[DemoCode下载]
M0518的ADC
1094|7
zhuomuniao110|  楼主 | 2017-8-7 21:38 | 显示全部楼层 |阅读模式
* [url=home.php?mod=space&uid=288409]@file[/url]     main.c
* [url=home.php?mod=space&uid=895143]@version[/url]  V2.0
* $Revision: 2 $
* $Date: 14/12/25 10:24a $
* [url=home.php?mod=space&uid=247401]@brief[/url]    Perform A/D Conversion with ADC continuous scan mode.
* @note
* Copyright (C) 2014 Nuvoton Technology Corp. All rights reserved.
#include <stdio.h>
#include "M0518.h"
#define PLL_CLOCK       50000000
/* Define Function Prototypes        */
void SYS_Init(void);
void UART0_Init(void);
void AdcContScanModeTest(void);
void SYS_Init(void)
    /* Init System Clock        */
    /* Enable Internal RC 22.1184MHz clock */
    CLK_EnableXtalRC(CLK_PWRCON_OSC22M_EN_Msk);
    /* Waiting for Internal RC clock ready */
    CLK_WaitClockReady(CLK_CLKSTATUS_OSC22M_STB_Msk);
    /* Switch HCLK clock source to Internal RC and HCLK source divide 1 */
    CLK_SetHCLK(CLK_CLKSEL0_HCLK_S_HIRC, CLK_CLKDIV_HCLK(1));
    /* Enable external XTAL 12MHz clock */
    CLK_EnableXtalRC(CLK_PWRCON_XTL12M_EN_Msk);
    /* Waiting for external XTAL clock ready */
    CLK_WaitClockReady(CLK_CLKSTATUS_XTL12M_STB_Msk);
    /* Set core clock as PLL_CLOCK from PLL */
    CLK_SetCoreClock(PLL_CLOCK);
    /* Enable UART module clock */
    CLK_EnableModuleClock(UART0_MODULE);
    /* Enable ADC module clock */
    CLK_EnableModuleClock(ADC_MODULE);
    /* Select UART module clock source */
    CLK_SetModuleClock(UART0_MODULE, CLK_CLKSEL1_UART_S_PLL, CLK_CLKDIV_UART(1));
    /* ADC clock source is 22.1184MHz, set divider to 7, ADC clock is 22.1184/7 MHz */
    CLK_SetModuleClock(ADC_MODULE, CLK_CLKSEL1_ADC_S_HIRC, CLK_CLKDIV_ADC(7));
    /* Init I/O Multi-function        */
    /* Set GPB multi-function pins for UART0 RXD and TXD */
    SYS->GPB_MFP &= ~(SYS_GPB_MFP_PB0_Msk | SYS_GPB_MFP_PB1_Msk);
    SYS->GPB_MFP |= SYS_GPB_MFP_PB0_UART0_RXD | SYS_GPB_MFP_PB1_UART0_TXD;
    /* Disable the GPA0 - GPA3 digital input path to avoid the leakage current. */
    GPIO_DISABLE_DIGITAL_PATH(PA, 0xF);
    /* Configure the GPA0 - GPA3 ADC analog input pins */
    SYS->GPA_MFP &= ~(SYS_GPA_MFP_PA0_Msk | SYS_GPA_MFP_PA1_Msk | SYS_GPA_MFP_PA2_Msk | SYS_GPA_MFP_PA3_Msk) ;
    SYS->GPA_MFP |= SYS_GPA_MFP_PA0_ADC0 | SYS_GPA_MFP_PA1_ADC1 | SYS_GPA_MFP_PA2_ADC2 | SYS_GPA_MFP_PA3_ADC3 ;
/* Init UART        */
void UART0_Init()
    /* Reset IP */
    SYS_ResetModule(UART0_RST);
    /* Configure UART0 and set UART0 Baudrate */
    UART_Open(UART0, 115200);
/* Function: ADC_GetConversionRate        */
/* Parameters:        */
/*   None.        */
/* Returns:        */
/*   Return the A/D conversion rate (sample/second)                                                     */
/* Description:        */
/*   The conversion rate depends on the clock source of ADC clock.                                         */
/*   It only needs 21 ADC clocks to complete an A/D conversion.                                            */
static __INLINE uint32_t ADC_GetConversionRate()
    uint32_t u32AdcClkSrcSel;
    uint32_t u32ClkTbl[4] = {__HXT, 0, 0, __HIRC};
    /* Set the PLL clock frequency */
    u32ClkTbl[1] = PllClock;
    /* Set the system core clock frequency */
    u32ClkTbl[2] = SystemCoreClock;
    /* Get the clock source setting */
    u32AdcClkSrcSel = ((CLK->CLKSEL1 & CLK_CLKSEL1_ADC_S_Msk) >> CLK_CLKSEL1_ADC_S_Pos);
    /* Return the ADC conversion rate */
    return ((u32ClkTbl[u32AdcClkSrcSel]) / (((CLK->CLKDIV & CLK_CLKDIV_ADC_N_Msk) >> CLK_CLKDIV_ADC_N_Pos) + 1) / 21);
/* Function: AdcContScanModeTest        */
/* Parameters:        */
/*   None.        */
/* Returns:        */
/*   None.        */
