[STM8]
一段奇葩的FLASH写入寿命测试程序,求批
1442|3
jcdzxh|  楼主 | 2017-6-21 17:43 | 显示全部楼层 |阅读模式
#asm
//        mov _FLASH_DUKR,#0xae
//        mov _FLASH_DUKR,#0x56
        mov _FLASH_PUKR,#0x56  //解锁FLASH
        mov _FLASH_PUKR,#0xae
  clr $20       //清计数器
  clr $21
  clr $22
main1:
        ldw y,sp
        ldw x,#$9fff  //写入高地址
        ldw sp,x
        mov _FLASH_CR2,#0x1;  //按页写入AAAA
        mov _FLASH_NCR2,#0xfe;
        ldw x,#$aaaa
        ld a,#32
        pushw x
        dec a
        jrne *-2
        btjt _FLASH_IAPSR,#6,*  //等开始写  =0 HV ON
        btjf _FLASH_IAPSR,#2,*  //等开始写  end of prog
        ld a,#32
testa:
        popw x
        cpw x,#$aaaa
        jrne err1
        dec a
        jrne testa
        mov _FLASH_CR2,#0x1;  //按页写入5555
        ldw x,#$5555
        ld a,#32
        pushw x
        dec a
        jrne *-2
        ld a,#32
test5:
        popw x
        cpw x,#$5555
        jrne err1
        dec a
        jrne test5
        inc 0x20
        jrne main1
        ldw sp,y
        ldw x,$21
        incw x
        ldw $21,x
        ld a,$21
        call _TxByte
        ld a,$22
        call _TxByte
        jra main1
        ldw sp,y    //串口输出256字节
        ldw x,#$9f00
        clr 40
LOOP:
        ld a,(x)
        call _TxByte
        incw x
        inc 40
        jrne LOOP
err1:          //错误陷阱  输出 00 00
        ldw sp,y  //恢复栈指针
        clr a
        call _TxByte
        call _TxByte
        jra *
#endasm
jcdzxh|  楼主 | 2017-6-21 17:44 | 显示全部楼层
RAM中跑的,等写报错
mmuuss586| | 2017-6-21 18:40 | 显示全部楼层
哦,测试这个干嘛啊
