[DemoCode下载]
ADC_SingleMode单次转换模式
1532|8
zhuomuniao110|  楼主 | 2016-12-20 22:33 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
* [url=home.php?mod=space&uid=288409]@file[/url]     main.c
* [url=home.php?mod=space&uid=895143]@version[/url]  V3.0
* $Revision: 4 $
* $Date: 14/01/28 11:44a $
* [url=home.php?mod=space&uid=247401]@brief[/url]    M051 Series ADC Interface Controller Driver Sample Code
* @note
* Copyright (C) 2014 Nuvoton Technology Corp. All rights reserved.
#include <stdio.h>
#include "M051Series.h"
#define PLL_CLOCK       50000000
/* Define Function Prototypes        */
void SYS_Init(void);
void UART0_Init(void);
void AdcSingleModeTest(void);
/* Define global variables and constants        */
volatile uint32_t g_u32AdcIntFlag;
void SYS_Init(void)
    /* Init System Clock        */
    /* Enable Internal RC 22.1184MHz clock */
    CLK_EnableXtalRC(CLK_PWRCON_OSC22M_EN_Msk);
    /* Waiting for Internal RC clock ready */
    CLK_WaitClockReady(CLK_CLKSTATUS_OSC22M_STB_Msk);
    /* Switch HCLK clock source to Internal RC and HCLK source divide 1 */
    CLK_SetHCLK(CLK_CLKSEL0_HCLK_S_HIRC, CLK_CLKDIV_HCLK(1));
    /* Enable external XTAL 12MHz clock */
    CLK_EnableXtalRC(CLK_PWRCON_XTL12M_EN_Msk);
    /* Waiting for external XTAL clock ready */
    CLK_WaitClockReady(CLK_CLKSTATUS_XTL12M_STB_Msk);
    /* Set core clock as PLL_CLOCK from PLL */
    CLK_SetCoreClock(PLL_CLOCK);
    /* Enable UART module clock */
    CLK_EnableModuleClock(UART0_MODULE);
    /* Enable ADC module clock */
    CLK_EnableModuleClock(ADC_MODULE);
    /* Select UART module clock source */
    CLK_SetModuleClock(UART0_MODULE, CLK_CLKSEL1_UART_S_PLL, CLK_CLKDIV_UART(1));
    /* ADC clock source is 22.1184MHz, set divider to 7, ADC clock is 22.1184/7 MHz */
    CLK_SetModuleClock(ADC_MODULE, CLK_CLKSEL1_ADC_S_HIRC, CLK_CLKDIV_ADC(7));
    /* Init I/O Multi-function        */
    /* Set P3 multi-function pins for UART0 RXD and TXD */
    SYS->P3_MFP &= ~(SYS_MFP_P30_Msk | SYS_MFP_P31_Msk);
    SYS->P3_MFP |= SYS_MFP_P30_RXD0 | SYS_MFP_P31_TXD0;
    /* Disable the P1.0 - P1.3 digital input path to avoid the leakage current */
    GPIO_DISABLE_DIGITAL_PATH(P1, 0xF);
    /* Configure the P1.0 - P1.3 ADC analog input pins */
    SYS->P1_MFP &= ~(SYS_MFP_P10_Msk | SYS_MFP_P11_Msk | SYS_MFP_P12_Msk | SYS_MFP_P13_Msk);
    SYS->P1_MFP |= SYS_MFP_P10_AIN0 | SYS_MFP_P11_AIN1 | SYS_MFP_P12_AIN2 | SYS_MFP_P13_AIN3 ;
/* Init UART        */
void UART0_Init()
    /* Reset IP */
    SYS_ResetModule(UART0_RST);
    /* Configure UART0 and set UART0 Baudrate */
    UART_Open(UART0, 115200);
/* Function: AdcSingleModeTest        */
/* Parameters:        */
/*   None.        */
/* Returns:        */
/*   None.        */
/* Description:        */
/*   ADC single mode test.        */
void AdcSingleModeTest()
    uint8_t  u8Option;
    int32_t  i32ConversionData;
    printf("\n");
    printf("+----------------------------------------------------------------------+\n");
    printf("|                      ADC single mode sample code                     |\n");
    while(1)
        printf("Select input mode:\n");
        printf("  [1] Single end input (channel 2 only)\n");
