* This is a very small example that shows how to use
* protothreads. The program consists of two protothreads that wait
* for each other to toggle a variable.
/* We must always include pt.h in our protothreads code. */
#include "pt.h"
/* Two flags that the two protothread functions use. */
static int protothread1_flag, protothread2_flag;
/* protothread state variables, one for each ptorothread. */
static struct pt pt1, pt2;
// constants won't change. Used here to set a pin number :
const int ledPin = 13; // the number of the LED pin
* The first protothread function. A protothread function must always
* return an integer, but must never explicitly return - returning is
* performed inside the protothread statements.
* The protothread function is driven by the main loop further down in
* the code.
static int protothread1(struct pt *pt)
/* A protothread function must begin with PT_BEGIN() which takes a
pointer to a struct pt. */
PT_BEGIN(pt);
/* We loop forever here. */
while(1) {
/* Wait until the other protothread has set its flag. */
PT_WAIT_UNTIL(pt, protothread2_flag != 0);
Serial.println("Protothread 1 running");
digitalWrite(ledPin,LOW);
/* We then reset the other protothread's flag, and set our own
flag so that the other protothread can run. */
protothread2_flag = 0;
protothread1_flag = 1;
/* And we loop. */
/* All protothread functions must end with PT_END() which takes a
PT_END(pt);
* The second protothread function.
* This one is almost the same as the first one.
static int protothread2(struct pt *pt)
PT_BEGIN(pt);
while(1) {
/* Let the other protothread run. */
protothread2_flag = 1;
PT_WAIT_UNTIL(pt, protothread1_flag != 0);
Serial.println("Protothread 2 running");
digitalWrite(ledPin,HIGH);
/* We then reset the other protothread's flag. */
protothread1_flag = 0;
/* And we loop. */
PT_END(pt);
* setup() is where the protothreads are initialized.
* The state variables pt1 and pt2 holdthe state of the two protothreads.
void setup()
/* Initialize the protothread state variables with PT_INIT(). */
PT_INIT(&pt1);
PT_INIT(&pt2);
Serial.begin(9600);
// set the digital pin as output:
pinMode(ledPin, OUTPUT);
* Finally, we have the main loop.
* This is where the protothreads are scheduled.
void loop()
* We schedule the two protothreads by repeatedly calling their
* protothread functions and passing a pointer to the protothread
* state variables as arguments.
protothread1(&pt1);
protothread2(&pt2);
