[DemoCode下载]
NUC123串口唤醒
906|7
玛尼玛尼哄|  楼主 | 2017-6-23 08:00 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
* [url=home.php?mod=space&uid=288409]@file[/url]     main.c
* [url=home.php?mod=space&uid=895143]@version[/url]  V3.00
* $Revision: 3 $
* $Date: 15/07/02 3:13p $
* @brief
*           Show how to wake up system form Power-down mode by UART interrupt.
* @note
* Copyright (C) 2014~2015 Nuvoton Technology Corp. All rights reserved.
#include <stdio.h>
#include "NUC123.h"
#define HCLK_CLOCK  72000000
/* Define functions prototype        */
int32_t main(void);
void UART_CTSWakeUpTest(void);
/* ISR to handle UART Channel 1 interrupt event                                                            */
void UART1_IRQHandler(void)
    if(UART_GET_INT_FLAG(UART1, UART_ISR_MODEM_INT_Msk))    /* UART Modem Status interrupt flag */
        printf("UART Modem Status interrupt happen.");
        UART_ClearIntFlag(UART1, UART_ISR_MODEM_INT_Msk);   /* Clear UART Modem Status interrupt flag */
/*  Function for System Entry to Power Down Mode                                                           */
void PowerDownFunction(void)
    /* Check if all the debug messages are finished */
    UART_WAIT_TX_EMPTY(UART0);
    /* Enter to Power-down mode */
    CLK_PowerDown();
/*  UART nCTS Wake-up Function        */
    printf("+----------------------------------------------------------+\n");
    printf("|   Power-Down and Wake-up by UART interrupt Sample Code   |\n");
    printf("+----------------------------------------------------------+\n\n");
    /* Clear Modem Status interrupt before entering Power-down mode */
    /* Enable UART Wake-up function and Modem Status interrupt */
    UART_EnableInt(UART1, UART_IER_WAKE_EN_Msk|UART_IER_MODEM_IEN_Msk);
    printf("System enter to Power-down mode.\n");
    printf("Toggle nCTS of UART1 to wake-up system.\n\n");
    /* Unlock protected registers before entering Power-down mode */
    SYS_UnlockReg();
    PowerDownFunction();
    /* Lock protected registers after entering Power-down mode */
    SYS_LockReg();
    /* Disable UART Wake-up function and Modem Status interrupt */
    UART_DisableInt(UART1, UART_IER_WAKE_EN_Msk|UART_IER_MODEM_IEN_Msk);
    printf("\nSystem waken-up done.\n");
    printf("\nUART Sample Program End.\n");
void SYS_Init(void)
    /* Init System Clock        */
    /* Enable XT1_OUT(PF0) and XT1_IN(PF1) */
    SYS->GPF_MFP |= SYS_GPF_MFP_PF0_XT1_OUT | SYS_GPF_MFP_PF1_XT1_IN;
    /* Enable Internal RC 22.1184MHz clock */
    CLK_EnableXtalRC(CLK_PWRCON_OSC22M_EN_Msk);
    /* Waiting for Internal RC clock ready */
    CLK_WaitClockReady(CLK_CLKSTATUS_OSC22M_STB_Msk);
    /* Switch HCLK clock source to Internal RC and HCLK source divide 1 */
    CLK_SetHCLK(CLK_CLKSEL0_HCLK_S_HIRC, CLK_CLKDIV_HCLK(1));
    /* Enable external XTAL 12MHz clock */
    CLK_EnableXtalRC(CLK_PWRCON_XTL12M_EN_Msk);
    /* Waiting for external XTAL clock ready */
    CLK_WaitClockReady(CLK_CLKSTATUS_XTL12M_STB_Msk);
    /* Set core clock as HCLK_CLOCK */
    CLK_SetCoreClock(HCLK_CLOCK);
    /* Enable UART module clock */
    CLK_EnableModuleClock(UART0_MODULE);
    CLK_EnableModuleClock(UART1_MODULE);
    /* Select UART module clock source */
    CLK_SetModuleClock(UART0_MODULE, CLK_CLKSEL1_UART_S_HXT, CLK_CLKDIV_UART(1));
    CLK_SetModuleClock(UART1_MODULE, CLK_CLKSEL1_UART_S_HXT, CLK_CLKDIV_UART(1));
    /* Init I/O Multi-function        */
    /* Set GPB multi-function pins for UART0 RXD(PB.0) and TXD(PB.1) */
    /* Set GPB multi-function pins for UART1 RXD(PB.4), TXD(PB.5) and nCTS(PB.7) */
    SYS->GPB_MFP &= ~(SYS_GPB_MFP_PB0_Msk | SYS_GPB_MFP_PB1_Msk |
                      SYS_GPB_MFP_PB4_Msk | SYS_GPB_MFP_PB5_Msk | SYS_GPB_MFP_PB7_Msk);
    SYS->GPB_MFP |= (SYS_GPB_MFP_PB0_UART0_RXD | SYS_GPB_MFP_PB1_UART0_TXD |
                     SYS_GPB_MFP_PB4_UART1_RXD | SYS_GPB_MFP_PB5_UART1_TXD | SYS_GPB_MFP_PB7_UART1_nCTS);
    SYS->ALT_MFP &= ~(SYS_ALT_MFP_PB4_Msk | SYS_ALT_MFP_PB5_Msk | SYS_ALT_MFP_PB7_Msk);
    SYS->ALT_MFP |= (SYS_ALT_MFP_PB4_UART1_RXD | SYS_ALT_MFP_PB5_UART1_TXD | SYS_ALT_MFP_PB7_UART1_nCTS);
void UART0_Init()
    /* Init UART        */
    /* Reset UART0 */
    SYS_ResetModule(UART0_RST);
    /* Configure UART0 and set UART0 Baudrate */
    UART_Open(UART0, 115200);
void UART1_Init()
    /* Init UART        */
    /* Reset UART1 */
    SYS_ResetModule(UART1_RST);
    /* Configure UART1 and set UART1 Baudrate */
    UART_Open(UART1, 115200);
/* MAIN function        */
int main(void)
    /* Unlock protected registers */
    SYS_UnlockReg();
    /* Init System, peripheral clock and multi-function I/O */
    SYS_Init();
    /* Lock protected registers */
    SYS_LockReg();
    /* Init UART0 for printf */
    UART0_Init();
    /* Init UART1 for testing */
    UART1_Init();
    /* SAMPLE CODE        */
    printf("\n\nCPU [url=home.php?mod=space&uid=72445]@[/url] %dHz\n", SystemCoreClock);
    printf("\n\nUART Sample Program.\n");
    /* UART wake-up sample function */
    UART_CTSWakeUpTest();
    while(1);
玛尼玛尼哄|  楼主 | 2017-6-23 08:01 | 只看该作者
    SYS_UnlockReg();
    SYS_LockReg();
玛尼玛尼哄|  楼主 | 2017-6-23 08:02 | 只看该作者
其实很简单就实现了,比较给力。
yiyigirl2014| | 2017-6-23 15:39 | 只看该作者
串口中断唤醒。
598330983| | 2017-6-24 12:07 | 只看该作者
读取和清理都是一一对应的。
598330983| | 2017-6-24 12:08 | 只看该作者
读取和清理都是一一对应的。
dongnanxibei| | 2017-6-25 15:49 | 只看该作者
原来也不是很难啊。
zhuotuzi| | 2017-6-25 16:20 | 只看该作者
每种中断其实都不难,特别是用库函数操作。
