RJ,RJM,EE,5PPM,万分之五精度
1375|2
shitahu|  楼主 | 2010-5-25 14:55 | 显示全部楼层 |阅读模式
1/4W,1/2W,1/8W,1W,2W,2WS,精度1%5%0.1%0.3%0.5%
RJ电阻高精密RJ系列金属膜电阻器,环氧涂复,色码标志,是用镍铬或类似的合金真空电镀技术,着膜于白瓷棒表面,经过切割调试阻值,以达到最终要求的精密阻值。金属膜电阻器提供广泛的阻值范围,有着精密阻值,公差范围小的特性。
RJ Series RJ-resistance high-precision metal film resistors, epoxy coating, color-coded signs, is to use nickel-chromium alloy or similar vacuum plating technology, the membrane on the white rod surface, after cutting debug resistance in order to achieve the final requirements Precision resistance. Metal film resistors offer a wide range of resistance range, with precision resistance, tolerance range of small features.
精密电阻生产厂家,如有需求请联系QQ157164068
RJM电阻MELF Resistor 又可称为晶圆电阻、圆柱型电阻、无引脚电阻、或无引线电阻,主要用于表面贴装加工过程。晶圆无引脚电阻与芯片(贴片)电阻,同样为表面贴装组件,晶圆电阻在功能上,机械结构上,电气特性上,安全性上,明显优于贴片(芯片)电阻,且杂音比厚膜芯片电阻器更低。圆柱型MELF电阻主要适用于功率型/高压冲击型/精密型/安全性要求高的高阶电路中。精密电阻生产厂家,如有需求请联系QQ157164068
RJM resistor MELF Resistors also can
be called a wafer resistance, cylindrical-type resistance, non-pin resistance, or non-lead resistance, mainly used for surface mount processing. No pin wafer and chip resistor (SMD) resistors, the same for surface mount components, wafer resistor function, mechanical structure, electrical properties, the safety of the obviously superior chip (chip) resistors, and the noise lower than the thick-film chip resistors. Cylindrical MELF resistors are applied to power type / high impact type / precision / high-end security requirements of high circuit.
3>
RG电阻是用金属铀镀于磁棒上面,有着极佳的耐冲击特性及耐高压,可靠性高、脉冲负载能力强、电压系数低等性能,广泛地使用于通讯设备、高质量电源等领域。
RG resistance is uranium metal plating on the top bar magnet, has excellent impact resistance characteristics and high voltage, high reliability, pulse load capability, low voltage coefficient of performance, widely used in communications equipment, high-quality power supplies and other areas
. EE电阻系列属于超高精密金属膜电阻,模压封装,防潮性能好. 25-85,测试条件下温度系数最高可到± 5PPM/,最低阻值覆盖至10 Ohm。广泛应用于高精密仪器仪表.
EE Resistance Series are high precision metal film resistors, molded packaging, moisture-proof performance is good. 25-85 , tested under the conditions of temperature coefficient of the maximum to ± 5PPM / , the lowest resistance coverage to 10 Ohm.is widely used in high precision instruments .
RGM电阻是用金属玻璃釉镀于磁棒上面,有着极佳的耐冲击特性及高温稳定性,散热性好,阻值范围广,价格便宜,广泛应用于高功率设备,是新一代表面贴装线路设计的最佳选择。精密电阻生产厂家,如有需求请联系QQ157164068
RGM resistance is to use metallic glass enamel coating on the top bar magnet, has excellent impact resistance characteristics and high temperature stability, heat dissipation is good, wide range of resistance at low prices, is widely used in high-power devices, is a new generation of surface mount circuit design the best choice.
UPR高精密电阻器系列,是用我司生产的EE1/10成品的高精密金属膜电阻器,经选配组装而成。具备EE系列电阻器高稳定/高精度/低温度系数的技术特性,满足EE系列电阻质量一致性检验项目的要求。技术特点:由于选配补偿效果,整体上具有更小的电阻值标称误差和温度系数,适用于精密电子仪器仪表的模拟电子线路。精密和高精密电阻,MELF晶圆电阻生产厂家,如有需求,请联系QQ157164068
执行企业标准Q/EBG003-2004,该标准主要参照国家军用标准GJB244A-2001及国家标准GB/T5729-1994;GB/T9546-1995;GB/T9547-1995的有关规定制定。
技术特点:无引线圆柱状外形、涂覆封装、色环标志、高精密、低温度系数。适用于有高精度要求的表面贴装(SMD)电子线路。
工作温度范围: -65~ +155
相关下载
明天我还来| | 2010-12-3 21:29 | 显示全部楼层
这是广告?
明天我还来| | 2010-12-22 22:38 | 显示全部楼层
:funk:
