[DemoCode下载]
M051串口发送接收
1072|1
zhuotuzi|  楼主 | 2017-7-8 23:17 | 显示全部楼层 |阅读模式
* [url=home.php?mod=space&uid=288409]@file[/url]     main.c
* [url=home.php?mod=space&uid=895143]@version[/url]  V1.00
* $Revision: 4 $
* $Date: 14/04/03 9:28a $
* [url=home.php?mod=space&uid=247401]@brief[/url]    M051 Series UART Interface Controller Driver Sample Code
* @note
* Copyright (C) 2011 Nuvoton Technology Corp. All rights reserved.
#include <stdio.h>
#include "M051Series.h"
#define PLLCON_SETTING  CLK_PLLCON_50MHz_HXT
#define PLL_CLOCK           50000000
#define RXBUFSIZE 1024
/* Global variables        */
uint8_t g_u8RecData[RXBUFSIZE]  = {0};
volatile uint32_t g_u32comRbytes = 0;
volatile uint32_t g_u32comRhead  = 0;
volatile uint32_t g_u32comRtail  = 0;
volatile int32_t g_bWait         = TRUE;
/* Define functions prototype        */
int32_t main(void);
void UART_TEST_HANDLE(void);
void UART_FunctionTest(void);
void SYS_Init(void)
    /* Init System Clock        */
    /* Enable Internal RC 22.1184MHz clock */
    CLK->PWRCON |= CLK_PWRCON_OSC22M_EN_Msk;
    /* Waiting for Internal RC clock ready */
    while(!(CLK->CLKSTATUS & CLK_CLKSTATUS_OSC22M_STB_Msk));
    /* Switch HCLK clock source to Internal RC and and HCLK source divide 1 */
    CLK->CLKSEL0 &= ~CLK_CLKSEL0_HCLK_S_Msk;
    CLK->CLKSEL0 |= CLK_CLKSEL0_HCLK_S_HIRC;
    CLK->CLKDIV &= ~CLK_CLKDIV_HCLK_N_Msk;
    CLK->CLKDIV |= CLK_CLKDIV_HCLK(1);
    /* Enable external XTAL 12MHz clock */
    CLK->PWRCON |= CLK_PWRCON_XTL12M_EN_Msk;
    /* Waiting for external XTAL clock ready */
    while(!(CLK->CLKSTATUS & CLK_CLKSTATUS_XTL12M_STB_Msk));
    /* Set core clock as PLL_CLOCK from PLL */
    CLK->PLLCON = PLLCON_SETTING;
    while(!(CLK->CLKSTATUS & CLK_CLKSTATUS_PLL_STB_Msk));
    CLK->CLKSEL0 &= (~CLK_CLKSEL0_HCLK_S_Msk);
    CLK->CLKSEL0 |= CLK_CLKSEL0_HCLK_S_PLL;
    /* Update System Core Clock */
    /* User can use SystemCoreClockUpdate() to calculate PllClock, SystemCoreClock and CycylesPerUs automatically. */
    //SystemCoreClockUpdate();
    PllClock        = PLL_CLOCK;            // PLL
    SystemCoreClock = PLL_CLOCK / 1;        // HCLK
    CyclesPerUs     = PLL_CLOCK / 1000000;  // For SYS_SysTickDelay()
    /* Enable UART module clock */
    CLK->APBCLK |= CLK_APBCLK_UART0_EN_Msk;
    /* Select UART module clock source */
    CLK->CLKSEL1 &= ~CLK_CLKSEL1_UART_S_Msk;
    CLK->CLKSEL1 |= CLK_CLKSEL1_UART_S_HXT;
    /* Init I/O Multi-function        */
    /* Set P3 multi-function pins for UART0 RXD and TXD */
    SYS->P3_MFP &= ~(SYS_MFP_P30_Msk | SYS_MFP_P31_Msk);
    SYS->P3_MFP |= (SYS_MFP_P30_RXD0 | SYS_MFP_P31_TXD0);
void UART0_Init()
    /* Init UART        */
    /* Reset UART IP */
    SYS->IPRSTC2 |=  SYS_IPRSTC2_UART0_RST_Msk;
    SYS->IPRSTC2 &= ~SYS_IPRSTC2_UART0_RST_Msk;
    /* Configure UART0 and set UART0 Baudrate */
    UART0->BAUD = UART_BAUD_MODE2 | UART_BAUD_MODE2_DIVIDER(__HXT, 115200);
    UART0->LCR = UART_WORD_LEN_8 | UART_PARITY_NONE | UART_STOP_BIT_1;
void UART1_Init()
    /* Init UART        */
    /* Reset UART IP */
    SYS->IPRSTC2 |=  SYS_IPRSTC2_UART1_RST_Msk;
    SYS->IPRSTC2 &= ~SYS_IPRSTC2_UART1_RST_Msk;
    /* Configure UART1 and set UART1 Baudrate */
    UART1->BAUD = UART_BAUD_MODE2 | UART_BAUD_MODE2_DIVIDER(__HXT, 115200);
