发新帖本帖赏金 2.33元(功能说明)我要提问
123
返回列表
定时中断死循环,求助?
楼主: suolong
xyz549040622| | 2017-6-16 09:44 | 显示全部楼层
suolong 发表于 2017-6-16 08:39
1.在启动文件中申明了ADC中断
2.不是中断出不来,而是进不了ADC中断。
你那个申明不对,我给你复制看看。加extern就是申明啦?
xyz549040622| | 2017-6-16 09:46 | 显示全部楼层
1.在启动文件中申明了ADC中断
       EXPORT  __Vectors
__Vectors
        DCD     StackMem + Stack            ; Top of Stack
        DCD     Reset_Handler               ; Reset Handler
        DCD     NmiSR                       ; NMI Handler
        DCD     FaultISR                    ; Hard Fault Handler
        DCD     IntDefaultHandler           ; The MPU fault handler
        DCD     IntDefaultHandler           ; The bus fault handler
        DCD     IntDefaultHandler           ; The usage fault handler
        DCD     0                           ; Reserved
        DCD     0                           ; Reserved
        DCD     0                           ; Reserved
        DCD     0                           ; Reserved
        DCD     IntDefaultHandler           ; SVCall handler
        DCD     IntDefaultHandler           ; Debug monitor handler
        DCD     0                           ; Reserved
        DCD     IntDefaultHandler           ; The PendSV handler
        DCD     IntDefaultHandler           ; The SysTick handler
        DCD     IntDefaultHandler           ; GPIO Port A
        DCD     IntDefaultHandler           ; GPIO Port B
        DCD     IntDefaultHandler           ; GPIO Port C
        DCD     IntDefaultHandler           ; GPIO Port D
        DCD     IntDefaultHandler           ; GPIO Port E
        DCD     IntDefaultHandler           ; UART0 Rx and Tx
        DCD     IntDefaultHandler           ; UART1 Rx and Tx
        DCD     IntDefaultHandler           ; SSI0 Rx and Tx
        DCD     IntDefaultHandler           ; I2C0 Master and Slave
        DCD     IntDefaultHandler           ; PWM Fault
        DCD     IntDefaultHandler           ; PWM Generator 0
        DCD     IntDefaultHandler           ; PWM Generator 1
        DCD     IntDefaultHandler           ; PWM Generator 2
        DCD     IntDefaultHandler           ; Quadrature Encoder 0
        DCD     IntDefaultHandler           ; ADC Sequence 0
        DCD     IntDefaultHandler           ; ADC Sequence 1
        DCD     IntDefaultHandler           ; ADC Sequence 2
        DCD     IntDefaultHandler           ; ADC Sequence 3
        DCD     IntDefaultHandler           ; Watchdog timer
        DCD     IntDefaultHandler           ; Timer 0 subtimer A
        DCD     IntDefaultHandler           ; Timer 0 subtimer B
        DCD     IntDefaultHandler           ; Timer 1 subtimer A
        DCD     IntDefaultHandler           ; Timer 1 subtimer B
        DCD     IntDefaultHandler           ; Timer 2 subtimer A
        DCD     IntDefaultHandler           ; Timer 2 subtimer B
        DCD     IntDefaultHandler           ; Analog Comparator 0
        DCD     IntDefaultHandler           ; Analog Comparator 1
        DCD     IntDefaultHandler           ; Analog Comparator 2
        DCD     IntDefaultHandler           ; System Control (PLL, OSC, BO)
        DCD     IntDefaultHandler           ; FLASH Control
        DCD     IntDefaultHandler           ; GPIO Port F
        DCD     IntDefaultHandler           ; GPIO Port G
        DCD     IntDefaultHandler           ; GPIO Port H
        DCD     IntDefaultHandler           ; UART2 Rx and Tx
        DCD     IntDefaultHandler           ; SSI1 Rx and Tx
        DCD     IntDefaultHandler           ; Timer 3 subtimer A
        DCD     IntDefaultHandler           ; Timer 3 subtimer B
        DCD     IntDefaultHandler           ; I2C1 Master and Slave
        DCD     IntDefaultHandler           ; Quadrature Encoder 1
        DCD     IntDefaultHandler           ; CAN0
        DCD     IntDefaultHandler           ; CAN1
        DCD     0                           ; Reserved
        DCD     0                           ; Reserved
        DCD     IntDefaultHandler           ; Hibernate
        DCD     IntDefaultHandler           ; USB0
        DCD     IntDefaultHandler           ; PWM Generator 3
        DCD     IntDefaultHandler           ; uDMA Software Transfer
        DCD     IntDefaultHandler           ; uDMA Error
        DCD     IntDefaultHandler           ; ADC1 Sequence 0
        DCD     IntDefaultHandler           ; ADC1 Sequence 1
        DCD     IntDefaultHandler           ; ADC1 Sequence 2
        DCD     IntDefaultHandler           ; ADC1 Sequence 3
        DCD     0                           ; Reserved
        DCD     0                           ; Reserved
        DCD     IntDefaultHandler           ; GPIO Port J
        DCD     IntDefaultHandler           ; GPIO Port K
        DCD     IntDefaultHandler           ; GPIO Port L
        DCD     IntDefaultHandler           ; SSI2 Rx and Tx
        DCD     IntDefaultHandler           ; SSI3 Rx and Tx
        DCD     IntDefaultHandler           ; UART3 Rx and Tx
        DCD     IntDefaultHandler           ; UART4 Rx and Tx
        DCD     IntDefaultHandler           ; UART5 Rx and Tx
        DCD     IntDefaultHandler           ; UART6 Rx and Tx
        DCD     IntDefaultHandler           ; UART7 Rx and Tx
