[ZLG-ARM] CortexMo菜鸟逆向学习ISP(第4天作业)
6767|19
 楼主| hotpower 发表于 2010-7-27 20:20 | 显示全部楼层 |阅读模式
 楼主| hotpower 发表于 2010-7-27 20:23 | 显示全部楼层
在逆向中学习:
0        10:00:59        FlashMagic.exe        IRP_MJ_CREATE        MosChipSerial1        SUCCESS        Options: Open //打开串口
1        10:00:59        FlashMagic.exe        IOCTL_SERIAL_GET_PROPERTIES        MosChipSerial1        SUCCESS
2        10:00:59        FlashMagic.exe        IOCTL_SERIAL_GET_BAUD_RATE        MosChipSerial1        SUCCESS
3        10:00:59        FlashMagic.exe        IOCTL_SERIAL_GET_LINE_CONTROL        MosChipSerial1        SUCCESS
4        10:00:59        FlashMagic.exe        IOCTL_SERIAL_GET_CHARS        MosChipSerial1        SUCCESS
5        10:00:59        FlashMagic.exe        IOCTL_SERIAL_GET_HANDFLOW        MosChipSerial1        SUCCESS
6        10:00:59        FlashMagic.exe        IOCTL_SERIAL_GET_BAUD_RATE        MosChipSerial1        SUCCESS
7        10:00:59        FlashMagic.exe        IOCTL_SERIAL_GET_LINE_CONTROL        MosChipSerial1        SUCCESS
8        10:00:59        FlashMagic.exe        IOCTL_SERIAL_GET_CHARS        MosChipSerial1        SUCCESS
9        10:00:59        FlashMagic.exe        IOCTL_SERIAL_GET_HANDFLOW        MosChipSerial1        SUCCESS
10        10:00:59        FlashMagic.exe        IOCTL_SERIAL_SET_BAUD_RATE        MosChipSerial1        SUCCESS        Rate: 115200 //设置波特率为115200BPS
11        10:00:59        FlashMagic.exe        IOCTL_SERIAL_CLR_RTS        MosChipSerial1        SUCCESS        //ISP=1 Cortext-M0运行状态
12        10:00:59        FlashMagic.exe        IOCTL_SERIAL_CLR_DTR        MosChipSerial1        SUCCESS        //RST=1 Cortext-M0工作
13        10:00:59        FlashMagic.exe        IOCTL_SERIAL_SET_LINE_CONTROL        MosChipSerial1        SUCCESS        StopBits: 1 Parity: NONE WordLength: 8 //8位数据无校验1位停止位
14        10:00:59        FlashMagic.exe        IOCTL_SERIAL_SET_CHAR        MosChipSerial1        SUCCESS        EOF:0 ERR:0 BRK:0 EVT:0 XON:11 XOFF:13
15        10:00:59        FlashMagic.exe        IOCTL_SERIAL_SET_HANDFLOW        MosChipSerial1        SUCCESS        Shake:0 Replace:0 XonLimit:2048 XoffLimit:512
16        10:00:59        FlashMagic.exe        IOCTL_SERIAL_SET_QUEUE_SIZE        MosChipSerial1        SUCCESS        InSize: 16384 OutSize: 16384
17        10:00:59        FlashMagic.exe        IOCTL_SERIAL_SET_TIMEOUTS        MosChipSerial1        SUCCESS        RI:0 RM:0 RC:4000 WM:0 WC:4000
18        10:00:59        FlashMagic.exe        IOCTL_SERIAL_CLR_RTS        MosChipSerial1        SUCCESS        //ISP=1 Cortext-M0运行状态
19        10:00:59        FlashMagic.exe        IOCTL_SERIAL_CLR_DTR        MosChipSerial1        SUCCESS        //RST=1 Cortext-M0工作
20        10:00:59        FlashMagic.exe        IOCTL_SERIAL_CLR_DTR        MosChipSerial1        SUCCESS
21        10:00:59        FlashMagic.exe        IOCTL_SERIAL_CLR_RTS        MosChipSerial1        SUCCESS
22        10:00:59        FlashMagic.exe        IOCTL_SERIAL_SET_DTR        MosChipSerial1        SUCCESS        //RST=0 Cortext-M0复位(信号跳变)
23        10:00:59        FlashMagic.exe        IOCTL_SERIAL_CLR_RTS        MosChipSerial1        SUCCESS
24        10:00:59        FlashMagic.exe        IOCTL_SERIAL_SET_RTS        MosChipSerial1        SUCCESS //ISP=0 Cortext-M0下载状态(信号跳变)
25        10:00:59        FlashMagic.exe        IOCTL_SERIAL_SET_DTR        MosChipSerial1        SUCCESS
26        10:00:59        FlashMagic.exe        IOCTL_SERIAL_CLR_DTR        MosChipSerial1        SUCCESS        //RST=1 Cortext-M0工作(信号跳变)
27        10:00:59        FlashMagic.exe        IOCTL_SERIAL_SET_RTS        MosChipSerial1        SUCCESS        //进入ISP时,ISP=0, RST=1
28        10:00:59        FlashMagic.exe        IOCTL_SERIAL_PURGE        MosChipSerial1        SUCCESS        Purge: RXCLEAR
29        10:00:59        FlashMagic.exe        IOCTL_SERIAL_PURGE        MosChipSerial1        SUCCESS        Purge: TXCLEAR
30        10:00:59        FlashMagic.exe        IOCTL_SERIAL_SET_TIMEOUTS        MosChipSerial1        SUCCESS        RI:0 RM:0 RC:1000 WM:0 WC:4000
31        10:00:59        FlashMagic.exe        IRP_MJ_WRITE        MosChipSerial1        SUCCESS        Length 1: 3F //发送联机同步命令(1:6:2)
