STM32固件库,Nand_if.c文件下的NAND_BuildLUT函数问题
4620|1
夜夜|  楼主 | 2010-4-15 14:30 | 显示全部楼层 |阅读模式
STM32固件库,Nand_if.c文件下的NAND_BuildLUT函数调试中出现问题,
即函数最后的那个do{}while ( pFreeBlock < MAX_PHY_BLOCKS_PER_ZONE );
循环中pFreeBlock 会导致LUT 数组溢出,但是我看了好久没明白这段代码的意思;
无从修改。
不知道有没有谁移植过这段程序,望指点一二。
* Function Name  : NAND_BuildLUT
* Description    : Build the look up table
* Input          : None
* Output         : None
* Return         : Status
* !!!! NOTE : THIS ALGORITHM IS A SUBJECT OF PATENT FOR STMICROELECTRONICS !!!!!
static uint16_t NAND_BuildLUT (uint8_t ZoneNbr)
  uint16_t  pBadBlock, pCurrentBlock, pFreeBlock;
  SPARE_AREA  SpareArea;
                                  1st step : Init.
  /*Init the LUT (assume all blocks free) */
  for (pCurrentBlock = 0 ; pCurrentBlock < MAX_PHY_BLOCKS_PER_ZONE ; pCurrentBlock++)
    LUT[pCurrentBlock] = FREE_BLOCK;  /* 12th bit is set to 1 */
  /* Init Pointers */
  pBadBlock    = MAX_PHY_BLOCKS_PER_ZONE - 1;
  pCurrentBlock = 0;
                         2nd step : locate used and bad blocks
  while (pCurrentBlock < MAX_PHY_BLOCKS_PER_ZONE)
    SpareArea = ReadSpareArea(pCurrentBlock * NAND_BLOCK_SIZE + (ZoneNbr * NAND_BLOCK_SIZE * MAX_PHY_BLOCKS_PER_ZONE));
    if ((SpareArea.DataStatus == 0) || (SpareArea.BlockStatus == 0))
      LUT[pBadBlock--]    |= pCurrentBlock | (uint16_t)BAD_BLOCK ;
      LUT[pCurrentBlock] &= (uint16_t)~FREE_BLOCK;
      if (pBadBlock == MAX_LOG_BLOCKS_PER_ZONE)
        return NAND_FAIL;
    else if (SpareArea.LogicalIndex != 0xFFFF)
      LUT[SpareArea.LogicalIndex & 0x3FF] |= pCurrentBlock | VALID_BLOCK | USED_BLOCK;
      LUT[pCurrentBlock] &= (uint16_t)( ~FREE_BLOCK);
    pCurrentBlock++ ;
    printf("2nd step\r\n");
     3rd step : locate Free Blocks by scanning the LUT already built partially
  pFreeBlock = 0;
  for (pCurrentBlock = 0 ; pCurrentBlock < MAX_PHY_BLOCKS_PER_ZONE ; pCurrentBlock++ )
    if ( !(LUT[pCurrentBlock]& USED_BLOCK))
      do
        if (LUT[pFreeBlock] & FREE_BLOCK)
          LUT [pCurrentBlock] |= pFreeBlock;
          LUT [pFreeBlock]   &= ~FREE_BLOCK;
          break;
        pFreeBlock++;
  return NAND_OK;
tiger84| | 2010-5-14 16:44 | 显示全部楼层
老相识了,顶下。
应该已经搞定了吧。
但刚好也在研究nandflash及fs,也说下。
“即函数最后的那个do{}while ( pFreeBlock < MAX_PHY_BLOCKS_PER_ZONE );
循环中pFreeBlock 会导致LUT 数组溢出”
肯定不会溢出的。
这个函数的功能就是建立了一个逻辑上的块表。最终的效果就是在LUT数组里面,好块(包括已经用的和没用的)在前面,坏块都扔到后面去了。如果坏块数超过24块了,这个nand也就报销了。
个人签名:一庭芳草围新绿 有情芍药含春泪
14
