编译时出现如下代码
375|10
pangb|  楼主 | 2017-6-30 23:21 | 显示全部楼层 |阅读模式
PSoC Designer 软件上,用了颗CY8C20434芯片(所以软件选型上也选择了CY8C2043)
当只加了定时器模块和Cap Sensors模块,并设了2个Cap Button和一个Slider(五个触点)
编译时出现如下代码
Linking..
LMM info: area 'InterruptRAM' uses 72 bytes in SRAM bank 0
LMM info: area 'ram2' item of 57 bytes allocated in SRAM page 0
LMM info: area 'ram1' item of 56 bytes allocated in SRAM page 0
LMM info: area 'ram0' item of 42 bytes allocated in SRAM page 0
LMM info: area 'bss' item of 7 bytes allocated in SRAM page 0
LMM info: area 'bss' item of 6 bytes allocated in SRAM page 0
LMM info: area 'virtual_registers' uses 2 bytes in SRAM page 0
  ROM 36% full. 2942 out of 8192 bytes used (does not include absolute areas).
  RAM 95% full. 242 bytes used (does not include stack usage).
idata dump at output/TR109A.idata
Built with ICCM8C STD V7.04
HY101A - 0 error(s) 0 warning(s) 22:56:20
chenjunt| | 2017-6-30 23:22 | 显示全部楼层
还有什么吗?
pangb|  楼主 | 2017-6-30 23:24 | 显示全部楼层
当只加了定时器模块和Cap Sensors模块,并设了3个Cap Button和一个Slider(五个触点)
编译时出现如下代码
Linking..
LMM info: area 'ram2' item of 65 bytes allocated in SRAM page 0
LMM info: area 'ram1' item of 64 bytes allocated in SRAM page 0
LMM info: area 'ram0' item of 48 bytes allocated in SRAM page 0
!E <library>(2385): {linker} Cannot allocate space for 8 bytes for 'bss' area
!E <library>(2385): {linker} Cannot allocate space for paged area 'virtual_registers'
d:\PROGRA~1\Cypress\PSOCDE~1\5.1\Common\CYPRES~3\tools\make: *** [output/TR109A.rom] Error 1
HY101A - 3 error(s) 0 warning(s) 23:01:09
ousj| | 2017-6-30 23:26 | 显示全部楼层
没看手册吗?
pangb|  楼主 | 2017-6-30 23:27 | 显示全部楼层
根据手册CY8C20434应该是有512个Byte的RAM的
从上面分析可以看出,编译器只认到了256个Byte的RAM吗?
morrisk| | 2017-6-30 23:29 | 显示全部楼层
超过了256个Byte就已经报错了?
pangb|  楼主 | 2017-6-30 23:30 | 显示全部楼层
是编译器设置问题吗?
zyf部长| | 2017-6-30 23:31 | 显示全部楼层
肯定不是规格书有错
kangzj| | 2017-6-30 23:33 | 显示全部楼层
不知道了。。。
zwll| | 2017-6-30 23:34 | 显示全部楼层
这个问题可以参照这里解决:
http://www.cypress.com/?id=4&rID=40001
pangb|  楼主 | 2017-6-30 23:35 | 显示全部楼层
嗯,预料中的结果,先结贴吧,多谢大家啦