32        10:00:59        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: 53        //应答联机同步命令字符串Synchronized
33        10:00:59        FlashMagic.exe        IOCTL_SERIAL_SET_TIMEOUTS        MosChipSerial1        SUCCESS        RI:0 RM:0 RC:4000 WM:0 WC:4000
34        10:00:59        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: 79
35        10:00:59        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: 6E
36        10:00:59        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: 63
37        10:00:59        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: 68
38        10:00:59        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: 72
39        10:00:59        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: 6F
40        10:00:59        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: 6E
41        10:00:59        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: 69
42        10:00:59        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: 7A
43        10:00:59        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: 65
44        10:00:59        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: 64
45        10:00:59        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: 0D
46        10:00:59        FlashMagic.exe        IOCTL_SERIAL_SET_TIMEOUTS        MosChipSerial1        SUCCESS        RI:0 RM:0 RC:50 WM:0 WC:4000
47        10:00:59        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: 0A
48        10:00:59        FlashMagic.exe        IOCTL_SERIAL_SET_TIMEOUTS        MosChipSerial1        SUCCESS        RI:0 RM:0 RC:4000 WM:0 WC:4000
49        10:00:59        FlashMagic.exe        IRP_MJ_WRITE        MosChipSerial1        SUCCESS        Length 13: 53 79 6E 63 68 72 6F 6E 69 7A 65 64 0D //发送波特率只适应字符串Synchronized
50        10:00:59        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: 53 //应答波特率只适应字符串
51        10:00:59        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: 79
52        10:00:59        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: 6E
53        10:00:59        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: 63
54        10:00:59        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: 68
55        10:00:59        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: 72
56        10:00:59        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: 6F
57        10:00:59        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: 6E
58        10:00:59        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: 69
59        10:00:59        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: 7A
60        10:00:59        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: 65
61        10:00:59        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: 64
62        10:00:59        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: 0D
63        10:00:59        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: 4F //波特率自适应成功OK。比特率以绑定
64        10:00:59        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: 4B
65        10:00:59        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: 0D
66        10:00:59        FlashMagic.exe        IOCTL_SERIAL_SET_TIMEOUTS        MosChipSerial1        SUCCESS        RI:0 RM:0 RC:50 WM:0 WC:4000
67        10:00:59        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: 0A
68        10:00:59        FlashMagic.exe        IOCTL_SERIAL_SET_TIMEOUTS        MosChipSerial1        SUCCESS        RI:0 RM:0 RC:4000 WM:0 WC:4000
69        10:00:59        FlashMagic.exe        IRP_MJ_WRITE        MosChipSerial1        SUCCESS        Length 6: 31 32 30 30 30 0D //发送主频12000KHz(12.000MHz)
70        10:00:59        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 6: 31 32 30 30 30 0D //应答主频12000KHz(12.000MHz)
71        10:01:00        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: 4F 成功返回OK
72        10:01:00        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: 4B
73        10:01:00        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: 0D
74        10:01:00        FlashMagic.exe        IOCTL_SERIAL_SET_TIMEOUTS        MosChipSerial1        SUCCESS        RI:0 RM:0 RC:50 WM:0 WC:4000
