[FPGA]
quartus ii 9.0 verilog 仿真报错,求助
929|0
hezewei206|  楼主 | 2017-4-29 13:02 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
编译通过,仿真报错如下不知为何?大神们,帮我快看看,万分感谢!
Error: Zero-time oscillation in node "|address|Add1~0" at time 0.0 ns. Check the design or vector source file for combinational loop.
代码如下:
module address(dir,clk,div,addr);
input clk,dir;
input[8:0] div;
output[8:0] addr;
reg[1:0] count_addr;
reg[48:0] count;
reg fenpin_clk;
reg[8:0] addr;
always @(negedge clk)
begin
        count=count+1;
        if(count==500000)  //fenpin 20ms
                begin
                        count=0;
                                fenpin_clk=~fenpin_clk;
                end
end
always @(negedge clk )
begin
        if(dir==0)
                begin
                count_addr=count_addr+1;
                        if(count_addr>=2)
                                count_addr=0;
                end
end
always @(count_addr)
begin
        case(count_addr)
                0:addr=addr+div;
                1:addr=addr-div;
                default:addr=addr+div;
        endcase
end
endmodule
