有线 KNX 温度调节装置参考设计
686|5
dirtwillfly|  楼主 | 2017-3-23 10:51 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
描述
This design serves as a demonstration platform for the KNX software and hardware offering for MSP430™ microcontrollers (MCUs) from TI and TAPKO Technologies GmbH™. The wired KNX thermostat takes advantage of the ultra-low-power FRAM technology of the MSP430FR5969 MCU to efficiently achieve a thermostat with persistent user settings upon power cycles. The real time clock (RTC) of the MSP microcontroller enables the creation of temperature profiles for automatic temperature adjustment.  Temperature and humidity measurements are collected by TI’s HDC1000 digital humidity sensor and sent to the MSP MCU over an I2C communication line. The Sharp® Memory LCD BoosterPack™ (430BOOST-SHARP96) plug-in module and four switches are used to create a user interface.
特性
  • Fully certified twisted-pair KNX transceiver
  • KNX stack support for TPUART and bit-based TP
  • Interoperability with any certified KNX device
  • Thermostat with setting retention upon power down
  • KAIstack licensing available through TAPKO Technologies
  • Order 3rd party PHY Module and KNX power supply (info@tapko.de)
  • More information on 3rd party USB-to-KNX
Wired KNX Thermostat Gerber.zip
161.68 KB
dirtwillfly|  楼主 | 2017-3-23 10:53 | 只看该作者
KNX Thermostat TI Design Guide.pdf (8.23 MB)
Using MSP on KNX Systems Application Report.pdf (4.29 MB)
dirtwillfly|  楼主 | 2017-3-23 10:54 | 只看该作者
wangdezhi| | 2017-3-24 22:01 | 只看该作者
dirtwillfly 发表于 2017-3-23 10:51
  • Wired KNX Thermostat CAD Files
  • Wired KNX Thermostat PCB
  • Wired KNX Thermostat BOM
  • 使用特权
    wangdezhi| | 2017-3-24 22:03 | 只看该作者
  • http://www.ti.com.cn/analog/cn/d ... 3&toolTypeId=49
    个人签名:欢迎进入TI MCU论坛      21ic TI技术交流1群:61549143(已满),  21ic TI技术交流2群:311421422 我的博客:http://blog.timcu.com/
    1179