75        10:01:00        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: 0A
76        10:01:00        FlashMagic.exe        IOCTL_SERIAL_SET_TIMEOUTS        MosChipSerial1        SUCCESS        RI:0 RM:0 RC:4000 WM:0 WC:4000
77        10:01:00        FlashMagic.exe        IRP_MJ_WRITE        MosChipSerial1        SUCCESS        Length 2: 4A 0D //发送读器件ID命令
78        10:01:00        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: 4A //应答读器件ID命令
79        10:01:00        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: 0D
80        10:01:00        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: 30 //成功返回CMD_SUCCESS
81        10:01:00        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: 0D
82        10:01:00        FlashMagic.exe        IOCTL_SERIAL_SET_TIMEOUTS        MosChipSerial1        SUCCESS        RI:0 RM:0 RC:50 WM:0 WC:4000
83        10:01:00        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: 0A
84        10:01:00        FlashMagic.exe        IOCTL_SERIAL_SET_TIMEOUTS        MosChipSerial1        SUCCESS        RI:0 RM:0 RC:4000 WM:0 WC:4000
85        10:01:00        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: 37 //Device ID = 71569451(0x0444102B)LPC1114/301
86        10:01:00        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: 31
87        10:01:00        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: 35
88        10:01:00        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: 36
89        10:01:00        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: 39
90        10:01:00        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: 34
91        10:01:00        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: 35
92        10:01:00        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: 31
93        10:01:00        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: 0D
94        10:01:00        FlashMagic.exe        IOCTL_SERIAL_SET_TIMEOUTS        MosChipSerial1        SUCCESS        RI:0 RM:0 RC:50 WM:0 WC:4000
95        10:01:00        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: 0A
96        10:01:00        FlashMagic.exe        IOCTL_SERIAL_SET_TIMEOUTS        MosChipSerial1        SUCCESS        RI:0 RM:0 RC:4000 WM:0 WC:4000
97        10:01:00        FlashMagic.exe        IRP_MJ_WRITE        MosChipSerial1        SUCCESS        Length 2: 4B 0D.//发送读BootLoad代码版本命令
98        10:01:00        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: 4B.//应答读BootLoad代码版本命令
99        10:01:00        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: 0D
100        10:01:00        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: 30 //成功返回CMD_SUCCESS
101        10:01:00        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: 0D
102        10:01:00        FlashMagic.exe        IOCTL_SERIAL_SET_TIMEOUTS        MosChipSerial1        SUCCESS        RI:0 RM:0 RC:50 WM:0 WC:4000
103        10:01:00        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: 0A
104        10:01:00        FlashMagic.exe        IOCTL_SERIAL_SET_TIMEOUTS        MosChipSerial1        SUCCESS        RI:0 RM:0 RC:4000 WM:0 WC:4000
105        10:01:00        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: 30 //BootLoad 次版本号0
106        10:01:00        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: 0D
107        10:01:00        FlashMagic.exe        IOCTL_SERIAL_SET_TIMEOUTS        MosChipSerial1        SUCCESS        RI:0 RM:0 RC:50 WM:0 WC:4000
108        10:01:00        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: 0A
109        10:01:00        FlashMagic.exe        IOCTL_SERIAL_SET_TIMEOUTS        MosChipSerial1        SUCCESS        RI:0 RM:0 RC:4000 WM:0 WC:4000
110        10:01:00        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: 37 //BootLoad 主版本号7
111        10:01:00        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: 0D
112        10:01:00        FlashMagic.exe        IOCTL_SERIAL_SET_TIMEOUTS        MosChipSerial1        SUCCESS        RI:0 RM:0 RC:50 WM:0 WC:4000
113        10:01:00        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: 0A
