[项目外包]
有如下设计和代工需求,能做的朋友请联系
1084|3
stantorsh|  楼主 | 2016-12-26 15:48 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
价格:2000 元
ST, AN, TI, TE, se
[color=rgb(102, 65, 135) !important]具体要求
May you help me with engineering in China Mainland who has the know how to build a 5$ Board including
- six IGBT
- one Micro for Motor-control 6kHz handling for Power control
- Input Filter Common mode choke
- passiv switched PFC ( added inductor + FET
- lot of diodes around in that system
- Input capacitor with 105 degrees celsius  long life
- non isolated Powersupply wide Vin Buck up to 600V down to 13V
能帮忙找到方案吗?做一个5美元的板子,需要有以下功能:
- 六个IGBT
- 一个微电机控制,处理6khz功率控制
- 输入滤波器共模阻流器
- 被动开关PFC(附加电感+ FET)
- 必要的二极管
- 输入电容器,要求105摄氏度,长使用寿命
- 非隔离电源,宽Vin 从600V到13V
[color=rgb(102, 65, 135) !important]补充需求
XV
Temperature Range        °C        -10 bis +50
Speed Range        rpm        1000 bis 4000
DC Voltage        VDC        325
Nominal Torque        Nm        0.15
Maximal Torque        Nm        0.55
Voltage constant at 20°C        VS/rad        0.63
Torque Constant 20°C        Nm/A        0.535
LD at 1A        H        0.028
LQ at 1A        H        0.029
Phase resitance 20°c        Ohm        11
Poles        -        6
BEMF Waveform        -        Square Wave
present Start current        APeak        1.7
present Start torque (calculated from Start current)        Nm        0.9
Motor Type        -        BLDC Motor
Estimated time schedule need confirmation, results we like to have ( Schematic / BOM / Costs estimation / prototype board )
stantorsh|  楼主 | 2016-12-26 15:49 | 只看该作者
联系方式:  QQ/微信 914567037
外包小助| | 2016-12-26 16:02 | 只看该作者
可以把项目发到21ic项目外包上,http://project.21ic.com/
