[技术问答]
新唐M0单片机NUC123系列看门狗复位标志WTRF的问题
1867|11
sunmoonsun|  楼主 | 2017-6-22 21:19 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
请教各位一个关于NUC123单片机看门狗的问题:
手册里说看门狗复位后复位标志WTRF会置位,且不会清零,用户可以手动向该位写一清零。 但是我在看门狗复位后,读取该位去做条件判断,从判断结果看是该位始终是0;
我使用的时库里自带的函数,并且在读之前解锁了位写保护,读完之后也在此上锁了写保护。折腾了好久了,就是读出的状态和手册里描述的不一致。如果哪位前辈有这方面的经验,希望不吝赐教!十分感激!谢谢
heisexingqisi| | 2017-6-22 22:05 | 只看该作者
* [url=home.php?mod=space&uid=288409]@file[/url]     main.c
* [url=home.php?mod=space&uid=895143]@version[/url]  V3.00
* $Revision: 7 $
* $Date: 15/09/14 4:22p $
* @brief
*           Demonstrate how to cause WDT time-out reset system event while WDT time-out reset delay period expired.
* @note
* Copyright (C) 2014~2015 Nuvoton Technology Corp. All rights reserved.
#include <stdio.h>
#include "NUC123.h"
#define HCLK_CLOCK           72000000
/* Global Interface Variables Declarations        */
volatile uint8_t g_u8IsWDTTimeoutINT = 0;
* [url=home.php?mod=space&uid=247401]@brief[/url]       IRQ Handler for WDT and WWDT Interrupt
* @param       None
* [url=home.php?mod=space&uid=266161]@return[/url]      None
* [url=home.php?mod=space&uid=1543424]@Details[/url]     The WDT_IRQHandler is default IRQ of WDT and WWDT, declared in startup_NUC123.s.
void WDT_IRQHandler(void)
    if(WDT_GET_TIMEOUT_INT_FLAG() == 1)
        /* Clear WDT time-out interrupt flag */
        WDT_CLEAR_TIMEOUT_INT_FLAG();
        g_u8IsWDTTimeoutINT = 1;
        printf("WDT time-out interrupt occurred.\n");
void SYS_Init(void)
    /* Init System Clock        */
    /* Enable IRC22M clock */
    CLK_EnableXtalRC(CLK_PWRCON_OSC22M_EN_Msk);
    /* Waiting for IRC22M clock ready */
    CLK_WaitClockReady(CLK_CLKSTATUS_OSC22M_STB_Msk);
    /* Switch HCLK clock source to HIRC */
    CLK_SetHCLK(CLK_CLKSEL0_HCLK_S_HIRC, CLK_CLKDIV_HCLK(1));
    /* Enable XT1_OUT(PF.0) and XT1_IN(PF.1) */
    SYS->GPF_MFP |= SYS_GPF_MFP_PF0_XT1_OUT | SYS_GPF_MFP_PF1_XT1_IN;
    /* Enable external 12 MHz XTAL, IRC10K */
    CLK_EnableXtalRC(CLK_PWRCON_XTL12M_EN_Msk | CLK_PWRCON_OSC10K_EN_Msk);
    /* Waiting for clock ready */
    while(!CLK_WaitClockReady(CLK_CLKSTATUS_XTL12M_STB_Msk | CLK_CLKSTATUS_OSC10K_STB_Msk));
    /* Set core clock as HCLK_CLOCK */
    CLK_SetCoreClock(HCLK_CLOCK);
    /* Enable peripheral clock */
    CLK_EnableModuleClock(UART0_MODULE);
    CLK_EnableModuleClock(WDT_MODULE);
    /* Peripheral clock source */
    CLK_SetModuleClock(UART0_MODULE, CLK_CLKSEL1_UART_S_PLL, CLK_CLKDIV_UART(1));
    CLK_SetModuleClock(WDT_MODULE, CLK_CLKSEL1_WDT_S_LIRC, 0);
    /* Init I/O Multi-function        */
    /* Set PB multi-function pins for UART0 RXD, TXD */
    SYS->GPB_MFP = SYS_GPB_MFP_PB0_UART0_RXD | SYS_GPB_MFP_PB1_UART0_TXD;
void UART0_Init(void)
    /* Init UART        */
    /* Reset IP */
    SYS_ResetModule(UART0_RST);
    /* Configure UART0 and set UART0 Baudrate */
    UART_Open(UART0, 115200);
/*  MAIN function        */
int main(void)
    /* Unlock protected registers */
    SYS_UnlockReg();
    /* Init System, peripheral clock and multi-function I/O */
    SYS_Init();
    /* Lock protected registers */
    SYS_LockReg();
    /* Init UART0 for printf */
    UART0_Init();
    if(WDT_GET_RESET_FLAG() == 1)
        /* Use PA.10 to check time-out period time */
        GPIO_SetMode(PA, BIT10, GPIO_PMD_OUTPUT);
        PA10 = 1;
        WDT_CLEAR_RESET_FLAG();