114        10:01:00        FlashMagic.exe        IOCTL_SERIAL_SET_TIMEOUTS        MosChipSerial1        SUCCESS        RI:0 RM:0 RC:4000 WM:0 WC:4000
115        10:01:00        FlashMagic.exe        IRP_MJ_WRITE        MosChipSerial1        SUCCESS        Length 2: 4E 0D //发送读UID命令
116        10:01:00        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: 4E //应答读UID命令(UID = 06061826 534E1112 4B6D7B5A F5000005)
117        10:01:00        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: 0D
118        10:01:00        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: 30 //成功返回CMD_SUCCESS
119        10:01:00        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: 0D
120        10:01:00        FlashMagic.exe        IOCTL_SERIAL_SET_TIMEOUTS        MosChipSerial1        SUCCESS        RI:0 RM:0 RC:50 WM:0 WC:4000
121        10:01:00        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: 0A
122        10:01:00        FlashMagic.exe        IOCTL_SERIAL_SET_TIMEOUTS        MosChipSerial1        SUCCESS        RI:0 RM:0 RC:4000 WM:0 WC:4000
123        10:01:00        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: 31 //序列号(1)101062694(0x06061826)
124        10:01:00        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: 30
125        10:01:00        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: 31
126        10:01:00        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: 30
127        10:01:00        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: 36
128        10:01:00        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: 32
129        10:01:00        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: 36
130        10:01:00        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: 39
131        10:01:00        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: 34
132        10:01:00        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: 0D
133        10:01:00        FlashMagic.exe        IOCTL_SERIAL_SET_TIMEOUTS        MosChipSerial1        SUCCESS        RI:0 RM:0 RC:50 WM:0 WC:4000
134        10:01:00        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: 0A
135        10:01:00        FlashMagic.exe        IOCTL_SERIAL_SET_TIMEOUTS        MosChipSerial1        SUCCESS        RI:0 RM:0 RC:4000 WM:0 WC:4000
136        10:01:00        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: 31 //序列号(2)1397625106(0x534E1112)
137        10:01:00        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: 33
138        10:01:00        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: 39
139        10:01:00        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: 37
140        10:01:00        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: 36
141        10:01:00        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: 32
142        10:01:00        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: 35
143        10:01:00        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: 31
144        10:01:00        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: 30
145        10:01:00        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: 36
146        10:01:00        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: 0D
147        10:01:00        FlashMagic.exe        IOCTL_SERIAL_SET_TIMEOUTS        MosChipSerial1        SUCCESS        RI:0 RM:0 RC:50 WM:0 WC:4000
148        10:01:00        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: 0A
149        10:01:00        FlashMagic.exe        IOCTL_SERIAL_SET_TIMEOUTS        MosChipSerial1        SUCCESS        RI:0 RM:0 RC:4000 WM:0 WC:4000
150        10:01:00        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: 31 //序列号(3)1265466202(0x4B6D7B5A)
151        10:01:00        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: 32
152        10:01:00        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: 36
153        10:01:00        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: 35
154        10:01:00        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: 34
155        10:01:00        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: 36
156        10:01:00        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: 36
