[DemoCode下载]
M051串口使用例程序
812|3
heisexingqisi|  楼主 | 2017-7-8 20:03 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
* [url=home.php?mod=space&uid=288409]@file[/url]     main.c
* [url=home.php?mod=space&uid=895143]@version[/url]  V1.00
* $Revision: 7 $
* $Date: 14/01/28 11:45a $
* [url=home.php?mod=space&uid=247401]@brief[/url]    M051 Series UART Interface Controller Driver Sample Code
* @note
* Copyright (C) 2011 Nuvoton Technology Corp. All rights reserved.
#include <stdio.h>
#include "M051Series.h"
#define PLL_CLOCK           50000000
#define RXBUFSIZE 1024
/* Define functions prototype        */
extern char GetChar(void);
int32_t main(void);
void AutoFlow_FunctionTxTest(void);
void SYS_Init(void)
    /* Init System Clock        */
    /* Enable Internal RC 22.1184MHz clock */
    CLK_EnableXtalRC(CLK_PWRCON_OSC22M_EN_Msk);
    /* Waiting for Internal RC clock ready */
    CLK_WaitClockReady(CLK_CLKSTATUS_OSC22M_STB_Msk);
    /* Switch HCLK clock source to Internal RC and HCLK source divide 1 */
    CLK_SetHCLK(CLK_CLKSEL0_HCLK_S_HIRC, CLK_CLKDIV_HCLK(1));
    /* Enable external XTAL 12MHz clock */
    CLK_EnableXtalRC(CLK_PWRCON_XTL12M_EN_Msk);
    /* Waiting for external XTAL clock ready */
    CLK_WaitClockReady(CLK_CLKSTATUS_XTL12M_STB_Msk);
    /* Set core clock as PLL_CLOCK from PLL */
    CLK_SetCoreClock(PLL_CLOCK);
    /* Enable UART module clock */
    CLK_EnableModuleClock(UART0_MODULE);
    CLK_EnableModuleClock(UART1_MODULE);
    /* Select UART module clock source */
    CLK_SetModuleClock(UART0_MODULE, CLK_CLKSEL1_UART_S_HXT, CLK_CLKDIV_UART(1));
    CLK_SetModuleClock(UART1_MODULE, CLK_CLKSEL1_UART_S_HXT, CLK_CLKDIV_UART(1));
    /* Init I/O Multi-function        */
    /* Set P3 multi-function pins for UART0 RXD and TXD */
    SYS->P3_MFP &= ~(SYS_MFP_P30_Msk | SYS_MFP_P31_Msk);
    SYS->P3_MFP |= (SYS_MFP_P30_RXD0 | SYS_MFP_P31_TXD0);
    /* Set P1 multi-function pins for UART1 RXD and TXD */
    SYS->P1_MFP &= ~(SYS_MFP_P12_Msk | SYS_MFP_P13_Msk);
    SYS->P1_MFP |= (SYS_MFP_P12_RXD1 | SYS_MFP_P13_TXD1);
    /* Set P0 multi-function pins for UART1 CTS */
    SYS->P0_MFP = SYS->P0_MFP & (~SYS_MFP_P00_Msk) | SYS_MFP_P00_CTS1;
void UART0_Init()
    /* Init UART        */
    /* Reset UART0 module */
    SYS_ResetModule(UART0_RST);
    /* Configure UART0 and set UART0 Baudrate */
    UART_Open(UART0, 115200);
void UART1_Init()
    /* Init UART        */
    /* Reset UART1 module */
    SYS_ResetModule(UART1_RST);
    /* Configure UART1 and set UART1 Baudrate */
    UART_Open(UART1, 115200);
/* MAIN function        */
int main(void)
    /* Unlock protected registers */
    SYS_UnlockReg();
    /* Init System, IP clock and multi-function I/O */
    SYS_Init();
    /* Lock protected registers */
    SYS_LockReg();
    /* Init UART0 for printf */
    UART0_Init();
    /* Init UART1 for testing */
    UART1_Init();
    /* SAMPLE CODE        */
    printf("\n\nCPU [url=home.php?mod=space&uid=72445]@[/url] %dHz\n", SystemCoreClock);
    printf("\n\nUART Sample Program\n");
    /* UART auto flow sample master function */
    AutoFlow_FunctionTxTest();
    while(1);
/*  AutoFlow Function Tx Test        */
void AutoFlow_FunctionTxTest()
    uint32_t u32i;
    printf("\n");
    printf("+-----------------------------------------------------------+\n");
    printf("|     Pin Configure                                         |\n");
