STM32的CRC校验是怎么回事,硬件校验码?
4372|16
Creas_Tall|  楼主 | 2016-11-13 21:24 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
MTCN2013| | 2016-11-15 20:31 | 只看该作者
CRC是软件校验吧。这个应该没有硬件校验。
huafei123| | 2016-11-18 14:40 | 只看该作者
我记得有个标准的CRC校验码的,加入运算就可以了。
叶覃| | 2016-11-18 14:45 | 只看该作者
STM32  CRC32校验很简单,只要调用库函数就可以
mdk55555| | 2016-11-19 19:45 | 只看该作者
给你个软件校验代码:
#include "crc8_16.h"
//CRC高位字节值表
const u8 auchCRCHi[] = {
0x00, 0xC1, 0x81, 0x40, 0x01, 0xC0, 0x80, 0x41, 0x01, 0xC0,
0x80, 0x41, 0x00, 0xC1, 0x81, 0x40, 0x01, 0xC0, 0x80, 0x41,
0x00, 0xC1, 0x81, 0x40, 0x00, 0xC1, 0x81, 0x40, 0x01, 0xC0,
0x80, 0x41, 0x01, 0xC0, 0x80, 0x41, 0x00, 0xC1, 0x81, 0x40,
0x00, 0xC1, 0x81, 0x40, 0x01, 0xC0, 0x80, 0x41, 0x00, 0xC1,
0x81, 0x40, 0x01, 0xC0, 0x80, 0x41, 0x01, 0xC0, 0x80, 0x41,
0x81, 0x40, 0x00, 0xC1, 0x81, 0x40, 0x01, 0xC0, 0x80, 0x41,
0x80, 0x41, 0x00, 0xC1, 0x81, 0x40, 0x00, 0xC1, 0x81, 0x40,
0x01, 0xC0, 0x80, 0x41, 0x01, 0xC0, 0x80, 0x41, 0x00, 0xC1,
0x81, 0x40, 0x01, 0xC0, 0x80, 0x41, 0x00, 0xC1, 0x81, 0x40,
0x01, 0xC0, 0x80, 0x41, 0x00, 0xC1, 0x81, 0x40, 0x01, 0xC0,
//CRC 低位字节值表
const u8 auchCRCLo[]={
0x00, 0xC0, 0xC1, 0x01, 0xC3, 0x03, 0x02, 0xC2, 0xC6, 0x06,
0x07, 0xC7, 0x05, 0xC5, 0xC4, 0x04, 0xCC, 0x0C, 0x0D, 0xCD,
0x0F, 0xCF, 0xCE, 0x0E, 0x0A, 0xCA, 0xCB, 0x0B, 0xC9, 0x09,
0x08, 0xC8, 0xD8, 0x18, 0x19, 0xD9, 0x1B, 0xDB, 0xDA, 0x1A,
0x1E, 0xDE, 0xDF, 0x1F, 0xDD, 0x1D, 0x1C, 0xDC, 0x14, 0xD4,
0xD5, 0x15, 0xD7, 0x17, 0x16, 0xD6, 0xD2, 0x12, 0x13, 0xD3,
0x11, 0xD1, 0xD0, 0x10, 0xF0, 0x30, 0x31, 0xF1, 0x33, 0xF3,
0xF2, 0x32, 0x36, 0xF6, 0xF7, 0x37, 0xF5, 0x35, 0x34, 0xF4,
0x3C, 0xFC, 0xFD, 0x3D, 0xFF, 0x3F, 0x3E, 0xFE, 0xFA, 0x3A,
0x3B, 0xFB, 0x39, 0xF9, 0xF8, 0x38, 0x28, 0xE8, 0xE9, 0x29,
0xEB, 0x2B, 0x2A, 0xEA, 0xEE, 0x2E, 0x2F, 0xEF, 0x2D, 0xED,
0xEC, 0x2C, 0xE4, 0x24, 0x25, 0xE5, 0x27, 0xE7, 0xE6, 0x26,
0x22, 0xE2, 0xE3, 0x23, 0xE1, 0x21, 0x20, 0xE0, 0xA0, 0x60,
0x61, 0xA1, 0x63, 0xA3, 0xA2, 0x62, 0x66, 0xA6, 0xA7, 0x67,
0xA5, 0x65, 0x64, 0xA4, 0x6C, 0xAC, 0xAD, 0x6D, 0xAF, 0x6F,
0x6E, 0xAE, 0xAA, 0x6A, 0x6B, 0xAB, 0x69, 0xA9, 0xA8, 0x68,
0x78, 0xB8, 0xB9, 0x79, 0xBB, 0x7B, 0x7A, 0xBA, 0xBE, 0x7E,
0x7F, 0xBF, 0x7D, 0xBD, 0xBC, 0x7C, 0xB4, 0x74, 0x75, 0xB5,