157        10:01:00        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: 32
158        10:01:00        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: 30
159        10:01:00        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: 32
160        10:01:00        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: 0D
161        10:01:00        FlashMagic.exe        IOCTL_SERIAL_SET_TIMEOUTS        MosChipSerial1        SUCCESS        RI:0 RM:0 RC:50 WM:0 WC:4000
162        10:01:00        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: 0A
163        10:01:00        FlashMagic.exe        IOCTL_SERIAL_SET_TIMEOUTS        MosChipSerial1        SUCCESS        RI:0 RM:0 RC:4000 WM:0 WC:4000
164        10:01:00        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: 34 //序列号(4)4110417925(0xF5000005)
165        10:01:00        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: 31
166        10:01:00        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: 31
167        10:01:00        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: 30
168        10:01:00        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: 34
169        10:01:00        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: 31
170        10:01:00        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: 37
171        10:01:00        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: 39
172        10:01:00        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: 32
173        10:01:00        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: 35
174        10:01:00        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: 0D
175        10:01:00        FlashMagic.exe        IOCTL_SERIAL_SET_TIMEOUTS        MosChipSerial1        SUCCESS        RI:0 RM:0 RC:50 WM:0 WC:4000
176        10:01:00        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: 0A
177        10:01:00        FlashMagic.exe        IOCTL_SERIAL_SET_TIMEOUTS        MosChipSerial1        SUCCESS        RI:0 RM:0 RC:4000 WM:0 WC:4000
178        10:01:00        FlashMagic.exe        IOCTL_SERIAL_SET_DTR        MosChipSerial1        SUCCESS        //RST=0 Cortext-M0复位(信号跳变)
179        10:01:00        FlashMagic.exe        IOCTL_SERIAL_SET_RTS        MosChipSerial1        SUCCESS
180        10:01:00        FlashMagic.exe        IOCTL_SERIAL_SET_RTS        MosChipSerial1        SUCCESS
181        10:01:00        FlashMagic.exe        IOCTL_SERIAL_SET_DTR        MosChipSerial1        SUCCESS
182        10:01:00        FlashMagic.exe        IOCTL_SERIAL_CLR_RTS        MosChipSerial1        SUCCESS        //ISP=1 Cortext-M0运行状态(信号跳变)
183        10:01:00        FlashMagic.exe        IOCTL_SERIAL_SET_DTR        MosChipSerial1        SUCCESS
184        10:01:00        FlashMagic.exe        IOCTL_SERIAL_CLR_DTR        MosChipSerial1        SUCCESS        //RST=1 Cortext-M0工作(信号跳变)
185        10:01:00        FlashMagic.exe        IOCTL_SERIAL_CLR_RTS        MosChipSerial1        SUCCESS
186        10:01:00        FlashMagic.exe        IRP_MJ_CLEANUP        MosChipSerial1        SUCCESS
187        10:01:00        FlashMagic.exe        IRP_MJ_CLOSE        MosChipSerial1        SUCCESS
ADaiPlay 发表于 2010-7-27 20:24 | 显示全部楼层
怎么总感觉菜农的思维这么跳跃呢,让菜鸟们琢磨不透
不管了,先沙发:lol
 楼主| hotpower 发表于 2010-7-27 20:24 | 显示全部楼层
在逆向中进取:
0        9:52:17        FlashMagic.exe        IRP_MJ_CREATE        MosChipSerial1        SUCCESS        Options: Open //打开串口
1        9:52:17        FlashMagic.exe        IOCTL_SERIAL_GET_PROPERTIES        MosChipSerial1        SUCCESS
2        9:52:17        FlashMagic.exe        IOCTL_SERIAL_GET_BAUD_RATE        MosChipSerial1        SUCCESS
3        9:52:17        FlashMagic.exe        IOCTL_SERIAL_GET_LINE_CONTROL        MosChipSerial1        SUCCESS
4        9:52:17        FlashMagic.exe        IOCTL_SERIAL_GET_CHARS        MosChipSerial1        SUCCESS
5        9:52:17        FlashMagic.exe        IOCTL_SERIAL_GET_HANDFLOW        MosChipSerial1        SUCCESS
6        9:52:17        FlashMagic.exe        IOCTL_SERIAL_GET_BAUD_RATE        MosChipSerial1        SUCCESS
7        9:52:17        FlashMagic.exe        IOCTL_SERIAL_GET_LINE_CONTROL        MosChipSerial1        SUCCESS