    printf("|    _______                                    _______     |\n");
    printf("|   |       |                                  |       |    |\n");
    printf("|   |Master |---TXD1(P1.3) <====> RXD1(P1.2)---| Slave |    |\n");
    printf("|   |       |---CTS1(P0.0) <====> RTS1(P0.1)---|       |    |\n");
    printf("|   |_______|                                  |_______|    |\n");
    printf("|                                                           |\n");
    printf("\n");
    printf("|       AutoFlow Function Test (Master)                     |\n");
    printf("|  Description :                                            |\n");
    printf("|    The sample code needs two boards. One is Master and    |\n");
    printf("|    the other is slave. Master will send 1k bytes data     |\n");
    printf("|    to slave.Slave will check if received data is correct  |\n");
    printf("|    after getting 1k bytes data.                           |\n");
    printf("|    Press any key to start...                              |\n");
    GetChar();
    /* Enable RTS and CTS autoflow control */
    UART_EnableFlowCtrl(UART1);
    /* Send 1k bytes data */
    for(u32i = 0; u32i < RXBUFSIZE; u32i++)
        /* Send 1 byte data */
        UART_WRITE(UART1, u32i & 0xFF);
        /* Wait if Tx FIFO is full */
        while(UART_IS_TX_FULL(UART1));
    printf("\n Transmit Done\n");
heisexingqisi|  楼主 | 2017-7-8 20:04 | 只看该作者
* @file     main.c
* @version  V1.00
* $Revision: 8 $
* @brief    M051 Series UART Interface Controller Driver Sample Code
* @note
#include <stdio.h>
/* Global variables        */
uint8_t g_u8SendData[12] = {0};
uint8_t g_u8RecData[RXBUFSIZE]  = {0};
volatile int32_t g_i32pointer = 0;
int32_t main(void);
void AutoFlow_FunctionRxTest(void);
void SYS_Init(void)
    /* Set P0 multi-function pins for UART1 RTS */
    SYS->P0_MFP = SYS->P0_MFP & (~SYS_MFP_P01_Msk) | SYS_MFP_P01_RTS1;
void UART0_Init()
    /* Init UART        */
void UART1_Init()
    /* Init UART        */
/* MAIN function        */
int main(void)
    SYS_UnlockReg();
    SYS_Init();
    SYS_LockReg();
    UART0_Init();
    UART1_Init();
    /* SAMPLE CODE        */
    printf("\n\nCPU @ %dHz\n", SystemCoreClock);
    /* UART auto flow sample slave function */
    AutoFlow_FunctionRxTest();
    while(1);
/* ISR to handle UART Channel 1 interrupt event                                                            */
void UART1_IRQHandler(void)
    volatile uint32_t u32IntSts = UART1->ISR;;
    /* Rx Ready or Time-out INT*/
    if(UART_GET_INT_FLAG(UART1, UART_ISR_RDA_INT_Msk) ||  UART_GET_INT_FLAG(UART1, UART_ISR_TOUT_INT_Msk))
        /* Handle received data */
        g_u8RecData[g_i32pointer] = UART_READ(UART1);
        g_i32pointer++;
/*  AutoFlow Function Test (Slave)        */
void AutoFlow_FunctionRxTest()
    uint32_t u32i;
    printf("\n");
    printf("|                                                           |\n");
    printf("\n");
    printf("|       AutoFlow Function Test (Slave)                      |\n");
    GetChar();
    /* Set RTS Trigger Level as 8 bytes */
    UART1->FCR &= ~UART_FCR_RTS_TRI_LEV_Msk;
    UART1->FCR |= UART_FCR_RTS_TRI_LEV_8BYTES;
    /* Enable RDA\RLS\RTO Interrupt  */
    UART_ENABLE_INT(UART1, (UART_IER_RDA_IEN_Msk | UART_IER_RLS_IEN_Msk | UART_IER_RTO_IEN_Msk));
    /* Set RX Trigger Level as 8 bytes */
    UART1->FCR &= ~UART_FCR_RFITL_Msk;
