[FPGA]
如何用FPGA实现CAN控制器
1823|3
syt6702|  楼主 | 2017-3-31 11:05 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
feihufuture| | 2017-4-1 13:50 | 只看该作者
不适合自己设计,用芯片把
STARM| | 2017-4-4 01:06 | 只看该作者
https://opencores.org/project,can
[size=13.3333px]Status
- Fixed problem when CAN was reset in SW at the inappropriate time. (November, 15, 2004)
- Fixed problem when 0xf was used for TSEG1. CAN tested up to 1 Mbps (October, 27, 2004)
- Tested in HW. Worked with another 11 boards in the system. (May, 12, 2004)
- Tested with the Bosch VHDL Reference System. All tests passed. (May, 12, 2004)
- Tested in HW. Worked with another board with SJA1000 CAN controller on it. (August, 18, 2003)
- 8051 interface added. (March, 12, 2003)
- Memory blocks for Actel APA devices added. Core size is approx. 40000 gates (from which internal fifos take 28000). (March, 1, 2003)
- Final version of the CAN controller is available. (February, 19, 2003)
- Initial version of the CAN controller is available. (February, 11, 2003)
- Status registers still under construction. (February, 11, 2003)
- Verification needed. Small test bench is written but needs to be improved. (February, 11, 2003)
[size=13.3333px]Feedback
Authors are asking anybody that download this IP core to provide a feedback (bug report, wishlist, improvements).