        printf("  [2] Differential input (channel pair 1 only)\n");
        printf("  Other keys: exit single mode test\n");
        u8Option = getchar();
        if(u8Option == '1')
            /* Set the ADC operation mode as single, input mode as single-end and enable the analog input channel 2 */
            ADC_Open(ADC, ADC_ADCR_DIFFEN_SINGLE_END, ADC_ADCR_ADMD_SINGLE, 0x1 << 2);
            /* Power on ADC module */
            ADC_POWER_ON(ADC);
            /* clear the A/D interrupt flag for safe */
            ADC_CLR_INT_FLAG(ADC, ADC_ADF_INT);
            /* Enable the ADC interrupt */
            ADC_EnableInt(ADC, ADC_ADF_INT);
            NVIC_EnableIRQ(ADC_IRQn);
            /* Reset the ADC interrupt indicator and Start A/D conversion */
            g_u32AdcIntFlag = 0;
            ADC_START_CONV(ADC);
            /* Wait ADC interrupt (g_u32AdcIntFlag will be set at IRQ_Handler function)*/
            while(g_u32AdcIntFlag == 0);
            /* Disable the ADC interrupt */
            ADC_DisableInt(ADC, ADC_ADF_INT);
            /* Get the conversion result of the ADC channel 2 */
            i32ConversionData = ADC_GET_CONVERSION_DATA(ADC, 2);
            printf("Conversion result of channel 2: 0x%X (%d)\n\n", i32ConversionData, i32ConversionData);
        else if(u8Option == '2')
            /* Set the ADC operation mode as single, input mode as differential and
               enable analog input channel 2 for differential input channel pair 1*/
            ADC_Open(ADC, ADC_ADCR_DIFFEN_DIFFERENTIAL, ADC_ADCR_ADMD_SINGLE, 0x1 << 2);
            ADC_POWER_ON(ADC);
            /* Get the conversion result of the specified ADC channel */
            printf("Conversion result of channel pair 1: 0x%X (%d)\n\n", i32ConversionData, i32ConversionData);
        else
            return ;
/* ADC interrupt handler        */
void ADC_IRQHandler(void)
    g_u32AdcIntFlag = 1;
    ADC_CLR_INT_FLAG(ADC, ADC_ADF_INT); /* clear the A/D conversion flag */
/* MAIN function        */
main(void)
    /* Unlock protected registers */
    SYS_UnlockReg();
    /* Init System, IP clock and multi-function I/O */
    SYS_Init();
    /* Lock protected registers */
    SYS_LockReg();
    /* Init UART0 for printf */
    UART0_Init();
    /* SAMPLE CODE        */
    printf("\nSystem clock rate: %d Hz", SystemCoreClock);
    /* Single Mode test */
    AdcSingleModeTest();
    /* Disable ADC module */
    ADC_Close(ADC);
    /* Disable ADC IP clock */
    CLK_DisableModuleClock(ADC_MODULE);
    /* Disable External Interrupt */
    NVIC_DisableIRQ(ADC_IRQn);
    printf("\nExit ADC sample code\n");
    while(1);
zhuomuniao110|  楼主 | 2016-12-20 22:43 | 只看该作者
实际上稍微修改一下函数的参数就可以实现其他模式的转换了。
643757107| | 2016-12-21 23:38 | 只看该作者
ADC在单片机中是非常重要的,掌握好各种使用方法很重要
zhuomuniao110|  楼主 | 2016-12-26 22:57 | 只看该作者
大家看,这个用法,通道2,直接通过移位运算实现。
huangcunxiake| | 2016-12-27 16:44 | 只看该作者
没想到ADC还有自己的时钟系统。
yiyigirl2014| | 2016-12-27 20:15 | 只看该作者
不知道可以设置中断优先级不可以
捉虫天师| | 2016-12-27 23:57 | 只看该作者
这个地方用这个函数做,就比那种写1清零的好懂多了。
gejigeji521| | 2016-12-30 00:09 | 只看该作者
稍微的修改一下参数就可以变成连续扫描模式的转换。
dianbeng007| | 2017-9-25 14:39 | 只看该作者
好资料,感谢楼主无私奉献
