[DemoCode下载]
M051寄存器操作IO中断
1024|7
玛尼玛尼哄|  楼主 | 2017-5-17 22:53 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
* [url=home.php?mod=space&uid=288409]@file[/url]     main.c
* [url=home.php?mod=space&uid=895143]@version[/url]  V3.00
* $Revision: 3 $
* $Date: 14/04/03 9:18a $
* [url=home.php?mod=space&uid=247401]@brief[/url]    M051 Series GPIO Driver Sample Code
* @note
* Copyright (C) 2013 Nuvoton Technology Corp. All rights reserved.
#include <stdio.h>
#include "M051Series.h"
#define PLLCON_SETTING      CLK_PLLCON_50MHz_HXT
#define PLL_CLOCK           50000000
* @brief       Port0/Port1 IRQ
* @param       None
* [url=home.php?mod=space&uid=266161]@return[/url]      None
* [url=home.php?mod=space&uid=1543424]@Details[/url]     The Port0/Port1 default IRQ, declared in startup_M051Series.s.
void GPIOP0P1_IRQHandler(void)
    /* To check if P1.3 interrupt occurred */
    if(P1->ISRC & BIT3)
        P1->ISRC = BIT3;
        printf("P1.3 INT occurred.\n");
    else
        /* Un-expected interrupt. Just clear all PORT0, PORT1 interrupts */
        P0->ISRC = P0->ISRC;
        P1->ISRC = P1->ISRC;
        printf("Un-expected interrupts.\n");
* @brief       Port2/Port3/Port4 IRQ
* @param       None
* @return      None
* @details     The Port2/Port3/Port4 default IRQ, declared in startup_M051Series.s.
void GPIOP2P3P4_IRQHandler(void)
    /* To check if P4.5 interrupt occurred */
    if(P4->ISRC & BIT5)
        P4->ISRC = BIT5;
        printf("P4.5 INT occurred.\n");
    else
        /* Un-expected interrupt. Just clear all PORT2, PORT3 and PORT4 interrupts */
        P2->ISRC = P2->ISRC;
        P3->ISRC = P3->ISRC;
        P4->ISRC = P4->ISRC;
void SYS_Init(void)
    /* Init System Clock        */
    /* Enable Internal RC 22.1184MHz clock */
    CLK->PWRCON |= CLK_PWRCON_OSC22M_EN_Msk;
    /* Waiting for Internal RC clock ready */
    while(!(CLK->CLKSTATUS & CLK_CLKSTATUS_OSC22M_STB_Msk));
    /* Switch HCLK clock source to Internal RC and and HCLK source divide 1 */
    CLK->CLKSEL0 &= ~CLK_CLKSEL0_HCLK_S_Msk;
    CLK->CLKSEL0 |= CLK_CLKSEL0_HCLK_S_HIRC;
    CLK->CLKDIV &= ~CLK_CLKDIV_HCLK_N_Msk;
    CLK->CLKDIV |= CLK_CLKDIV_HCLK(1);
    /* Enable external XTAL 12MHz clock */
    CLK->PWRCON |= CLK_PWRCON_XTL12M_EN_Msk;
    /* Waiting for external XTAL clock ready */
    while(!(CLK->CLKSTATUS & CLK_CLKSTATUS_XTL12M_STB_Msk));
    /* Set core clock as PLL_CLOCK from PLL */
    CLK->PLLCON = PLLCON_SETTING;
    while(!(CLK->CLKSTATUS & CLK_CLKSTATUS_PLL_STB_Msk));
    CLK->CLKSEL0 &= (~CLK_CLKSEL0_HCLK_S_Msk);
    CLK->CLKSEL0 |= CLK_CLKSEL0_HCLK_S_PLL;
    /* Update System Core Clock */
    /* User can use SystemCoreClockUpdate() to calculate PllClock, SystemCoreClock and CycylesPerUs automatically. */
    //SystemCoreClockUpdate();
    PllClock        = PLL_CLOCK;            // PLL
