[开发工具]
求助!烧录失败
1393|2
brianholesnake|  楼主 | 2017-3-16 12:59 | 显示全部楼层 |阅读模式
环境:MPLAB IDE v8.80芯片:PIC16F690
报错:
Programming...
The following memory regions failed to program correctly:
Program Memory
Address: 00000000 Expected Value: 0000118a Received Value: 00000000
Programming failed
操作顺序:
Project->Build,Programmer->Program
然后就报错了  求大神帮忙看下
mojingjian| | 2017-3-21 10:00 | 显示全部楼层
我感觉是接触不良或烧录器坏了,“Address: 00000000” 看出来的(新手发表一下自己的想法,不对别怪)
michaellengleng| | 2017-3-23 15:14 | 显示全部楼层
你用什么烧录器烧录690?