    UART1->FCR |= UART_FCR_RFITL_8BYTES;
    /* Set Timeout time 0x3E bit-time and time-out counter enable */
    UART_SetTimeoutCnt(UART1, 0x3E);
    /* Enable UART1 IRQ */
    NVIC_EnableIRQ(UART1_IRQn);
    printf("\n Starting to receive data...\n");
    /* Wait for receive 1k bytes data */
    while(g_i32pointer < RXBUFSIZE);
    /* Compare Data */
        if(g_u8RecData[u32i] != (u32i & 0xFF))
            printf("Compare Data Failed\n");
            while(1);
    printf("\n Receive OK & Check OK\n");
    /* Disable UART1 IRQ */
    NVIC_DisableIRQ(UART1_IRQn);
    /* Disable RDA\RLS\RTO Interrupt */
    UART_DISABLE_INT(UART1, (UART_IER_RDA_IEN_Msk | UART_IER_RLS_IEN_Msk | UART_IER_RTO_IEN_Msk));
heisexingqisi|  楼主 | 2017-7-8 20:27 | 只看该作者
* @file     main.c
* @version  V1.00
* $Revision: 5 $
* @note
#include <stdio.h>
int32_t main(void);
void IrDA_FunctionTxTest(void);
/*  IrDA Function Transmit Test        */
void IrDA_FunctionTxTest()
    uint8_t u8OutChar;
    printf("\n");
    printf("|     ______                                    _______     |\n");
    printf("|    |Master|---TXD1(P1.3) <====> RXD1(P1.2)---|Slave  |    |\n");
    printf("|    |______|                                  |_______|    |\n");
    printf("|                                                           |\n");
    printf("\n");
    printf("|     IrDA Function Test                                    |\n");
    printf("|    the other is slave.  Master will send data based on    |\n");
    printf("|    terminal input and Slave will printf received data on  |\n");
    printf("|    terminal screen.                                       |\n");
        UART0 is set to debug port and connect with PC firstly.
        The IrDA sample code needs two module board to execute.
        Set the master board is IrDA TX Mode and the other is IrDA Rx mode.
        Inputing char on terminal will be sent to the UART0 of master.
        After the master receiving, the inputing char will send to UART0 again.
        At the same time, it also sends to UART1 TX pin by IrDA mode.
        Slave will print received char after UART1 send out.
        Note that IrDA mode is ONLY used when baud rate equation is selected mode 0.
    printf("\n");
    printf("|     IrDA Function Mode Test (Master)                      |\n");
    printf("| 1). Input char by UART0 terminal.                         |\n");
    printf("| 2). UART1 will send a char according to step 1.           |\n");
    printf("| 3). Return step 1. (Press '0' to exit)                    |\n");
    printf("\nIRDA Sample Code Start. \n");
    /* Set IrDA Tx Mode, Baud Rate configuration must be used MODE0 */
    UART_SelectIrDAMode(UART1, 57600, UART_IRCR_TX_SELECT);
    /* Wait Terminal input to send data to UART1 TX pin */
    do
        u8OutChar = GetChar();
        printf("   Input: %c , Send %c out\n", u8OutChar, u8OutChar);
        UART_WRITE(UART1, u8OutChar);
    while(u8OutChar != '0');
    printf("\nIrDA Sample Code End.\n");
void SYS_Init(void)
void UART0_Init()
    /* Init UART        */
void UART1_Init()
    /* Init UART        */
/* MAIN function        */
int main(void)
    SYS_UnlockReg();
    SYS_Init();
    SYS_LockReg();
    UART0_Init();
    UART1_Init();
    /* SAMPLE CODE        */
    /* UART sample IrDA Master function */
    IrDA_FunctionTxTest();
zhuomuniao110| | 2017-7-8 22:28 | 只看该作者
串口看着简单,用好了,需要下功夫。
