[DemoCode下载]
给予NUC029的定时器捕获
1346|8
wahahaheihei|  楼主 | 2017-2-21 20:17 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
* [url=home.php?mod=space&uid=288409]@file[/url]     main.c
* [url=home.php?mod=space&uid=895143]@version[/url]  V3.00
* $Revision: 3 $
* $Date: 14/01/28 6:42p $
* [url=home.php?mod=space&uid=247401]@brief[/url]    NUC029 Series Timer Driver Sample Code
* @note
* Copyright (C) 2013 Nuvoton Technology Corp. All rights reserved.
#include <stdio.h>
#include "NUC029xAN.h"
#define PLLCON_SETTING      CLK_PLLCON_50MHz_HXT
#define PLL_CLOCK           50000000
/* Global Interface Variables Declarations        */
extern int IsDebugFifoEmpty(void);
volatile uint8_t  g_u8IsWDTTimeoutINT = 0;
volatile uint32_t g_au32TMRINTCount[4] = {0};
* @brief       Timer0 IRQ
* @param       None
* [url=home.php?mod=space&uid=266161]@return[/url]      None
* [url=home.php?mod=space&uid=1543424]@Details[/url]     The Timer0 default IRQ, declared in startup_NUC029xAN.s.
void TMR0_IRQHandler(void)
    /* Clear Timer0 time-out interrupt flag */
    TIMER_ClearIntFlag(TIMER0);
    g_au32TMRINTCount[0]++;
* @brief       Timer1 IRQ
* @param       None
* @return      None
* @details     The Timer1 default IRQ, declared in startup_NUC029xAN.s.
void TMR1_IRQHandler(void)
    if(TIMER_GetCaptureIntFlag(TIMER1) == 1)
        /* Clear Timer1 capture interrupt flag */
        TIMER_ClearCaptureIntFlag(TIMER1);
        g_au32TMRINTCount[1]++;
* @brief       Timer2 IRQ
* @param       None
* @return      None
* @details     The Timer2 default IRQ, declared in startup_NUC029xAN.s.
void TMR2_IRQHandler(void)
    /* Clear Timer2 time-out interrupt flag */
    TIMER_GetIntFlag(TIMER2);
    g_au32TMRINTCount[2]++;
* @brief       Timer3 IRQ
* @param       None
* @return      None
* @details     The Timer3 default IRQ, declared in startup_NUC029xAN.s.
void TMR3_IRQHandler(void)
    /* Clear Timer3 time-out interrupt flag */
    TIMER_GetIntFlag(TIMER3);
    g_au32TMRINTCount[3]++;
void SYS_Init(void)
    /* Init System Clock        */
    /* Enable IRC22M clock */
    CLK->PWRCON |= CLK_PWRCON_IRC22M_EN_Msk;
    /* Waiting for IRC22M clock ready */
    CLK_WaitClockReady(CLK_CLKSTATUS_IRC22M_STB_Msk);
    /* Switch HCLK clock source to HIRC */
    CLK->CLKSEL0 = CLK_CLKSEL0_HCLK_S_HIRC;
    /* Set PLL to Power-down mode and PLL_STB bit in CLKSTATUS register will be cleared by hardware.*/
    CLK->PLLCON |= CLK_PLLCON_PD_Msk;
    /* Enable external 12 MHz XTAL, IRC10K */
    CLK->PWRCON |= CLK_PWRCON_XTL12M_EN_Msk | CLK_PWRCON_OSC10K_EN_Msk;
    /* Enable PLL and Set PLL frequency */
    CLK->PLLCON = PLLCON_SETTING;
    /* Waiting for clock ready */
    CLK_WaitClockReady(CLK_CLKSTATUS_PLL_STB_Msk | CLK_CLKSTATUS_XTL12M_STB_Msk | CLK_CLKSTATUS_IRC10K_STB_Msk);
    /* Switch HCLK clock source to PLL, STCLK to HCLK/2 */
    CLK->CLKSEL0 = CLK_CLKSEL0_STCLK_S_HCLK_DIV2 | CLK_CLKSEL0_HCLK_S_PLL;
    /* Enable peripheral clock */
    CLK->APBCLK = CLK_APBCLK_UART0_EN_Msk |
                  CLK_APBCLK_TMR0_EN_Msk | CLK_APBCLK_TMR1_EN_Msk | CLK_APBCLK_TMR2_EN_Msk | CLK_APBCLK_TMR3_EN_Msk;
    /* Peripheral clock source */
    CLK->CLKSEL1 = CLK_CLKSEL1_UART_S_PLL |
                   CLK_CLKSEL1_TMR0_S_HXT | CLK_CLKSEL1_TMR1_S_HCLK | CLK_CLKSEL1_TMR1_S_HIRC | CLK_CLKSEL1_TMR3_S_HXT;
    /* Update System Core Clock */
    /* User can use SystemCoreClockUpdate() to calculate PllClock, SystemCoreClock and CycylesPerUs automatically. */
    SystemCoreClockUpdate();
    /* Init I/O Multi-function        */
    /* Set P3 multi-function pins for UART0 RXD, TXD, T0, T1 and T1EX */
    SYS->P3_MFP = SYS_MFP_P30_RXD0 | SYS_MFP_P31_TXD0 | SYS_MFP_P34_T0 | SYS_MFP_P35_T1 | SYS_MFP_P33_T1EX;
    /* Set P1 multi-function pins for T3 */
    SYS->P1_MFP = SYS_MFP_P11_T3;
void UART0_Init(void)
    /* Init UART        */
    /* Reset IP */
