriteCommand(0x06, 1);                 //写字符时整体不移动
    LcdWriteCommand(0x0c, 1);                 //显示开,不开游标,不闪烁
函数名称:LcdWriteCommand
功    能:向液晶模块写入命令
参    数:cmd--命令,
          chk--是否判忙的标志,1:判忙,0:不判
void LcdWriteCommand(uchar cmd,uchar chk)
    if (chk) WaitForEnable();         // 检测忙信号?
    CLR_RS;
    CLR_RW;
    _NOP();
    DataPort = cmd;                  //将命令字写入数据端口
    _NOP();
    SET_EN;                         //产生使能脉冲信号
    _NOP();
    _NOP();
    CLR_EN;
函数名称:LcdWriteData
功    能:向液晶显示的当前地址写入显示数据
参    数:data--显示字符数据
void LcdWriteData( uchar data )
    WaitForEnable();        //等待液晶不忙
    SET_RS;
    CLR_RW;
    _NOP();
    DataPort = data;        //将显示数据写入数据端口
    _NOP();
    SET_EN;                 //产生使能脉冲信号
    _NOP();
    _NOP();
    CLR_EN;
函数名称:WaitForEnable
功    能:等待1602液晶完成内部操作
    P2DIR &= 0x00;             //将P4口切换为输入状态
    CLR_RS;
    SET_RW;
    _NOP();
    SET_EN;
    _NOP();
    _NOP();
    while((P2IN & Busy)!=0);  //检测忙标志
    CLR_EN;
    P2DIR |= 0xFF;           //将P4口切换为输出状态
函数名称:Delay5ms
功    能:延时约5ms
void Delay5ms(void)
    uint i=40000;
    while (i != 0)
        i--;
dirtwillfly 发表于 2016-8-24 20:19 | 显示全部楼层
汗,貌似不是官方的例程阿
 楼主| 开始吧 发表于 2016-8-24 21:39 | 显示全部楼层
汗,貌似不是官方的例程阿
超声测距也有官方例程么?
 楼主| 开始吧 发表于 2016-8-24 21:42 | 显示全部楼层
汗,貌似不是官方的例程阿
请问这几句什么意思?
TACTL&=~MC_3;
         P1IES&=~BIT5;
         distance=TAR*5/3;
TAR是时间么?原程序是f149的,但是我149的板子烧入不进程序。应该是没有驱动,,,所以想改用5529的
dirtwillfly 发表于 2016-8-24 21:49 | 显示全部楼层
TAR是定时器的计数器
迪卡 发表于 2016-8-25 10:15 | 显示全部楼层
超声波测距是算的声波发出到接收之间的时间间隔,乘以声速,在除以2
 楼主| 开始吧 发表于 2016-8-25 10:52 | 显示全部楼层
请问这个时间间隔怎么得到的
火山LF 发表于 2016-8-25 14:40 | 显示全部楼层
请问这几句什么意思?
TACTL&=~MC_3;
         P1IES&=~BIT5;
你得看芯片规格书,和datasheet去了解是什么寄存器实现什么功能,定时器那块不难,你看一下就造了,官网例程也有助于你理解
举个例子
我找的是我自己的MSP430FR5969的定时器那块(不过很多是通用的)
MC_3就是选择定时器模式的
Mode control. Setting MC = 00h when Timer_A is not in use conserves power.
00b = Stop mode: Timer is halted
01b = Up mode: Timer counts up to TAxCCR0
10b = Continuous mode: Timer counts up to 0FFFFh
11b = Up/down mode: Timer counts up to TAxCCR0 then down to 0000h
P1IES :Interrupt Edge Select Registers (PxIES)选择中断触发沿
PxIES PxIN PxIFG
0 → 1 0 Will be set
0 → 1 1 Unchanged
1 → 0 0 Unchanged
1 → 0 1 Will be set
所以,我个人建议,先看规格书和Datasheet,看不懂再来问人
学习是个过程,学习解决问题的能力和查找资料的能力
777  发表于 2016-8-25 17:22
666  发表于 2016-8-25 17:19
评分
参与人数 1威望 +10 收起 理由
dirtwillfly + 10 很给力!
查看全部评分
航天的鱼 发表于 2016-8-25 17:26 | 显示全部楼层
你得看芯片规格书,和datasheet去了解是什么寄存器实现什么功能,定时器那块不难,你看一下就造了,官网例 ...
请接收我的膝盖
火山LF 发表于 2016-8-25 17:26 | 显示全部楼层
你的膝盖太大了,收不下啊
航天的鱼 发表于 2016-8-25 17:31 | 显示全部楼层
你的膝盖太大了,收不下啊
妹纸太谦虚了
vivilzb1985 发表于 2016-8-25 22:40 | 显示全部楼层
超声波测距的关键是发出的信号跟返回的信号的处理的
拉克丝 发表于 2016-8-27 20:46 | 显示全部楼层
楼主是不知道什么时候发出的波,什么时候又接收到回波吧
 楼主| 开始吧 发表于 2016-9-2 17:36 | 显示全部楼层
嗯,中断部分没搞明白
 楼主| 开始吧 发表于 2016-9-2 17:37 | 显示全部楼层
嗯,中断部分没搞明白
kkzz 发表于 2016-9-2 22:39 | 显示全部楼层
这个最简单还是中断触发。
kkzz 发表于 2016-9-2 22:44 | 显示全部楼层
以前做过超声波,直接中断启动定时器,然后就读取下降沿。
Rangar 发表于 2016-9-10 21:09 | 显示全部楼层
149的板子烧入不进程序?怎么会这样
Soraka 发表于 2016-9-11 22:04 | 显示全部楼层
请问这个时间间隔怎么得到的
这就是超声波的发射和接收端得到的信号啊
cehuafan 发表于 2016-9-12 16:11 | 显示全部楼层
定时器采样吗?
