[点读笔/故事机应用]
单片机16led走马灯仿真及程序
1200|8
feiqi1|  楼主 | 2016-9-3 13:12 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
51单片机做的单片机16个led的走马灯仿真及源程序
源代码如下:#include <REG52.H>
unsigned char RunMode;
//**********************************System Fuction*************************************************
void Delay1ms(unsigned int count)
        unsigned int i,j;
        for(i=0;i<count;i++)
        for(j=0;j<120;j++);
unsigned char code LEDDisplayCode[] = { 0xC0,0xF9,0xA4,0xB0,0x99,0x92,0x82,0xF8,        //0~7
                                                          0x80,0x90,0x88,0x83,0xC6,0xA1,0x86,0x8E,0xFF};
void Display(unsigned char Value)
        P3 = LEDDisplayCode[Value];
void LEDFlash(unsigned char Count)
        unsigned char i;
        bit Flag;
        for(i = 0; i<Count;i++)
                Flag = !Flag;
                if(Flag)
                        Display(RunMode);
                else
                        Display(0x10);
                Delay1ms(100);
        Display(RunMode);
unsigned char GetKey(void)
        unsigned char KeyTemp,CheckValue,Key = 0x00;
        CheckValue = P2&0x32;
        if(CheckValue==0x32)
                return 0x00;
        Delay1ms(10);
        KeyTemp = P2&0x32;
        if(KeyTemp==CheckValue)
                return 0x00;
        if(!(CheckValue&0x02))
                Key|=0x01;
        if(!(CheckValue&0x10))
                Key|=0x02;
        if(!(CheckValue&0x20))
                Key|=0x04;
        return Key;
unsigned int TimerCount,SystemSpeed,SystemSpeedIndex;
void InitialTimer2(void)
        T2CON  = 0x00;                        //16 Bit Auto-Reload Mode
         TH2 = RCAP2H = 0xFC;          //重装值,初始值        TL2 = RCAP2L = 0x18;
        ET2=1;                                        //定时器 2 中断允许
        TR2 = 1;                                //定时器 2 启动
        EA=1;
unsigned int code SpeedCode[]={   1,   2,   3,   5,   8,  10,  14,  17,  20,  30,
                                                             40,  50,  60,  70,  80,  90, 100, 120, 140, 160,
        180, 200, 300, 400, 500, 600, 700, 800, 900,1000};//30
void SetSpeed(unsigned char Speed)
        SystemSpeed =SpeedCode[Speed];
void LEDShow(unsigned int LEDStatus)
        P1 = ~(LEDStatus&0x00FF);
        P0 = ~((LEDStatus>>8)&0x00FF);
void InitialCPU(void)
        RunMode = 0x00;
        TimerCount = 0;
        SystemSpeedIndex = 10;
        P1 = 0x00;
        P0 = 0x00;
        P2 = 0xFF;
        P3 = 0x00;
        Delay1ms(500);
        P1 = 0xFF;
        P0 = 0xFF;
        P2 = 0xFF;
        P3 = 0xFF;
        SetSpeed(SystemSpeedIndex);
        Display(RunMode);
//Mode 0
unsigned int LEDIndex = 0;
bit LEDDirection = 1,LEDFlag = 1;
void Mode_0(void)
        LEDShow(0x0001<<LEDIndex);
        LEDIndex = (LEDIndex+1)%16;
//Mode 1
void Mode_1(void)
        LEDShow(0x8000>>LEDIndex);
//Mode 2
void Mode_2(void)
        if(LEDDirection)
        else
        if(LEDIndex==15)
                LEDDirection = !LEDDirection;
//Mode 3
void Mode_3(void)
        if(LEDDirection)
                LEDShow(~(0x0001<<LEDIndex));
        else
                LEDShow(~(0x8000>>LEDIndex));