    SYS_ResetModule(UART0_RST);
    /* Configure UART0 and set UART0 Baudrate */
    UART_Open(UART0, 115200);
/*  MAIN function        */
int main(void)
    volatile uint32_t u32InitCount;
    /* Unlock protected registers */
    SYS_UnlockReg();
    /* Init System, peripheral clock and multi-function I/O */
    SYS_Init();
    /* Lock protected registers */
    SYS_LockReg();
    /* Init UART0 for printf */
    UART0_Init();
    printf("\n\nCPU [url=home.php?mod=space&uid=72445]@[/url] %d Hz\n", SystemCoreClock);
    printf("+---------------------------------------------------+\n");
    printf("|    Timer External Capture Function Sample Code    |\n");
    printf("+---------------------------------------------------+\n\n");
    printf("# Timer Settings:\n");
    printf("  Timer0: Clock source is 12 MHz; Toggle-output mode and frequency is 500 Hz.\n");
    printf("  Timer3: Clock source is 12 MHz; Toggle-output mode and frequency is 1 Hz.\n");
    printf("  Timer1: Clock source is HCLK(50 MHz); Continuous counting mode; TCMP is 0xFFFFFF;\n");
    printf("          Counter pin enable; Capture pin and capture interrupt enable;\n");
    printf("# Generate 500 Hz frequency from T0 and connect T0 pin to Timer1 counter pin.\n");
    printf("# Generate 1 Hz frequency from T3 and connect T3 pin to T1EX capture pin.\n");
    printf("# Get 500 event counts from Timer1 counter pin when each T1EX pin interrupt occurred.\n\n");
    /* Initial Timer0 and Timer3 default setting */
    TIMER_Open(TIMER0, TIMER_TOGGLE_MODE, 1000);
    TIMER_Open(TIMER3, TIMER_TOGGLE_MODE, 2);
    /* Initial Timer1 default setting */
    TIMER_Open(TIMER1, TIMER_CONTINUOUS_MODE, 1);
    /* Configure Timer1 setting for external counter input and capture function */
    TIMER_SET_PRESCALE_VALUE(TIMER1, 0);
    TIMER_SET_CMP_VALUE(TIMER1, 0xFFFFFF);
    TIMER_EnableEventCounter(TIMER1, TIMER_COUNTER_FALLING_EDGE);
    TIMER_EnableCapture(TIMER1, TIMER_CAPTURE_FREE_COUNTING_MODE, TIMER_CAPTURE_FALLING_EDGE);
    TIMER_EnableCaptureInt(TIMER1);
    /* Enable Timer1 NVIC */
    NVIC_EnableIRQ(TMR1_IRQn);
    /* Clear Timer1 interrupt counts to 0 */
    u32InitCount = g_au32TMRINTCount[1] = 0;
    /* Start Timer0, Timer1 and Timer3 counting */
    TIMER_Start(TIMER0);
    TIMER_Start(TIMER1);
    TIMER_Start(TIMER3);
    /* Check T1EX interrupt counts */
    while(g_au32TMRINTCount[1] <= 10)
        if(g_au32TMRINTCount[1] != u32InitCount)
            printf("[%2d] - %4d\n", g_au32TMRINTCount[1], TIMER_GetCaptureData(TIMER1));
            u32InitCount = g_au32TMRINTCount[1];
    /* Stop Timer0, Timer1 and Timer3 counting */
    TIMER_Close(TIMER0);
    TIMER_Close(TIMER1);
    TIMER_Close(TIMER3);
    printf("*** PASS ***\n");
    while(1);
/*** (C) COPYRIGHT 2013 Nuvoton Technology Corp. ***/
wahahaheihei|  楼主 | 2017-2-21 20:41 | 只看该作者
定时器捕获可以很容易获取一个脉冲宽度。
wahahaheihei|  楼主 | 2017-2-21 20:43 | 只看该作者
wahahaheihei|  楼主 | 2017-2-21 20:44 | 只看该作者
1、外部波形周期
得到两个相邻波形上升沿或下降沿的时间T1,T2,
       "T2 - T1"的值就是周期
2、脉冲周期
记录相邻的两个不同极性的沿变化时间T1,T2
   "T2 - T1"的值就是周期
PS:两次输入捕获之间若存在着定时器溢出中断,则需要考虑溢出中断的次数,而不能够直接将T2-T1当作周期,还需考虑定时器溢出中断的周期。
598330983| | 2017-2-21 21:04 | 只看该作者
捕获这方面是主要应用。
天灵灵地灵灵| | 2017-2-21 21:27 | 只看该作者
用之前就要先清理一下,防止里面有随机数。
lss1985| | 2017-6-8 14:30 | 只看该作者
想问下这个例程里面,TIMER0和TIMER3是什么作用,主要是TIMER1在捕捉吧
另外,我想测脉冲宽度,即上述说的第二种,即相邻上升沿和下降沿之间宽度,该怎么改啊
@wahahaheihei
wahahaheihei|  楼主 | 2017-6-9 23:35 | 只看该作者
另外,我想测脉冲宽度,即上述说的 ...
这个例子就是T1的捕获。
lss1985| | 2017-6-11 09:37 | 只看该作者
wahahaheihei 发表于 2017-6-9 23:35
这个例子就是T1的捕获。
大哥,我现在把这个例程移植了一下,用来测速,中断能够进去,但是进去中断后读取TCAP时好像没有数据,中断读取处理如下,能帮我看下么,谢谢
        g_au32TMRINTCount[1]++;        value[g_au32TMRINTCount[1]]=TIMER1->TCAP;
                          if(g_au32TMRINTCount[1]==2)
                                        g_au32TMRINTCount[1]=0;
                                        value_TCAP[1]=value[2]-value[1];
main.rar (3.11 KB)
