[DemoCode下载]
看门狗定时器作为定时器超时中断使用
1275|4
玛尼玛尼哄|  楼主 | 2017-7-11 21:30 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
* [url=home.php?mod=space&uid=288409]@file[/url]     main.c
* [url=home.php?mod=space&uid=895143]@version[/url]  V3.00
* $Revision: 2 $
* $Date: 14/01/28 11:45a $
* [url=home.php?mod=space&uid=247401]@brief[/url]    M051 Series WDT Driver Sample Code
* @note
* Copyright (C) 2013 Nuvoton Technology Corp. All rights reserved.
#include <stdio.h>
#include "M051Series.h"
#define PLLCON_SETTING      CLK_PLLCON_50MHz_HXT
#define PLL_CLOCK           50000000
/* Global Interface Variables Declarations        */
extern int IsDebugFifoEmpty(void);
volatile uint8_t g_u8IsWDTTimeoutINT = 0;
* @brief       IRQ Handler for WDT and WWDT Interrupt
* @param       None
* [url=home.php?mod=space&uid=266161]@return[/url]      None
* [url=home.php?mod=space&uid=1543424]@Details[/url]     The WDT_IRQHandler is default IRQ of WDT and WWDT, declared in startup_M051Series.s.
void WDT_IRQHandler(void)
    if(WDT_GET_TIMEOUT_INT_FLAG() == 1)
        /* Clear WDT time-out interrupt flag */
        WDT_CLEAR_TIMEOUT_INT_FLAG();
        g_u8IsWDTTimeoutINT = 1;
void SYS_Init(void)
    /* Init System Clock        */
    /* Enable IRC22M clock */
    CLK->PWRCON |= CLK_PWRCON_IRC22M_EN_Msk;
    /* Waiting for IRC22M clock ready */
    CLK_WaitClockReady(CLK_CLKSTATUS_IRC22M_STB_Msk);
    /* Switch HCLK clock source to HIRC */
    CLK->CLKSEL0 = CLK_CLKSEL0_HCLK_S_HIRC;
    /* Set PLL to Power-down mode and PLL_STB bit in CLKSTATUS register will be cleared by hardware.*/
    CLK->PLLCON |= CLK_PLLCON_PD_Msk;
    /* Enable external 12 MHz XTAL, IRC 10 kHz */
    CLK->PWRCON |= CLK_PWRCON_XTL12M_EN_Msk | CLK_PWRCON_OSC10K_EN_Msk;
    /* Enable PLL and Set PLL frequency */
    CLK->PLLCON = PLLCON_SETTING;
    /* Waiting for clock ready */
    CLK_WaitClockReady(CLK_CLKSTATUS_PLL_STB_Msk | CLK_CLKSTATUS_XTL12M_STB_Msk | CLK_CLKSTATUS_IRC10K_STB_Msk);
    /* Switch HCLK clock source to PLL, STCLK to HCLK/2 */
    CLK->CLKSEL0 = CLK_CLKSEL0_STCLK_S_HCLK_DIV2 | CLK_CLKSEL0_HCLK_S_PLL;
    /* Enable peripheral clock */
    CLK->APBCLK = CLK_APBCLK_UART0_EN_Msk | CLK_APBCLK_WDT_EN_Msk;
    /* Peripheral clock source */
    CLK->CLKSEL1 = CLK_CLKSEL1_UART_S_PLL | CLK_CLKSEL1_WDT_S_LIRC;
    /* Update System Core Clock */
    /* User can use SystemCoreClockUpdate() to calculate PllClock, SystemCoreClock and CycylesPerUs automatically. */
    SystemCoreClockUpdate();
    /* Init I/O Multi-function        */
    /* Set P3 multi-function pins for UART0 RXD, TXD */
    SYS->P3_MFP = SYS_MFP_P30_RXD0 | SYS_MFP_P31_TXD0;
void UART0_Init(void)
    /* Init UART        */
    /* Reset IP */
    SYS_ResetModule(UART0_RST);
    /* Configure UART0 and set UART0 Baudrate */
    UART_Open(UART0, 115200);
/*  MAIN function        */
int main(void)
    uint32_t u32IntCnts = 0;
    /* Unlock protected registers */
    SYS_UnlockReg();
    /* Init System, peripheral clock and multi-function I/O */
    SYS_Init();
    /* Lock protected registers */
    SYS_LockReg();
    /* Init UART0 for printf */
    UART0_Init();
    printf("\n\nCPU [url=home.php?mod=space&uid=72445]@[/url] %d Hz\n", SystemCoreClock);
    printf("+---------------------------------------+\n");
    printf("|    WDT Time-out Period Sample Code    |\n");
    printf("+---------------------------------------+\n\n");
    printf("# WDT Settings:\n");
    printf("  Clock source is 10 kHz; Enable interrupt; Time-out interval is 2^14 * WDT clock.\n");
    printf("# When WDT statr counting, system will generate a WDT time-out interrupt after 1.6384 ~ 1.7408 s.\n");
    printf("  Measure P0.0 period time to check time-out interval.\n\n");
    /* Use P0.0 to check time-out period time */
    GPIO_SetMode(P0, 0, GPIO_PMD_OUTPUT);
    P00 = 1;
    P00 = 0;
    /* Because of all bits can be written in WDT Control Register are write-protected;
       To program it needs to disable register protection first. */
    SYS_UnlockReg();
    /* Select WDT time-out interval to 2^14 * WDT clock then start WDT counting */
    WDT_Open(WDT_TIMEOUT_2POW14, WDT_RESET_DELAY_3CLK, FALSE, FALSE);
    /* Enable WDT interrupt function */
    WDT_EnableInt();
    /* Enable WDT NVIC */
    NVIC_EnableIRQ(WDT_IRQn);
    while(1)
        /* Check if WDT time-out interrupt occurred or not */
        while(g_u8IsWDTTimeoutINT == 0);
        P00 ^= 1;
        printf("WDT time-out interrupt occurred. INT counts: %d      \r", ++u32IntCnts);
/*** (C) COPYRIGHT 2013 Nuvoton Technology Corp. ***/
dongnanxibei| | 2017-7-11 21:44 | 只看该作者
其实看门狗是可以作为普通的定时器使用的。非常棒。
598330983| | 2017-7-12 19:25 | 只看该作者
长长的配置,让我头疼不已。
zhuotuzi| | 2017-7-12 19:41 | 只看该作者
可以在缺少定时器时候,又不用看门狗的情况下使用。
heisexingqisi| | 2017-7-17 22:08 | 只看该作者
没这么用过看看。