/* Description:        */
/*   ADC continuous scan mode test.        */
void AdcContScanModeTest()
    uint8_t  u8Option;
    uint32_t u32ChannelCount;
    int32_t  i32ConversionData;
    printf("\n\nConversion rate: %d samples/second\n", ADC_GetConversionRate());
    printf("\n");
    printf("+----------------------------------------------------------------------+\n");
    printf("|                 ADC continuous scan mode sample code                 |\n");
    printf("\nIn this test, software will get 2 cycles of conversion result from the specified channels.\n");
    while(1)
        printf("\n\nSelect input mode:\n");
        printf("  [1] Single end input (channel 0, 1, 2 and 3)\n");
        printf("  [2] Differential input (input channel pair 0 and 1)\n");
        printf("  Other keys: exit continuous scan mode test\n");
        u8Option = getchar();
        if(u8Option == '1')
            /* Set the ADC operation mode as continuous scan, input mode as single-end and
                 enable the analog input channel 0, 1, 2 and 3 */
            ADC_Open(ADC, ADC_ADCR_DIFFEN_SINGLE_END, ADC_ADCR_ADMD_CONTINUOUS, 0xF);
            /* Power on ADC module */
            ADC_POWER_ON(ADC);
            /* Clear the A/D interrupt flag for safe */
            ADC_CLR_INT_FLAG(ADC, ADC_ADF_INT);
            /* Start A/D conversion */
            ADC_START_CONV(ADC);
            /* Wait conversion done */
            while(!ADC_GET_INT_FLAG(ADC, ADC_ADF_INT));
            for(u32ChannelCount = 0; u32ChannelCount < 4; u32ChannelCount++)
                i32ConversionData = ADC_GET_CONVERSION_DATA(ADC, u32ChannelCount);
                printf("Conversion result of channel %d: 0x%X (%d)\n", u32ChannelCount, i32ConversionData, i32ConversionData);
            /* Stop A/D conversion */
            ADC_STOP_CONV(ADC);
        else if(u8Option == '2')
            /* Set the ADC operation mode as continuous scan, input mode as differential and
               enable analog input channel 0 and 2 */
            ADC_Open(ADC, ADC_ADCR_DIFFEN_DIFFERENTIAL, ADC_ADCR_ADMD_CONTINUOUS, 0x5);
            ADC_POWER_ON(ADC);
            for(u32ChannelCount = 0; u32ChannelCount < 2; u32ChannelCount++)
                i32ConversionData = ADC_GET_CONVERSION_DATA(ADC, u32ChannelCount * 2);
                printf("Conversion result of differential input pair %d: 0x%X (%d)\n", u32ChannelCount, i32ConversionData, i32ConversionData);
            ADC_STOP_CONV(ADC);
        else
            return ;
/* MAIN function        */
int main(void)
    /* Unlock protected registers */
    SYS_UnlockReg();
    /* Init System, IP clock and multi-function I/O */
    SYS_Init();
    /* Lock protected registers */
    SYS_LockReg();
    /* Init UART0 for printf */
    UART0_Init();
    /* SAMPLE CODE        */
    printf("\nSystem clock rate: %d Hz", SystemCoreClock);
    /* Continuous scan mode test */
    AdcContScanModeTest();
    /* Disable ADC module */
    ADC_Close(ADC);
    /* Disable ADC IP clock */
    CLK_DisableModuleClock(ADC_MODULE);
    /* Disable External Interrupt */
    NVIC_DisableIRQ(ADC_IRQn);
    printf("\nExit ADC sample code\n");
    while(1);
zhuomuniao110|  楼主 | 2017-8-7 21:46 | 显示全部楼层
zhuomuniao110|  楼主 | 2017-8-7 21:47 | 显示全部楼层
这个比较给力,使用ADC第一步,先关闭这些端口的数字输入通路,目的是避免泄露电流,也就说,只使用这个端口的ADC模块,IO输入模块关闭。。。
然后配置模拟输入端口。。就是选择哪些ADC使用。
zhuomuniao110|  楼主 | 2017-8-7 21:55 | 显示全部楼层
后面两个位逻辑运算是,第一个,先选择要操作的位置,取反后,通过位与操作,让其他不相干的位保持不变,而要操作的位,全部清0.
第二个操作是通过位或操作,将要操作的位置1,还是保持其他的原来位值。。
zhuomuniao110|  楼主 | 2017-8-7 22:09 | 显示全部楼层
然后通过内联函数获取转换采样率。。。很牛叉。好多单片机厂商没有提供这个函数。
没有用中断就关闭了。
21mengnan| | 2017-8-8 23:13 | 显示全部楼层
看着很长,仔细看Main就很短了。
wanduzi| | 2017-8-9 16:17 | 显示全部楼层
我是新来的,准备从STM32转这个,请大家多多关照。
