Two Phase Interleaved LLC Resonant Converter Reference Design Using C2000™ ...
887|11
dirtwillfly|  楼主 | 2017-4-8 22:02 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Description
Resonant converters are popular DC-DC converters frequently used in server, telecom, automotive, industrial and other power supply applications. Their high performance (efficiency, power density, etc.), improving requirements of the various industry standards, and the ever increasing power density goals have made these converters a good choice for medium to high power applications.
This design implements a digitally controlled 500W two phase interleaved LLC resonant converter. The system is controlled by a single C2000™ microcontroller (MCU), TMS320F28379, which also generates PWM waveforms for all power electronic switching devices under all operating modes. This design implements a novel current sharing technique to accurately achieve current balancing between phases.
Features
  • Digitally controlled two phase interleaved LLC resonant DC-to-DC converter
  • Excellent current sharing between phases without any additional hardware
  • Peak efficiency: 94.5%. Efficiency > 90% for all loads above 10% of rated load
  • powerSUITE support for easy adaptation of software for a customized power level
  • Fault protection: phase/output over-current, output over-voltage, and input under-voltage and overvoltage
  • Phase shedding with programmable limits
dirtwillfly|  楼主 | 2017-4-8 22:07 | 只看该作者
Two Phase Interleaved LLC Resonant Converter Using C2000™ MCUs Schematic.pdf (1.32 MB)
Two Phase Interleaved LLC Resonant Converter Using C2000™ MCUs BOM.pdf (119.79 KB)
Two Phase Interleaved LLC Resonant Converter Using C2000™ MCUs Assembly Drawing.pdf (782.25 KB)
Two Phase Interleaved LLC Resonant Converter Using C2000™ MCUs CAD Files.zip (2.38 MB)
Two Phase Interleaved LLC Resonant Converter Using C2000™ MCUs Gerber.zip (278.6 KB)
Two Phase Interleaved LLC Resonant Converter Using C2000™ MCUs PCB.pdf (3.83 MB)
dirtwillfly|  楼主 | 2017-4-8 22:22 | 只看该作者
Two-Phase Interleaved LLC Resonant Converter Design With C2000™ Microcontrollers.pdf (18.95 MB)
febgxu| | 2017-4-9 16:32 | 只看该作者
这是什么电路,英文的没有看懂。
febgxu| | 2017-4-9 16:35 | 只看该作者
两相交错LLC谐振转换器?
xiaoyaodz| | 2017-4-10 20:59 | 只看该作者
febgxu 发表于 2017-4-9 16:35
两相交错LLC谐振转换器?
看着翻译应该是这个电路。
xiaoyaodz| | 2017-4-10 21:00 | 只看该作者
febgxu 发表于 2017-4-9 16:32
这是什么电路,英文的没有看懂。
可以去官网看看相关资料。
wangdezhi| | 2017-4-13 20:57 | 只看该作者
中文的 资料来一份。
wangdezhi| | 2017-4-13 20:59 | 只看该作者
两相交错LLC谐振转换器?
对,就是谐振器。
dirtwillfly|  楼主 | 2017-4-14 08:16 | 只看该作者
wangdezhi 发表于 2017-4-13 20:57
中文的 资料来一份。
么有中文的
kkzz| | 2017-4-14 22:00 | 只看该作者
两相交错LLC谐振转换器?
要使用这个硬件电路吗?
kkzz| | 2017-4-14 22:08 | 只看该作者
TI的资料,都是英文的。
个人签名:欢迎进入TI MCU论坛      21ic TI技术交流1群:61549143(已满),  21ic TI技术交流2群:311421422 我的博客:http://blog.timcu.com/
1179
