[DemoCode下载]
Nano100的定时器写延时函数
1409|7
zhuomuniao110|  楼主 | 2017-5-4 17:42 | 显示全部楼层 |阅读模式
* [url=home.php?mod=space&uid=288409]@file[/url]     main.c
* [url=home.php?mod=space&uid=895143]@version[/url]  V1.00
* $Revision: 3 $
* $Date: 14/09/11 7:17p $
* [url=home.php?mod=space&uid=247401]@brief[/url]    Demonstrate the usage of TIMER_Delay() API to generate a 1 second delay
* @note
* Copyright (C) 2013 Nuvoton Technology Corp. All rights reserved.
#include <stdio.h>
#include "Nano100Series.h"
void SYS_Init(void)
    /* Init System Clock        */
    /* Unlock protected registers */
    SYS_UnlockReg();
    /* Enable External XTAL (4~24 MHz) */
    CLK_EnableXtalRC(CLK_PWRCTL_HXT_EN_Msk);
    /* Waiting for 12MHz clock ready */
    CLK_WaitClockReady( CLK_CLKSTATUS_HXT_STB_Msk);
    /* Switch HCLK clock source to HXT */
    CLK_SetHCLK(CLK_CLKSEL0_HCLK_S_HXT,CLK_HCLK_CLK_DIVIDER(1));
    /* Enable IP clock */
    CLK_EnableModuleClock(UART0_MODULE);
    CLK_EnableModuleClock(TMR0_MODULE);
    /* Select IP clock source */
    CLK_SetModuleClock(UART0_MODULE, CLK_CLKSEL1_UART_S_HXT, CLK_UART_CLK_DIVIDER(1));
    CLK_SetModuleClock(TMR0_MODULE, CLK_CLKSEL1_TMR0_S_HXT, 0);
    /* Update System Core Clock */
    /* User can use SystemCoreClockUpdate() to calculate SystemCoreClock. */
    SystemCoreClockUpdate();
    /* Init I/O Multi-function        */
    /* Set GPB multi-function pins for UART0 RXD and TXD */
    SYS->PB_L_MFP &= ~(SYS_PB_L_MFP_PB0_MFP_Msk | SYS_PB_L_MFP_PB1_MFP_Msk);
    SYS->PB_L_MFP |= (SYS_PB_L_MFP_PB1_MFP_UART0_TX | SYS_PB_L_MFP_PB0_MFP_UART0_RX);
    /* Lock protected registers */
    SYS_LockReg();
int main(void)
    /* Init System, IP clock and multi-function I/O
       In the end of SYS_Init() will issue SYS_LockReg()
       to lock protected register. If user want to write
       protected register, please issue SYS_UnlockReg()
       to unlock protected register if necessary */
    SYS_Init();
    /* Init UART to 115200-8n1 for print message */
    UART_Open(UART0, 115200);
    printf("\nThis sample code use timer to create a small delay \n");
    while(1) {
        printf("Delay 1 second\n");
        TIMER_Delay(TIMER0, 1000000);
/*** (C) COPYRIGHT 2013 Nuvoton Technology Corp. ***/
zhuomuniao110|  楼主 | 2017-5-4 17:44 | 显示全部楼层
void TIMER_Delay(TIMER_T *timer, uint32_t u32Usec);
这个是定时器延时函数的原型
zhuomuniao110|  楼主 | 2017-5-4 17:45 | 显示全部楼层
  * @brief This API is used to create a delay loop for u32usec micro seconds
  * @param[in] timer The base address of Timer module
  * @param[in] u32Usec Delay period in micro seconds with 10 usec every step. Valid values are between 10~1000000 (10 micro second ~ 1 second)
  * [url=home.php?mod=space&uid=266161]@return[/url] None
  * @note This API overwrites the register setting of the timer used to count the delay time.
  * @note This API use polling mode. So there is no need to enable interrupt for the timer module used to generate delay
    uint32_t u32Clk = TIMER_GetModuleClock(timer);
    uint32_t u32Prescale = 0, delay = SystemCoreClock / u32Clk;
    long long u64Cmpr;
    // Clear current timer configuration
    timer->CTL = 0;
    if(u32Clk == 10000) {         // min delay is 100us if timer clock source is LIRC 10k
        u32Usec = ((u32Usec + 99) / 100) * 100;
    } else {    // 10 usec every step
        u32Usec = ((u32Usec + 9) / 10) * 10;
    if(u32Clk >= 0x2000000) {
        u32Prescale = 3;    // real prescaler value is 4
        u32Clk >>= 2;
    } else if(u32Clk >= 0x1000000) {
        u32Prescale = 1;    // real prescaler value is 2
        u32Clk >>= 1;
    // u32Usec * u32Clk might overflow if using uint32_t
    u64Cmpr = ((long long)u32Usec * (long long)u32Clk) / (long long)1000000;
    timer->CMPR = (uint32_t)u64Cmpr;
    timer->PRECNT = u32Prescale;
    timer->CTL = TIMER_CTL_TMR_EN_Msk; // one shot mode
    // When system clock is faster than timer clock, it is possible timer active bit cannot set in time while we check it.
    // And the while loop below return immediately, so put a tiny delay here allowing timer start counting and raise active flag.
    for(; delay > 0; delay--) {
        __NOP();
    while(timer->CTL & TIMER_CTL_TMR_ACT_Msk);
这个是定时器延时函数的实现
实现的过程是复杂的,我们是不是该考虑这个实现过程消耗掉的时间呢?
wahahaheihei| | 2017-5-4 23:14 | 显示全部楼层
通过查询定时器做到延时的效果
huangcunxiake| | 2017-5-5 14:40 | 显示全部楼层
关于那个实现过程,感觉好复杂,没看懂。
捉虫天师| | 2017-5-5 16:21 | 显示全部楼层
看了一下,基本上那个系统初始化代码都是可以拿来主义的。
yiyigirl2014| | 2017-5-6 20:52 | 显示全部楼层
如果跑系统,那么系统是如何管理这些中断和定时器的?
wahahaheihei| | 2017-5-7 16:17 | 显示全部楼层
这个是延时的范围,还是很大呢,那个最小的是10,可能就是考虑到了实现部分的其他代码。
