[STM32F7]
[STM32F7]NUCLEO-F722ZE评测(1)建立编程工作环境
3178|3
sky.sun.zz|  楼主 | 2017-3-8 20:03 | 显示全部楼层 |阅读模式
    NUCLEO-F722ZE开发板收到
意法半导体推出了STM32 Nucleo-144的NUCLEO-F722ZE开发板。这块板子集成一个内置512Kb闪存的144针STM32F722ZET6微控制器,以及一个ST-Zio连接器,支持Arduino™-Uno-V3接口,以及可以连接微控制器所有输入输出的ST-morpho扩展排针。并集成了ST-LINK/V2-1编程和调试的IDE。
STM32F722ZE官方介绍的技术参数如下:
  • Core: ARM® 32-bit Cortex® -M7 CPU with FPU,adaptive real-time accelerator (ART Accelerator™)and L1-cache:8 Kbytes of data cache and 8 Kbytes of instruction cache,allowing 0-wait state     execution from embedded Flash memory and external memories, frequency up to 216 MHz, MPU, 462 DMIPS/2.14 DMIPS/MHz (Dhrystone 2.1) and DSP instructions.
  • Memories
    • Up to 512 Kbytes of Flash memory with protection mechanisms (read and write protections,proprietary code readout protection (PCROP))
    • 528 bytes of OTP memory
    • SRAM: 256 Kbytes (including 64 Kbytes of data TCM RAM for critical real-time data)+16 Kbytes of instruction TCM RAM (for critical real-time routines)+4 Kbytes of backup SRAM (available in the lowest power modes)
    • Flexible external memory controller with up to 32-bit data bus: SRAM, PSRAM, SDRAM/LPSDR SDRAM, NOR/NAND memories
  • Dual mode Quad-SPI
  • Clock, reset and supply  management
    • 1.7 V to 3.6 V application supply and I/Os
    • POR, PDR, PVD and BOR
    • Dedicated USB power
    • 4-to-26 MHz crystal oscillator
    • Internal 16 MHz factory-trimmed RC(1% accuracy)
    • 32 kHz oscillator for RTC with calibration
    • Internal 32 kHz RC with calibration
  • Low-power
    • Sleep Stop and Standby modes
    • VBAT supply for RTC, 32×32 bit backup registers+4 Kbytes of backup SRAM
  • 3×12-bit, 2.4 MSPS ADC:up to 24 channels and 7.2 MSPS in triple interleaved mode
  • 2×12-bit D/A converters
  • Up to 18 timers:up to thirteen 16-bit (1x low- power 16-bit timer available in Stop mode) andtwo 32-bit timers, each with up to 4 IC/OC/PWMs or pulse counter and quadrature(incremental) encoder inputs.All 15 timers running up to 216 MHz.2x watchdogs,SysTick timer
  • General-purpose DMA:16-stream DMA controller with FIFOs and burst support
  • Debug mode
    • SWD & JTAG interfaces
    • Cortex® -M7 Trace Macrocell™
  • Up to 140 I/O ports with interrupt capability
    • Up to 136 fast I/Os up to 108 MHz
    • Up to 138 5   V-tolerant I/Os
  • Up to 21 communication  interfaces
    • Up to 3× I2 C interfaces (SMBus/PMBus)
    • Up to 4 USARTs/4  UARTs (27 Mbit/s,ISO7816 interface, LIN,IrDA,modem control)
    • Up to 5 SPIs (up to 50 Mbit/s),3 with muxed simplex I2 Ss for audio class accuracy via internal audio PLL or external clock
    • 2 x SAIs(serial audio interface)
    • 1 x CAN (2.0B active)
    • 2 x SDMMCs
  • Advanced connectivity
    • USB 2.0 full-speed device/host/OTG controller with on-chip PHY
    • USB 2.0 high-speed/full-speed device/host/OTG controller with dedicated DMA, on-chip full-speed PHY and on-chip Hi-speed PHY or ULPI depending on the part number
  • True random number generator
  • CRC calculation unit
  • RTC: subsecond accuracy, hardware calendar
  • 96-bit unique ID
使用MDK进行开发,要到http://www.keil.com/dd2/pack/#/eula-container下载驱动包Keil.STM32F7xx_DFP.2.9.0.pack
STM32Cubemx需要升级到MX.4.19.0或MX.4.20.0以上版本。
这个MX.4.19.0版本在编译STM32F767的LWIP会出现错误。MX.4.20.0未进行测试。
演示代码要到ST官方网站下载STM32Cube_FW_F7_1.60版。代码在STM32Cube_FW_F7_V1.6.0\Projects\STM32F722ZE-Nucleo中。
springvirus| | 2017-3-9 09:45 | 显示全部楼层
顶,评测开始了
zeng_fanlong| | 2017-3-11 08:53 | 显示全部楼层
期待
sky.sun.zz|  楼主 | 2017-3-11 10:04 | 显示全部楼层
