[技术问答]
N76E003,内部Flash怎么写入数据
5820|5
chenqinyao|  楼主 | 2017-7-18 01:54 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
如下程序, 数据手册上的写入流程, 来操作没有任何变化, 读出来的是0xFF, 而不是0x55按BSP包里面的例程序也没任何变化, 写入0x55, 读出来也是0xFF
现在问一下, 写内部Flash要注意什么的吗, 还是还要哪里云设置
#include "N76E003.h"
#include "Function_Define.h"
#include "SFR_Macro.h"
//  This code illustrates how to use IAP to make APROM 201h as a byte of
//  Data Flash when user code is executed in APROM.
#define  PAGE_ERASE_AP    0x22
#define  BYTE_PROGRAM_AP  0x21
/*Data Flash, as part of APROM, is read by MOVC. Data Flash can be defined as
128-element array in “code” area from absolute address 0x0200               */
volatile unsigned char code Data_Flash[128] _at_ 0x0200;
Main (void)
    TA = 0xAA;        //CHPCON is TA protected
    TA = 0x55;
    CHPCON |= 0x01;       //IAPEN = 1, enable IAP mode
    TA = 0xAA;        //IAPUEN is TA protected
    TA = 0x55;
    IAPUEN |= 0x01;       //APUEN = 1, enable APROM update
    IAPCN = PAGE_ERASE_AP;    //Erase page 200h~27Fh
    IAPAH = 0x02;
    IAPAL = 0x00;
    IAPFD = 0xFF;
    TA = 0xAA;        //IAPTRG is TA protected
    TA = 0x55;
    IAPTRG |= 0x01;      //write ‘1’ to IAPGO to trigger IAP process
    IAPCN = BYTE_PROGRAM_AP;    // Program 201h with 55h
    IAPAH = 0x02;
    IAPAL = 0x01;
    IAPFD = 0x55;
    TA = 0xAA;
    TA = 0x55;
    TA = 0x55;
    IAPUEN &= ~0x01;       //APUEN = 0, disable APROM update
    TA = 0x55;
    CHPCON &= ~0x01;       //IAPEN = 0, disable IAP mode
    P0 = Data_Flash[1];     //Read content of address 200h+1
    while(1);
上面  Data_Flash[1] 读出来的0xFF, 而不是0x55
wahahaheihei| | 2017-7-18 14:58 | 只看该作者
提供的有例子吧。
wahahaheihei| | 2017-7-18 15:13 | 只看该作者
/* Copyright(c) 2016 Nuvoton Technology Corp. All rights reserved.                                         */
//  Nuvoton Technoledge Corp.
//  Website: http://www.nuvoton.com
//  E-Mail : MicroC-8bit@nuvoton.com
//  Date   : Apr/21/2016
//  File Function: N76E003 APROM program DATAFLASH as EEPROM way
#include <stdio.h>
#include "Common.h"
#include "Delay.h"
bit BIT_TMP;
UINT8 read_APROM_BYTE(UINT16 code *u16_addr)
        UINT8 rdata;
        rdata = *u16_addr>>8;
        return rdata;
write_DATAFLASH_BYTE :
user can copy all this subroutine into project, then call this function in main.
void write_DATAFLASH_BYTE(UINT16 u16_addr,UINT8 u8_data)
        UINT8 looptmp=0,u8_addrl_r;
        unsigned char code *cd_longaddr;
        unsigned char xdata *xd_tmp;
//Check page start address
        u8_addrl_r = u16_addr;
        if (u8_addrl_r<0x80)
                u8_addrl_r = 0;
        else
                u8_addrl_r = 0x80;
//Save APROM data to XRAM
        xd_tmp = 0x80;
        cd_longaddr = (u16_addr&0xff00)+u8_addrl_r;
        while (xd_tmp !=0x100)
                *xd_tmp = *cd_longaddr;
                looptmp++;
                xd_tmp++;
                cd_longaddr++;
// Modify customer data in XRAM
                xd_tmp = u8_addrl_r+0x80;
        else
                xd_tmp = u8_addrl_r+0;
        *xd_tmp = u8_data;
//Erase APROM DATAFLASH page
                IAPAL = u16_addr;
                IAPAH = u16_addr>>8;
                IAPFD = 0xFF;
          set_IAPEN;
                set_APUEN;
    IAPCN = 0x22;
                set_IAPGO;
//Save changed RAM data to APROM DATAFLASH
                u8_addrl_r =0;
        else
                u8_addrl_r = 0x80;
                xd_tmp = 0x80;
          IAPAL = u8_addrl_r;
                set_IAPEN;
                set_APUEN;
          IAPCN = 0x21;
                while (xd_tmp !=0xFF)
                        IAPFD = *xd_tmp;
                        set_IAPGO;
                        IAPAL++;
                        xd_tmp++;
                clr_APUEN;
                clr_IAPEN;
void main (void)
                UINT8 datatemp;
/*  Dataflash use APROM area        */
/*        APROM 0x3800~0x38FF demo as dataflash        */
/* Please use Memory window key in C:0x3800 to check earse result                                          */
//call write byte
                write_DATAFLASH_BYTE (0x3881,0x55);
                write_DATAFLASH_BYTE (0x3882,0x56);
                write_DATAFLASH_BYTE (0x3855,0xaa);
                write_DATAFLASH_BYTE (0x3856,0x66);
//call read byte
                datatemp = read_APROM_BYTE(0x3882);
    while(1);
yiyigirl2014| | 2017-7-18 18:57 | 只看该作者
稳稳の幸福| | 2017-7-18 19:59 | 只看该作者
手册上应该有说操作哪儿
l4157| | 2017-7-19 10:08 | 只看该作者
KEIL C51 有时会优化掉 TA=0xAA;TA=0x55; ???;这个时序有要求的.我也是刚发现,优化等级为9的时候出了问题,改优化等级为7 就没有 问题了