        if(LEDIndex==15)
//Mode 4
void Mode_4(void)
        if(LEDDirection)
                if(LEDFlag)
                        LEDShow(0xFFFE<<LEDIndex);
                   else
                        LEDShow(~(0x7FFF>>LEDIndex));
        else
                if(LEDFlag)
                        LEDShow(0x7FFF>>LEDIndex);
                else
                        LEDShow(~(0xFFFE<<LEDIndex));
        if(LEDIndex==15)
                if(LEDDirection)        LEDFlag = !LEDFlag;
//Mode 5
void Mode_5(void)
        if(LEDDirection)
                LEDShow(0x000F<<LEDIndex);
        else
                LEDShow(0xF000>>LEDIndex);
        if(LEDIndex==15)
//Mode 6
void Mode_6(void)
        if(LEDDirection)
                LEDShow(~(0x000F<<LEDIndex));
        else
                LEDShow(~(0xF000>>LEDIndex));
        if(LEDIndex==15)
//Mode 7
void Mode_7(void)
        if(LEDDirection)
                LEDShow(0x003F<<LEDIndex);
        else
                LEDShow(0xFC00>>LEDIndex);
        if(LEDIndex==9)
    LEDIndex = (LEDIndex+1)%10;
//Mode 8
void Mode_8(void)
        LEDShow(++LEDIndex);
void TimerEventRun(void)
        if(RunMode==0x00)
                Mode_0();
        else if(RunMode ==0x01)
                Mode_1();
        else if(RunMode ==0x02)
                Mode_2();
        else if(RunMode ==0x03)
                Mode_3();
        else if(RunMode ==0x04)
                Mode_4();
        else if(RunMode ==0x05)
                Mode_5();
        else if(RunMode ==0x06)
                Mode_6();
        else if(RunMode ==0x07)
                Mode_7();
        else if(RunMode ==0x08)
                Mode_8();
void Timer2(void) interrupt 5 using 3
        TF2 = 0;         //中断标志清除( Timer2 必须软件清标志!)
        if(++TimerCount>=SystemSpeed)
                TimerCount = 0;
                TimerEventRun();
unsigned char MusicIndex = 0;
void KeyDispose(unsigned char Key)
        if(Key&0x01)
                LEDDirection = 1;
                LEDIndex = 0;
                LEDFlag = 1;
                RunMode = (RunMode+1)%9;
                Display(RunMode);
        if(Key&0x02)
                if(SystemSpeedIndex>0)
                        --SystemSpeedIndex;
                else
                        LEDFlash(6);
        if(Key&0x04)
                if(SystemSpeedIndex<28)
                        ++SystemSpeedIndex;
                else
                        LEDFlash(6);
main()
        unsigned char Key;
        InitialCPU();
        InitialTimer2();
        while(1)
                Key = GetKey();
                if(Key!=0x00)
                        KeyDispose(Key);
androidbus| | 2016-9-3 13:17 | 只看该作者
电路图设计的不错,代码也写的很不赞啊
litengg| | 2016-9-3 13:24 | 只看该作者
代码写的比较简单呢
qiangweii| | 2016-9-3 13:48 | 只看该作者
不错,记得上学的第一个实验就是这个了。。。
shashaa| | 2016-9-3 13:54 | 只看该作者
是个很不错的走马灯程序。。。。
feiqi1|  楼主 | 2016-9-3 14:21 | 只看该作者
androidbus 发表于 2016-9-3 13:17
电路图设计的不错,代码也写的很不赞啊
才接触单片机C语言不就而已。。。
feiqi1|  楼主 | 2016-9-3 14:22 | 只看该作者
litengg 发表于 2016-9-3 13:24
代码写的比较简单呢
主要设计 有加速 减速和计数功能。
shashaa 发表于 2016-9-3 13:54
是个很不错的走马灯程序。。。。
谢谢,我才开始呢,还得继续努力啊!!!
长的帅怪我落| | 2016-9-5 08:36 | 只看该作者
不错,有成为大牛的潜质、、、