    UART1->LCR = UART_WORD_LEN_8 | UART_PARITY_NONE | UART_STOP_BIT_1;
/* UART Test Sample        */
/* Test Item        */
/* It sends the received data to HyperTerminal.                                                            */
/* MAIN function        */
int main(void)
    /* Unlock protected registers */
    SYS_UnlockReg();
    /* Init System, IP clock and multi-function I/O */
    SYS_Init();
    /* Lock protected registers */
    SYS_LockReg();
    /* Init UART0 for printf and testing */
    UART0_Init();
    /* SAMPLE CODE        */
    printf("\n\nCPU [url=home.php?mod=space&uid=72445]@[/url] %dHz\n", SystemCoreClock);
    printf("\n\nUART Sample Program\n");
    /* UART sample function */
    UART_FunctionTest();
/* ISR to handle UART Channel 0 interrupt event                                                            */
void UART0_IRQHandler(void)
    UART_TEST_HANDLE();
/* UART Callback function        */
void UART_TEST_HANDLE()
    uint8_t u8InChar = 0xFF;
    uint32_t u32IntSts = UART0->ISR;
    if(u32IntSts & UART_ISR_RDA_INT_Msk)
        printf("\nInput:");
        /* Get all the input characters */
        while(UART0->ISR & UART_ISR_RDA_IF_Msk)
            /* Get the character from UART Buffer */
            u8InChar = UART0->RBR;
            printf("%c ", u8InChar);
            if(u8InChar == '0')
                g_bWait = FALSE;
            /* Check if buffer full */
            if(g_u32comRbytes < RXBUFSIZE)
                /* Enqueue the character */
                g_u8RecData[g_u32comRtail] = u8InChar;
                g_u32comRtail = (g_u32comRtail == (RXBUFSIZE - 1)) ? 0 : (g_u32comRtail + 1);
                g_u32comRbytes++;
        printf("\nTransmission Test:");
    if(u32IntSts & UART_ISR_THRE_INT_Msk)
        uint16_t tmp;
        tmp = g_u32comRtail;
        if(g_u32comRhead != tmp)
            u8InChar = g_u8RecData[g_u32comRhead];
            UART_WRITE(UART0, u8InChar);
            g_u32comRhead = (g_u32comRhead == (RXBUFSIZE - 1)) ? 0 : (g_u32comRhead + 1);
            g_u32comRbytes--;
/*  UART Function Test        */
void UART_FunctionTest()
    printf("+-----------------------------------------------------------+\n");
    printf("|  UART Function Test                                       |\n");
    printf("|  Description :                                            |\n");
    printf("|    The sample code will print input char on terminal      |\n");
    printf("|    Please enter any to start     (Press '0' to exit)      |\n");
        Using a RS232 cable to connect UART0 and PC.
        UART0 is set to debug port. UART0 is enable RDA and RLS interrupt.
        When inputing char to terminal screen, RDA interrupt will happen and
        UART0 will print the received char on screen.
    /* Enable Interrupt and install the call back function */
    UART0->IER |= UART_IER_RDA_IEN_Msk | UART_IER_THRE_IEN_Msk | UART_IER_RTO_IEN_Msk ;
    NVIC_EnableIRQ(UART0_IRQn);
    while(g_bWait);
    /* Disable Interrupt */
    UART0->IER &= ~(UART_IER_RDA_IEN_Msk | UART_IER_THRE_IEN_Msk | UART_IER_RTO_IEN_Msk);
    NVIC_DisableIRQ(UART0_IRQn);
    g_bWait = TRUE;
    printf("\nUART Sample Demo End.\n");
zhuotuzi|  楼主 | 2017-7-8 23:21 | 显示全部楼层
通过寄存器更容易理解手册。