        printf("\n\n*** WDT time-out reset occurred ***\n");
        while(1);
    printf("\n\nCPU [url=home.php?mod=space&uid=72445]@[/url] %d Hz\n", SystemCoreClock);
    printf("+--------------------------------------+\n");
    printf("|    WDT Time-out Reset Sample Code    |\n");
    printf("+--------------------------------------+\n\n");
    printf("# WDT Settings:\n");
    printf("  Clock source is 10 kHz; Enable interrupt; Time-out interval is 2^14 * WDT clock.\n");
    printf("# When WDT start counting, system will generate a WDT time-out interrupt after around 1.6384 s.\n");
    printf("  Measure PA.10 low period to check time-out interval and do not reload WDT counter will cause system reset.\n\n");
    PA10 = 1;
    PA10 = 0;
    /* Because of all bits can be written in WDT Control Register are write-protected;
       To program it needs to disable register protection first. */
    SYS_UnlockReg();
    /* Enable WDT time-out reset function and select time-out interval to 2^14 * WDT clock then start WDT counting */
    WDT_Open(WDT_TIMEOUT_2POW14, WDT_RESET_DELAY_1026CLK, TRUE, FALSE);
    /* Enable WDT interrupt function */
    WDT_EnableInt();
    /* Enable WDT NVIC */
    NVIC_EnableIRQ(WDT_IRQn);
    while(1);
/*** (C) COPYRIGHT 2014~2015 Nuvoton Technology Corp. ***/
看看这个例程是你要的那个吗
sunmoonsun|  楼主 | 2017-6-22 22:08 | 只看该作者
116.    if(WDT_GET_RESET_FLAG() == 1)
117.    {
sunmoonsun|  楼主 | 2017-6-22 22:15 | 只看该作者
heisexingqisi 发表于 2017-6-22 22:05
看看这个例程是你要的那个吗
117.    {
非常感谢您的回答,我没有用到复位中断和串口这些东西,我的程序是在处理一个射频RF接收,多次接收未果之后调到一个复位函数里,启动看门狗复位,启动看门狗计数,进入一个死循环,等着系统复位。复位以后,程序正常运行,这时候来读取WTRF,如果读出值是1,液晶屏就显示A内容,如果读出值是0,就显示B内容。但是复位后我读出来不是1.
您给的例程代码我也找不出来我的读不出1的原因啊,如果您知道是哪儿的问题,麻烦给个思路!谢谢!
玛尼玛尼哄| | 2017-6-23 07:53 | 只看该作者
你先单独写个看门狗超时复位的程序,在主程序里面判断是否发生了看门狗复位,试试可以实现不
玛尼玛尼哄| | 2017-6-23 07:57 | 只看该作者
#define WDT_GET_RESET_FLAG()            ((WDT->WTCR & WDT_WTCR_WTRF_Msk)? 1 : 0)
  * @brief      Get WDT Time-out Interrupt Flag
  * @param      None
  * @retval     0   WDT time-out interrupt did not occur
  * @retval     1   WDT time-out interrupt occurred
  * @Details    This macro indicate WDT time-out interrupt occurred or not.
库函数里面好像就是用的这个实现的。
sunmoonsun|  楼主 | 2017-6-23 09:32 | 只看该作者
好,我先写个简单的程序测试一下吧。
库函数是这个,在WDT.h里
* @brief      Get WDT Timeout Reset Flag
* @param[in]  None
* @retval     1 = Watchdog timer reset occurred
* @retval     0 = Watchdog timer reset did not occur
* @Details    Get WDT Timeout Reset Flag.
*             Example: WDT_GET_RESET_FLAG()
static __INLINE uint32_t WDT_GET_RESET_FLAG(void)
    return ((WDT->WTCR) & WDT_WTCR_WTRF);
我的程序框架是这样的
int main(void)
    变量定义、赋初值;
    各种初始化,包括看门狗初始化;
    if( WDT_GET_RESET_FLAG() ==1 )
       语句1;
    else
       语句2;
    标号:
    if(条件C)
       使能看门狗复位;
       看门狗计数开始;
       while(1);      //等待看门狗复位
    while(1)
       while(条件B)
         if(条件A)
           条件C = 1;
           goto  标号;
执行结果是,上电及看门狗复位后一直执行语句2,语句1从来都不执行。
zhuomuniao110| | 2017-6-23 09:36 | 只看该作者
别用goto....切记。。。
sunmoonsun|  楼主 | 2017-6-23 09:47 | 只看该作者
zhuomuniao110 发表于 2017-6-23 09:36
别用goto....切记。。。
我也是没办法才用的goto,因为涉及到无线通信,并且供电也是无线,使用环境还比较恶劣,不得已就用goto了。
不过这个goto好像没有搞乱程序,因为之前没有用看门狗复位,程序在条件满足时也会运行至标号部分,程序运行一直很正常。
sunmoonsun|  楼主 | 2017-6-23 11:26 | 只看该作者
大家有没有用过看门狗复位标志WTRF来判断复位源,指导一下!3Q!
sunmoonsun|  楼主 | 2017-6-23 17:59 | 只看该作者
自己顶一下,大家帮帮忙!