    SystemCoreClock = PLL_CLOCK / 1;        // HCLK
    CyclesPerUs     = PLL_CLOCK / 1000000;  // For SYS_SysTickDelay()
    /* Enable UART module clock */
    CLK->APBCLK |= CLK_APBCLK_UART0_EN_Msk;
    /* Select UART module clock source */
    CLK->CLKSEL1 &= ~CLK_CLKSEL1_UART_S_Msk;
    CLK->CLKSEL1 |= CLK_CLKSEL1_UART_S_PLL;
    /* Init I/O Multi-function        */
    /* Set P3 multi-function pins for UART0 RXD and TXD */
    SYS->P3_MFP &= ~(SYS_MFP_P30_Msk | SYS_MFP_P31_Msk);
    SYS->P3_MFP |= (SYS_MFP_P30_RXD0 | SYS_MFP_P31_TXD0);
void UART0_Init()
    /* Init UART        */
    /* Reset UART IP */
    SYS->IPRSTC2 |=  SYS_IPRSTC2_UART0_RST_Msk;
    SYS->IPRSTC2 &= ~SYS_IPRSTC2_UART0_RST_Msk;
    /* Configure UART0 and set UART0 Baudrate */
    UART0->BAUD = UART_BAUD_MODE2 | UART_BAUD_MODE2_DIVIDER(PLL_CLOCK, 115200);
    UART0->LCR = UART_WORD_LEN_8 | UART_PARITY_NONE | UART_STOP_BIT_1;
/* MAIN function        */
int main(void)
    /* Unlock protected registers */
    SYS->REGWRPROT = 0x59;
    SYS->REGWRPROT = 0x16;
    SYS->REGWRPROT = 0x88;
    /* Init System, peripheral clock and multi-function I/O */
    SYS_Init();
    /* Lock protected registers */
    SYS->REGWRPROT = 0x0;
    /* Init UART0 for printf */
    UART0_Init();
    printf("\n\nCPU [url=home.php?mod=space&uid=72445]@[/url] %d Hz\n", SystemCoreClock);
    printf("+------------------------------------------------+\n");
    printf("|    GPIO P1.3 and P4.5 Interrupt Sample Code    |\n");
    printf("+------------------------------------------------+\n\n");
    /* GPIO Interrupt Function Test        */
    printf("P1.3 and P4.5 are used to test interrupt ......\n");
    /* Configure P1.3 as Input mode and enable interrupt by rising edge trigger */
    P1->PMD = P1->PMD & (~GPIO_PMD_PMD3_Msk) | (GPIO_PMD_INPUT << GPIO_PMD_PMD3_Pos);
    P1->IMD |= (GPIO_IMD_EDGE << 3);
    P1->IEN |= (BIT3 << GPIO_IEN_IR_EN_Pos);
    NVIC_EnableIRQ(GPIO_P0P1_IRQn);
    /*  Configure P4.5 as Quasi-bidirection mode and enable interrupt by falling edge trigger */
    P4->PMD = P1->PMD & (~GPIO_PMD_PMD5_Msk) | (GPIO_PMD_QUASI << GPIO_PMD_PMD5_Pos);
    P4->IMD |= (GPIO_IMD_EDGE << 5);
    P4->IEN |= (BIT5 << GPIO_IEN_IF_EN_Pos);
    NVIC_EnableIRQ(GPIO_P2P3P4_IRQn);
    /* Waiting for interrupts */
    while(1);
/*** (C) COPYRIGHT 2013 Nuvoton Technology Corp. ***/
玛尼玛尼哄|  楼主 | 2017-5-17 22:54 | 只看该作者
实际上如果熟记相关寄存器的功能后,用寄存器操作也是很简单的。
玛尼玛尼哄|  楼主 | 2017-5-17 22:56 | 只看该作者
我们看到因为共用了中断入口,所以对应的标志位都是要清一下的
上面的程序看是读取后,赋值,实际上是因为该寄存器是写1清零。
玛尼玛尼哄|  楼主 | 2017-5-17 22:57 | 只看该作者
这些都是要仔细看手册的说明才能知道的。不能凭空臆测
heisexingqisi| | 2017-5-18 20:00 | 只看该作者
有时候寄存器和库函数版本都要学
xixi2017| | 2017-5-18 21:49 | 只看该作者
是不是直接修改这个就可以更改时钟了,太厉害了。
bingkaiok| | 2017-5-18 23:27 | 只看该作者
不懂寄存器是不能完全看懂库函数的
huangcunxiake| | 2017-5-19 10:55 | 只看该作者
寄存器操作还是很方便的。不过移植性小了点。
