[工具下载]
CooCox CoIDE没有关门,又能访问了
3942|31
wahahaheihei|  楼主 | 2016-11-24 23:26 | 显示全部楼层 |阅读模式
wahahaheihei|  楼主 | 2016-11-24 23:27 | 显示全部楼层
CooCox CoIDE
http://www.coocox.org/download.php?downIndex=CoIDE&id=20CooCox CoSmart
http://www.coocox.org/download.php?downIndex=CoSmart&id=22
wahahaheihei|  楼主 | 2016-11-24 23:28 | 显示全部楼层
CoIDE is a free integrated development environment focusing on ARM Cortex-M0/M0+/M3/M4 based microcontrollers.It is a trimmed version of Eclipse + GCC (GCC-ARM-Embedded) tool chain dedicatedly for embedded development, allowing users experience both high efficiency and minimalism in an individual IDE. With a powerful code component sharing and collaborative cloud platform Git integrated, over 800 code components are within easy reach, allowing users to implement programs simply by stacking up building blocks.
wahahaheihei|  楼主 | 2016-11-24 23:29 | 显示全部楼层
CoSmart is a free graphical configuration tool for ARM Cortex-M peripherals. Though the user-friendly graphical configuration interface, users can configure the working mode of the peripherals, set the status of I/O pins, generate corresponding initialization code, and export CoIDE project.
wahahaheihei|  楼主 | 2016-11-24 23:30 | 显示全部楼层
CooCox CoFlash
CoFlash is an easy-to-use stand-alone online flash programmer for ARM Cortex-M microcontrollers. It has two kinds of user interface, graphical user interface and command line interface. It supports a number of mainstream debug adapters, such as CoLinkEx, J-Link, ST-Link, and FTDI-based debug adapters.
Read More
AKOO| | 2016-11-25 08:05 | 显示全部楼层
是的,昨天已經發現了。
剛剛用它見了M058的工程,貌似還行的樣子。
不過似乎他的BSP還是舊的,沒有更新,不知道有沒有Bug
lilei0902| | 2016-11-25 11:04 | 显示全部楼层
很好,我还以为关了,CoIDE很不错。
dongnanxibei| | 2016-11-27 16:36 | 显示全部楼层
前段刚看个贴说人家没钱关门了,这又有钱开张了?
heisexingqisi| | 2016-11-27 19:04 | 显示全部楼层
这个软件唯一不爽的地方就是版本号总是Beta
598330983| | 2016-11-27 23:27 | 显示全部楼层
这说明人家在努力做这个软件,我们要支持啊,多多使用
wahahaheihei|  楼主 | 2016-11-28 09:44 | 显示全部楼层
好多公司收到过收费开发软件的法律函件,大家用这个开源的吧,免费好用。
ofsummer| | 2016-11-28 20:42 | 显示全部楼层
这个也是用eclipse做的开发器吧
mintspring| | 2016-11-29 17:03 | 显示全部楼层
楼上说的对,现在好多这种免费的都是用eclipse做
wahahaheihei|  楼主 | 2016-11-30 10:51 | 显示全部楼层
如果不用免费的,以后你会少不了法律麻烦。
逍遥派掌门| | 2016-11-30 16:15 | 显示全部楼层
CooCox OS 很难下载了。
mintspring| | 2016-12-3 13:43 | 显示全部楼层
刚刚下载,没有问题。
734774645| | 2016-12-3 22:02 | 显示全部楼层
这么好的东西,必须学习学习。
zhuotuzi| | 2016-12-4 14:41 | 显示全部楼层
以后越来越多的人会使用这些免费的东西,因为成本啊。。
wahahaheihei|  楼主 | 2016-12-8 23:04 | 显示全部楼层
这么好的软件,如果你不用那可惜了
dongnanxibei| | 2016-12-11 14:41 | 显示全部楼层
这个软件目前用的人越来越多了。
