DSP数字钟设计
2835|1
 楼主| 雨在雪中飘 发表于 2010-6-11 17:08 | 显示全部楼层 |阅读模式
我是一个普通的本科学生,主专业是通信工程
这个学科学了DSP芯片的原理与开发应用这门课
学起来还是比较吃力的
老师布置了一个设计数字时钟的作业,要求在液晶屏上显示6位的数字时钟
//  常量定义
#define LCDDELAY 1
#define LCDCMDTURNON 0x3f
#define LCDCMDTURNOFF 0x3e
#define LCDCMDSTARTLINE 0xc0
#define LCDCMDPAGE 0xb8
#define LCDCMDVERADDRESS 0x40
#define WAITSTATUS (*(unsigned int *)0x28)
//  CTR扩展寄存器定义
ioport unsigned int port8000;
ioport unsigned int port8001;
ioport unsigned int port8002;
ioport unsigned int port8003;
ioport unsigned int port8004;
ioport unsigned int port8005;
ioport unsigned int port8007;
#define CTRGR       port8000
#define CTRLCDCMDR  port8001
#define CTRKEY      port8001
#define CTRCLKEY    port8002
#define CTRLCDCR    port8002
#define CTRLCDLCR   port8003
#define CTRLCDRCR   port8004
#define CTRLA       port8005
#define CTRLR       port8007
void Delay(unsigned int nTime);  // 延时函数
void TurnOnLCD();           // 打开显示
void LCDCLS();            // 清除屏幕显示内容
unsigned char ledkey[10][8]=
{0x00,0x00,0x7C,0x82,0x82,0x82,0x7C,0x00}, //0
{0x00,0x00,0x00,0x84,0xFE,0x80,0x00,0x00}, //1
{0x00,0x00,0x84,0xC2,0xA2,0x92,0x8C,0x00}, //2
{0x00,0x00,0x44,0x92,0x92,0x92,0x6C,0x00},
{0x00,0x00,0x30,0x28,0x24,0xFE,0x20,0x00},
{0x00,0x00,0x4E,0x92,0x92,0x92,0x62,0x00},
{0x00,0x00,0x7C,0x92,0x92,0x92,0x64,0x00},
{0x00,0x00,0x02,0xC2,0x32,0x0A,0x06,0x00},
{0x00,0x00,0x6C,0x92,0x92,0x92,0x6C,0x00},
{0x00,0x00,0x4C,0x92,0x92,0x92,0x7C,0x00}
main()
int i,nCount=0,nBW=0;
CTRGR=0;  // 初始化ICETEK-CTR
CTRGR=0x80;
CTRGR=0;
CTRLR=0;   // 关闭东西方向的交通灯
CTRLR=0x40; // 关闭南北方向的交通灯
LCDCLS();    // 清除显示内存
CTRLCDCMDR=LCDCMDSTARTLINE;  // 设置显示起始行
CTRLCDCR=0;
for (;;)
  CTRLCDCMDR=LCDCMDPAGE;  // 设置操作页=0
  Delay(LCDDELAY);
  CTRLCDCR=0;
  Delay(LCDDELAY);
  CTRLCDCMDR=LCDCMDVERADDRESS; // 起始列=0
  Delay(LCDDELAY);
  CTRLCDCR=0;
  Delay(LCDDELAY);
  for ( i=0;i<8;i++ )
   CTRLCDLCR=( nBW==0 )?(ledkey[nCount][i]):(~ledkey[nCount][i]); // 屏幕左侧第1至8行第i列赋值       port8002=0;   // (赋值后当前操作列自动加1,所以不需设置)
   Delay(LCDDELAY);
   CTRLCDCR=0;
   Delay(LCDDELAY);
  Delay(512);
  nCount++;
  if ( nCount==10 )
   nCount=0;
   nBW=1-nBW;
void Delay(unsigned int nDelay)
int ii,jj,kk=0;
for ( ii=0;ii<nDelay;ii++ )
  for ( jj=0;jj<1024;jj++ )
   kk++;
void TurnOnLCD()
CTRLCDCMDR=LCDCMDTURNON;
Delay(LCDDELAY);
CTRLCDCR=0;
Delay(LCDDELAY);
Delay(LCDDELAY);
CTRLCDCR=0;
Delay(LCDDELAY);
void LCDCLS()
int i,j;
Delay(LCDDELAY);
CTRLCDCR=0;
Delay(LCDDELAY);
for ( i=0;i<8;i++ )
  CTRLCDCMDR=LCDCMDPAGE+i;
  Delay(LCDDELAY);
  CTRLCDCR=0;
  Delay(LCDDELAY);
  Delay(LCDDELAY);
  CTRLCDCR=0;
  Delay(LCDDELAY);
  for ( j=0;j<64;j++ )
   CTRLCDLCR=0;
   Delay(LCDDELAY);
   CTRLCDCR=0;
   Delay(LCDDELAY);
  Delay(LCDDELAY);
  CTRLCDCR=0;
  Delay(LCDDELAY);
  Delay(LCDDELAY);
  CTRLCDCR=0;
  Delay(LCDDELAY);
   CTRLCDRCR=0;
   Delay(LCDDELAY);
   CTRLCDCR=0;
   Delay(LCDDELAY);
以上是LCD的显示程序
然后是计时的程序
#define TIM  *(int *)0x24
#define PRD     *(int *)0x25
#define TCR  *(int *)0x26
#define IMR  *(int *)0x0
#define IFR  *(int *)0x1
#define PMST *(int *)0x1d
ioport unsigned int port3002,port3003;
#define DIP port3003
#define LED port3002
void interrupt time(void);
unsigned int nCount,uWork;
main()
nCount=uWork=0;
asm(" ssbx INTM"); // 关中断,进行关键设置时不许打扰
// 设置通用定时器
uWork=PMST;   // 设置PMST寄存器
PMST =uWork&0xff; // 中断向量表起始地址=80H
IMR = 0x8;   // 使能TINT
TCR = 0x41F;  // 预分频系数为8
TIM = 0;   // 时钟计数器清0
PRD = 0x0f423;  // 周期寄存器为0f423H
TCR = 0x42f;  // 复位、启动
IFR = 0x100;  // 清中断标志位
asm(" rsbx INTM"); // 开中断
LED=0xff;
while ( 1 )
nCount++;
if ( nCount>=4 )
    LED^=0x55;      // 设置指示灯状态
       nCount=0;
不知道怎么让着两个结合起来,在液晶屏上显示数字时钟,我是小白
期待高手解答!!
因为是刚注册的,所以没有积分,抱歉啦~~