        DCD     0                           ; Reserved
        DCD     0                           ; Reserved
        DCD     0                           ; Reserved
        DCD     0                           ; Reserved
        DCD     IntDefaultHandler           ; I2C2 Master and Slave
        DCD     IntDefaultHandler           ; I2C3 Master and Slave
        DCD     IntDefaultHandler           ; Timer 4 subtimer A
        DCD     IntDefaultHandler           ; Timer 4 subtimer B
        DCD     0                           ; Reserved
        DCD     0                           ; Reserved
        DCD     0                           ; Reserved
        DCD     0                           ; Reserved
        DCD     0                           ; Reserved
        DCD     0                           ; Reserved
        DCD     0                           ; Reserved
        DCD     0                           ; Reserved
        DCD     0                           ; Reserved
        DCD     0                           ; Reserved
        DCD     0                           ; Reserved
        DCD     0                           ; Reserved
        DCD     0                           ; Reserved
        DCD     0                           ; Reserved
        DCD     0                           ; Reserved
        DCD     0                           ; Reserved
        DCD     0                           ; Reserved
        DCD     0                           ; Reserved
        DCD     0                           ; Reserved
        DCD     0                           ; Reserved
        DCD     IntDefaultHandler           ; Timer 5 subtimer A
        DCD     IntDefaultHandler           ; Timer 5 subtimer B
        DCD     IntDefaultHandler           ; Wide Timer 0 subtimer A
        DCD     IntDefaultHandler           ; Wide Timer 0 subtimer B
        DCD     IntDefaultHandler           ; Wide Timer 1 subtimer A
        DCD     IntDefaultHandler           ; Wide Timer 1 subtimer B
        DCD     IntDefaultHandler           ; Wide Timer 2 subtimer A
        DCD     IntDefaultHandler           ; Wide Timer 2 subtimer B
        DCD     IntDefaultHandler           ; Wide Timer 3 subtimer A
        DCD     IntDefaultHandler           ; Wide Timer 3 subtimer B
        DCD     IntDefaultHandler           ; Wide Timer 4 subtimer A
        DCD     IntDefaultHandler           ; Wide Timer 4 subtimer B
        DCD     IntDefaultHandler           ; Wide Timer 5 subtimer A
        DCD     IntDefaultHandler           ; Wide Timer 5 subtimer B
        DCD     IntDefaultHandler           ; FPU
        DCD     0                           ; Reserved
        DCD     0                           ; Reserved
        DCD     IntDefaultHandler           ; I2C4 Master and Slave
        DCD     IntDefaultHandler           ; I2C5 Master and Slave
        DCD     IntDefaultHandler           ; GPIO Port M
        DCD     IntDefaultHandler           ; GPIO Port N
        DCD     IntDefaultHandler           ; Quadrature Encoder 2
        DCD     0                           ; Reserved
        DCD     0                           ; Reserved
        DCD     IntDefaultHandler           ; GPIO Port P (Summary or P0)
        DCD     IntDefaultHandler           ; GPIO Port P1
        DCD     IntDefaultHandler           ; GPIO Port P2
        DCD     IntDefaultHandler           ; GPIO Port P3
        DCD     IntDefaultHandler           ; GPIO Port P4
        DCD     IntDefaultHandler           ; GPIO Port P5
        DCD     IntDefaultHandler           ; GPIO Port P6
        DCD     IntDefaultHandler           ; GPIO Port P7
        DCD     IntDefaultHandler           ; GPIO Port Q (Summary or Q0)
        DCD     IntDefaultHandler           ; GPIO Port Q1
        DCD     IntDefaultHandler           ; GPIO Port Q2
        DCD     IntDefaultHandler           ; GPIO Port Q3
        DCD     IntDefaultHandler           ; GPIO Port Q4
        DCD     IntDefaultHandler           ; GPIO Port Q5
        DCD     IntDefaultHandler           ; GPIO Port Q6
        DCD     IntDefaultHandler           ; GPIO Port Q7
        DCD     IntDefaultHandler           ; GPIO Port R
        DCD     IntDefaultHandler           ; GPIO Port S
        DCD     IntDefaultHandler           ; PWM 1 Generator 0
        DCD     IntDefaultHandler           ; PWM 1 Generator 1
        DCD     IntDefaultHandler           ; PWM 1 Generator 2
        DCD     IntDefaultHandler           ; PWM 1 Generator 3
        DCD     IntDefaultHandler           ; PWM 1 Fault
需要在这里定义的。
打赏榜单
suolong 打赏了 2.33 元 2017-06-16
suolong|  楼主 | 2017-6-16 14:40 | 显示全部楼层
xyz549040622 发表于 2017-6-16 09:46
需要在这里定义的。
谢谢,大神。
suolong|  楼主 | 2017-6-16 14:43 | 显示全部楼层
suolong 发表于 2017-6-15 17:01
1.  //设置系统时钟为40MHz(400/2.5/4=40)
        SysCtlClockSet(SYSCTL_SYSDIV_1 |SYSCTL_USE_PLL|SYSC ...
@xyz549040622 ,大神指导一下时钟问题,现在ADC中断能进了,可是不知道为什么用TIMER触发ADC,不知道是不是时钟频率问题,搭配不上。我的系统时钟是200MHZ?不对吧,还是这个SysCtlClockGet()?
xyz549040622| | 2017-6-16 14:53 | 显示全部楼层
suolong 发表于 2017-6-16 14:43
@xyz549040622 ,大神指导一下时钟问题,现在ADC中断能进了,可是不知道为什么用TIMER触发ADC,不知道是 ...
谢谢你的打赏。TM4C123x的这个时钟获取函数不对,有问题,官方承认的bug,最新版的库不知道有没有改,你可以试试,不知道你的库的版本。你用ROM_SysCtlClockGet()看看。
发新帖 本帖赏金 2.33元(功能说明)我要提问
