小白求助,超声波测距出问题,找不出来啊、、、
550|1
小甲鱼123|  楼主 | 2017-3-29 21:45 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include"reg52.h"
#include"intrins.h"        //°üº¬_nop_()
typedef unsigned char uchar;
typedef unsigned int uint;
sbit WE1 = P2^0;
sbit WE2 = P2^1;
sbit WE3 = P2^2;
sbit WE4 = P2^3;
sbit trig = P3^7; //·¢ËÍ´¥·¢ÐͺÅÒý½Å
sbit echo = P3^6; //µÈ´ý½ÓÊܻز¨ÐźÅÒý½Å
sbit led1 = P1^0;
uchar code leddata[]=
                0xC0,  //"0"
                0xF9,  //"1"
                0xA4,  //"2"
                0xB0,  //"3"
                0x99,  //"4"
                0x92,  //"5"
                0x82,  //"6"
                0xF8,  //"7"
                0x80,  //"8"
                0x90,  //"9"
                0x88,  //"A"
                0x83,  //"B"
                0xC6,  //"C"
                0xA1,  //"D"
                0x86,  //"E"
                0x8E,  //"F"
                0x89,  //"H"
                0xC7,  //"L"
                0xC8,  //"n"
                0xC1,  //"u"
                0x8C,  //"P"
                0xA3,  //"o"
uint distance_time;//´æ·Å»Ø²¨Ê±¼ä
uint  distance;
uchar qian = 2,bai = 3,shi = 5,ge = 9;
uint num;
bit fill_flag;
º¯Êý£ºstart_signal()
º¯Êý¹¦ÄÜ£º ÒýÆð³¬Éù²¨Ä£¿é·¢Ëͳ¬Éù²¨ÐźÅ
ÊäÈ룺ÎÞ
Êä³ö£ºÎÞ
void start_signal()
        trig = 1;
        _nop_();
        _nop_();
        _nop_();
        _nop_();
        _nop_();
        _nop_();
        _nop_();
        _nop_();
        _nop_();
        _nop_();
        _nop_();
        _nop_();
        _nop_();
        _nop_();
        _nop_();
        _nop_();
        _nop_();
        _nop_();
        _nop_();
        _nop_();
        trig = 0;
void  count_distance() //¼ÆËã¾àÀë
        distance_time = TH0 * 256 + TL0; //µÃµ½»Ø²¨Íù·µµÄʱ¼ä
  distance = (int)(1.7 * distance_time) / 100 ;//¼ÆËã¾àÀë µ¥Î»cm
        qian = distance / 1000;
        bai = distance % 1000 / 100;
        shi = distance % 1000 % 100 / 10;
        ge = distance % 1000 % 100 / 10;
        TH0 = 0;
        TL0 = 0;led1 = 0;
void timeinit()         //¶¨Ê±Æ÷³õʼ»¯
        TMOD = 0x11;//ÉèÖö¨Ê±Æ÷0Ϊ16λ¶¨Ê±Ä£Ê½£¬¶¨Ê±Æ÷1Ϊ16λ¶¨Ê±Ä£Ê½
        TH0 = 0;
        TL0 = 0;
        TH1 = 0xf8;
        TL1 = 0x30;
        TR1 = 1;
        EA = 1;        //¿ª×ÜÖжÏ
        ET0 = 1; //¿ª¶¨Ê±Æ÷ÖжÏ0
        ET1 = 1; //¿ª¶¨Ê±Æ÷ÖжÏ1
void delay(uchar z)
        uchar x,y;
        for(x = z;x > 0;x--)
                for(y = 110;y > 0;y--);
void display(uchar qian,uchar bai,uchar shi,uchar ge)
        P0 = 0xff;
        WE1 = 0;
        P0 = leddata[qian];
        delay(5);
        WE1 = 1;
        P0 = 0xff;
        WE2 = 0;
        P0 = leddata[bai];
        delay(5);
        WE2 = 1;
        P0 = 0xff;
        WE3 = 0;
        P0 = leddata[shi];
        delay(5);
        WE3 = 1;
        P0 = 0xff;
        WE4 = 0;
        P0 = leddata[ge];
        delay(5);
        WE4 = 1;
        TR1 = 1;
void main()
        timeinit();//¶¨Ê±Æ÷³õʼ»¯
        while(1)
                while(!echo);//µÈ´ý¸ßµçƽµÄµ½À´
                TR0 = 1;  //¿ª¶¨Ê±Æ÷0£¬²âÁ¿»Ø²¨µÄÂö¿í
                TR1 = 0;  //¹Ø±Õ¶¨Ê±Æ÷1
                while(echo); //µÈ´ý¸ßµçƽ½áÊø
                TR0 = 0; //¼ÆÊý½áÊø£¬¹Ø±Õ¶¨Ê±Æ÷0
void T0_time() interrupt 1   //¶¨Ê±Æ÷0ÖжϷþÎñº¯Êý
        fill_flag = 1;
void T1_time() interrupt 3 //¶¨Ê±Æ÷1ÖжϷþÎñº¯Êý
        uchar i;
        TH1 = 0xf8;
        TL0 = 0x30;
        count_distance(); //¼ÆËã¾àÀë
        display(qian,bai,shi,ge); //ÏÔʾËù²âµ½µÄ¾àÀë
        num++;
        if(num >= 400)
                num = 0;
                start_signal();
dirtwillfly| | 2017-3-30 21:01 | 只看该作者
有什么问题?
