求助:基于FPGA的矩阵键盘程序
2526|8
hd328329346|  楼主 | 2010-4-25 15:32 | 显示全部楼层 |阅读模式
求助:
FPGA的键盘扫描程序,以下是我用Verilog写的,但出现如下错误
Error (10170): Verilog HDL syntax error at jianpan.v(17) near text "b";  expecting ";"
敢问高手改如何解决啊
module jianpan(clk,hang1,lie1,out);
input clk,hang1,lie1;
output out;
wire[2:0] hang1;
wire[5:0] lie1;
reg[2:0] hang;
reg[5:0] lie;
reg[3:0] out;
integer i,out1,out2,out3;
initial
begin
i=0;
out1=0;
out2=0;
out3=0;
hang1=3b'111;    错误提示在这行
lie1=6b'000000;   这行也有同样的错误
end
initial
begin
hang=hang1;
lie=lie1;
end
always(@posedge clk)
begin
if(hang==3b'111)
out=4b'0000;
else if(out1==0)
begin
lie=6b'011111;
if(hang[0]==1)
lie=6b'101111;
if(hang[0]==1)
lie=6b'110111;
if(hang[0]==1)
lie=6b'111011;
if(hang[0]==1)
lie=6b'111101;
if(hang[0]==1)
lie=6b'111110;
if(hang[1]==1)
lie=6b'011111;
if(hang[1]==1)
lie=6b'101111;
if(hang[1]==1)
lie=6b'110111;
if(hang[1]==1)
lie=6b'111011;
else
out1=4b'1001;
else
out1=4b'1000;
else
out1=4b'0111;
else
out1=4b'0111;
else
out1=4b'0110;
else
out1=4b'0101;
else
out1=4b'0100;
else
out1=4b'0011;
else
out1=4b'0010;
else
out1=4b'0001;
end
end
always(@posedge clk&&out1!=0)
begin
if(hang==3b'111)
out=4b'0000;
else if
lie=6b'011111;
if(hang[0]==1)
lie=6b'101111;
if(hang[0]==1)
lie=6b'110111;
if(hang[0]==1)
lie=6b'111011;
if(hang[0]==1)
lie=6b'111101;
if(hang[0]==1)
lie=6b'111110;
if(hang[1]==1)
lie=6b'011111;
if(hang[1]==1)
lie=6b'101111;
if(hang[1]==1)
lie=6b'110111;
if(hang[1]==1)
lie=6b'111011;
else
out2=4b'1001;
else
out2=4b'1000;
else
out2=4b'0111;
else
out2=4b'0111;
else
out2=4b'0110;
else
out2=4b'0101;
else
out2=4b'0100;
else
out2=4b'0011;
else
out2=4b'0010;
else
out2=4b'0001;
end
always(@posedge clk&&out3==0)
begin
if(hang==3b'111)
out=4b'0000;
else if
lie=6b'011111;
if(hang[0]==1)
lie=6b'101111;
if(hang[0]==1)
lie=6b'110111;
if(hang[0]==1)
lie=6b'111011;
if(hang[0]==1)
lie=6b'111101;
if(hang[0]==1)
lie=6b'111110;
if(hang[1]==1)
lie=6b'011111;
if(hang[1]==1)
lie=6b'101111;
if(hang[1]==1)
lie=6b'110111;
if(hang[1]==1)
lie=6b'111011;
else
out3=4b'1001;
else
out3=4b'1000;
else
out3=4b'0111;
else
out3=4b'0111;
else
out3=4b'0110;
else
out3=4b'0101;
else
out3=4b'0100;
else
out3=4b'0011;
else
out3=4b'0010;
else
out3=4b'0001;
end
begin
lie=6b'111110;
if(hang[2]==0)
i=i+1;
if(i==1)
out=out1;
    else if(i==2)
out=out2;
    else if(i==3)
out=out3;
hd328329346|  楼主 | 2010-4-25 16:21 | 显示全部楼层
大家还是不要看这个程序了,问题太多,太复杂了。进来的了留个言吧,50分送你啦~
hd328329346|  楼主 | 2010-4-25 16:54 | 显示全部楼层
在verilog里面,if语句能嵌套多少if啊,像上面嵌了10个的行不行?
lelee007| | 2010-4-25 17:15 | 显示全部楼层
晕翻了
怎么往input里边赋值啊?!
你这是要干吗了?!
zifeiyuuuu| | 2010-4-26 09:34 | 显示全部楼层
哈哈, 你这是别人的例子吧、、  我昨天也看到了
4b'0110;  所有这种格式都不正确, 还有 这么多 if else 要是我可能会考虑一下case casex 语句喔、
ma9453| | 2010-4-26 12:40 | 显示全部楼层
这个是按C语言的思路写VERILOG吧。。。。。。
hd328329346|  楼主 | 2010-5-16 10:11 | 显示全部楼层
唉~
写的真丢人。送分了~
ljolove| | 2010-5-19 10:30 | 显示全部楼层
LZ我有一份写好的扫描矩阵键盘的程序如果需要的话我给发上来
sinetech01| | 2010-5-22 20:54 | 显示全部楼层
输入给赋值能对嘛
