SPIM 模块
494|6
 楼主| pangb 发表于 2017-6-18 19:48 | 显示全部楼层 |阅读模式
请问有谁调试成功过CY8C21434 SPIM 模块的读操作,
xxrs 发表于 2017-6-18 19:51 | 显示全部楼层
可以向SPI从设备写操作?
 楼主| pangb 发表于 2017-6-18 19:53 | 显示全部楼层
kangzj 发表于 2017-6-18 19:54 | 显示全部楼层
程序我看看
 楼主| pangb 发表于 2017-6-18 21:48 | 显示全部楼层
void SPI_Write(unsigned char dig)
PRT2DR |= CS;
while(!(SPIM_1_bReadStatus() & SPIM_1_SPIM_TX_BUFFER_EMPTY)){};
PRT2DR &= ~CS;  // set slave select low
SPIM_1_SendTxData(dig); // set message to transmit
while(!(SPIM_1_bReadStatus() & SPIM_1_SPIM_SPI_COMPLETE)){};
PRT2DR |= CS; //
unsigned char SPI_Read(void)
unsigned char ReceivedData;
PRT2DR |= CS;
PRT2DR &= ~CS;
SPIM_1_SendTxData(0x00);  // 写伪数据,以便读到数据
while(!(SPIM_1_bReadStatus() &  SPIM_1_SPIM_RX_BUFFER_FULL));//RX Buffer register has received current data
ReceivedData = SPIM_1_bReadRxData();
PRT2DR |= CS;
return ReceivedData;
liuzaiy 发表于 2017-6-18 21:50 | 显示全部楼层
不懂,帮顶吧
 楼主| pangb 发表于 2017-6-18 21:52 | 显示全部楼层
唉,还是没有什么结果,算了,先结贴吧,多谢大家啦
