I.MX6Q调试TW2835
427|0
Xexerse|  楼主 | 2016-9-22 16:54 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
大家好:
      硬件环境:I.MX6Q ARM 9 +TW2835,接CSI0,CSI0_DAT12~CSI0_DAT19,用I2C配置寄存器。
      我根据手册上的推荐配置配置寄存器,但是HSYNC VSYNC和CSI0_DAT12~CSI0_DAT19的波形一直是高,时钟的27M波形是对的,调用应用采集视频就报错:
      ERROR: v4l2 capture: mxc_v4l_dqueue timeout enc_counter 0。
      请问一下,我现在这个现象是因为TW2835的寄存器配置有问题还是ARM这边IPU配置有问题?
目前IPU配置如下:
IPU_CONF =      0x00000101
IDMAC_CONF =    0x0000002F
IDMAC_CHA_EN1 =         0x00000001
IDMAC_CHA_EN2 =         0x00000000
IDMAC_CHA_PRI1 =        0x18800001
IDMAC_CHA_PRI2 =        0x00000000
IDMAC_BAND_EN1 =        0x00000000
IDMAC_BAND_EN2 =        0x00000000
IPU_CHA_DB_MODE_SEL0 =  0x00000001
IPU_CHA_DB_MODE_SEL1 =  0x00000000
IPU_CHA_TRB_MODE_SEL0 =         0x00000000
IPU_CHA_TRB_MODE_SEL1 =         0x00000000
DMFC_WR_CHAN =  0x00000090
DMFC_WR_CHAN_DEF =      0x202020F6
DMFC_DP_CHAN =  0x00009694
DMFC_DP_CHAN_DEF =      0x2020F6F6
DMFC_IC_CTRL =  0x00000002
IPU_FS_PROC_FLOW1 =     0x00000000
IPU_FS_PROC_FLOW2 =     0x00000000
IPU_FS_PROC_FLOW3 =     0x00000000
IPU_FS_DISP_FLOW1 =     0x00000000
IPU_VDIC_VDI_FSIZE =    0x00000000
IPU_VDIC_VDI_C =        0x00000000
IPU_IC_CONF =   0x00000000