0x77, 0xB7, 0xB6, 0x76, 0x72, 0xB2, 0xB3, 0x73, 0xB1, 0x71,
0x70, 0xB0, 0x50, 0x90, 0x91, 0x51, 0x93, 0x53, 0x52, 0x92,
0x96, 0x56, 0x57, 0x97, 0x55, 0x95, 0x94, 0x54, 0x9C, 0x5C,
0x5D, 0x9D, 0x5F, 0x9F, 0x9E, 0x5E, 0x5A, 0x9A, 0x9B, 0x5B,
0x99, 0x59, 0x58, 0x98, 0x88, 0x48, 0x49, 0x89, 0x4B, 0x8B,
0x8A, 0x4A, 0x4E, 0x8E, 0x8F, 0x4F, 0x8D, 0x4D, 0x4C, 0x8C,
0x44, 0x84, 0x85, 0x45, 0x87, 0x47, 0x46, 0x86, 0x82, 0x42,
0x43, 0x83, 0x41, 0x81, 0x80, 0x40
//获得CRC16值
//puchMsg:要校验的数组
//usDataLen:数组长度
u16 Get_Crc16(u8 *puchMsg,u16 usDataLen)
u8 uchCRCHi=0xFF;     //高CRC 字节初始化
u8 uchCRCLo=0xFF;     //低CRC 字节初始化
u32 uIndex;     //CRC 循环中的索引
while(usDataLen--)     //传输消息缓冲区
uIndex=uchCRCHi^*puchMsg++; //计算CRC
uchCRCHi=uchCRCLo^auchCRCHi[uIndex];
uchCRCLo=auchCRCLo[uIndex];
return (uchCRCHi<<8|uchCRCLo);
//CRC8校验
//ptr:要校验的数组
//len:数组长度
//返回值:CRC8码
u8 Get_Crc8(u8 *ptr,u16 len)
u8 crc;
u8 i;
crc=0;
while(len--)
crc^=*ptr++;
for(i=0;i<8;i++)
if(crc&0x01)crc=(crc>>1)^0x8C;
else crc >>= 1;
return crc;
haokeer| | 2016-11-19 19:50 | 只看该作者
好像有自带的crc校验的,不过没有用过
xiaolong12| | 2016-11-19 22:59 | 只看该作者
stm32硬件算出来的CRC与标准的CRC不一样,我用的是标准CRC
hotpower| | 2016-11-20 06:08 | 只看该作者
http://www.21ic.com/tools/HotWC3_V1.22.html
rmbass| | 2016-11-20 20:50 | 只看该作者
STM32的CRC32是标准的,只是非标准的成了主流而已。
maninman1981| | 2016-11-20 21:00 | 只看该作者
CRC校验原理都一样,只是选的多项式不同,因此会有各种不同的多项式算法.选择的时候一定要注意对应的多项式是不是我们的多项式.
冰是睡着的冰| | 2016-11-22 10:56 | 只看该作者
使用自带的CRC模块应该速度快点,使用软件crc的话速度应该慢
yysforever| | 2016-11-22 11:01 | 只看该作者
主频高的话,这些都不是问题,就一个操作而已
Dennis-Zhou| | 2016-11-23 21:56 | 只看该作者
参考 MCD Application V3.5.0, CRC_Calculation CRC Calculation example:
\stm32f10x_stdperiph_lib\STM32F10x_StdPeriph_Lib_V3.5.0\Project\STM32F10x_StdPeriph_Examples\CRC\CRC_Calculation
这就是个CRC的例程
积少成多的,运算多了,速度不知不觉就下降了。
jouney316| | 2016-11-23 22:04 | 只看该作者
所有的STM32芯片都内置了一个硬件的CRC计算模块,可以很方便地应用到需要进行通信的程序中,这个CRC计算模块使用常见的、在以太网中使用的计算多项式:
  X32 + X26 + X23 + X22 + X16 + X12 + X11 + X10 +X8 + X7 + X5 + X4 + X2+ X +1
写成16进制就是:0x04C11DB7
l科科1987| | 2016-11-24 19:39 | 只看该作者
mdk55555 发表于 2016-11-19 19:45
给你个软件校验代码:
这些字节表是否可以任意修改呢?有什么规律在内呢
dongbaohui| | 2016-11-24 20:45 | 只看该作者
一样的,发送端改了,接收端也要改的。但最好不要修改。