8        9:52:17        FlashMagic.exe        IOCTL_SERIAL_GET_CHARS        MosChipSerial1        SUCCESS
9        9:52:17        FlashMagic.exe        IOCTL_SERIAL_GET_HANDFLOW        MosChipSerial1        SUCCESS
10        9:52:17        FlashMagic.exe        IOCTL_SERIAL_SET_BAUD_RATE        MosChipSerial1        SUCCESS        Rate: 115200 //设置波特率为115200BPS
11        9:52:17        FlashMagic.exe        IOCTL_SERIAL_CLR_RTS        MosChipSerial1        SUCCESS        //ISP=1 Cortext-M0运行状态
12        9:52:17        FlashMagic.exe        IOCTL_SERIAL_CLR_DTR        MosChipSerial1        SUCCESS        //RST=1 Cortext-M0工作
13        9:52:17        FlashMagic.exe        IOCTL_SERIAL_SET_LINE_CONTROL        MosChipSerial1        SUCCESS        StopBits: 1 Parity: NONE WordLength: 8 //8位数据无校验1位停止位
14        9:52:17        FlashMagic.exe        IOCTL_SERIAL_SET_CHAR        MosChipSerial1        SUCCESS        EOF:0 ERR:0 BRK:0 EVT:0 XON:11 XOFF:13
15        9:52:17        FlashMagic.exe        IOCTL_SERIAL_SET_HANDFLOW        MosChipSerial1        SUCCESS        Shake:0 Replace:0 XonLimit:2048 XoffLimit:512
16        9:52:17        FlashMagic.exe        IOCTL_SERIAL_SET_QUEUE_SIZE        MosChipSerial1        SUCCESS        InSize: 16384 OutSize: 16384
17        9:52:17        FlashMagic.exe        IOCTL_SERIAL_SET_TIMEOUTS        MosChipSerial1        SUCCESS        RI:0 RM:0 RC:4000 WM:0 WC:4000
18        9:52:17        FlashMagic.exe        IOCTL_SERIAL_CLR_RTS        MosChipSerial1        SUCCESS        //ISP=1 Cortext-M0运行状态
19        9:52:17        FlashMagic.exe        IOCTL_SERIAL_CLR_DTR        MosChipSerial1        SUCCESS        //RST=1 Cortext-M0工作
20        9:52:17        FlashMagic.exe        IOCTL_SERIAL_CLR_DTR        MosChipSerial1        SUCCESS
21        9:52:17        FlashMagic.exe        IOCTL_SERIAL_CLR_RTS        MosChipSerial1        SUCCESS
22        9:52:17        FlashMagic.exe        IOCTL_SERIAL_SET_DTR        MosChipSerial1        SUCCESS        //RST=0 Cortext-M0复位(信号跳变)
23        9:52:17        FlashMagic.exe        IOCTL_SERIAL_CLR_RTS        MosChipSerial1        SUCCESS
24        9:52:17        FlashMagic.exe        IOCTL_SERIAL_SET_RTS        MosChipSerial1        SUCCESS //ISP=0 Cortext-M0下载状态(信号跳变)
25        9:52:17        FlashMagic.exe        IOCTL_SERIAL_SET_DTR        MosChipSerial1        SUCCESS
26        9:52:17        FlashMagic.exe        IOCTL_SERIAL_CLR_DTR        MosChipSerial1        SUCCESS        //RST=1 Cortext-M0工作(信号跳变)
27        9:52:17        FlashMagic.exe        IOCTL_SERIAL_SET_RTS        MosChipSerial1        SUCCESS
28        9:52:17        FlashMagic.exe        IOCTL_SERIAL_PURGE        MosChipSerial1        SUCCESS        Purge: RXCLEAR
29        9:52:17        FlashMagic.exe        IOCTL_SERIAL_PURGE        MosChipSerial1        SUCCESS        Purge: TXCLEAR
30        9:52:17        FlashMagic.exe        IOCTL_SERIAL_SET_TIMEOUTS        MosChipSerial1        SUCCESS        RI:0 RM:0 RC:1000 WM:0 WC:4000
31        9:52:17        FlashMagic.exe        IRP_MJ_WRITE        MosChipSerial1        SUCCESS        Length 1: ? //发送联机同步命令(1:6:2)
32        9:52:17        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: S        //应答联机同步命令字符串Synchronized
33        9:52:17        FlashMagic.exe        IOCTL_SERIAL_SET_TIMEOUTS        MosChipSerial1        SUCCESS        RI:0 RM:0 RC:4000 WM:0 WC:4000
34        9:52:17        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: y
35        9:52:17        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: n
36        9:52:17        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: c
37        9:52:17        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: h
38        9:52:17        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: r
39        9:52:17        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: o
40        9:52:17        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: n
41        9:52:17        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: i
42        9:52:17        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: z
43        9:52:17        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: e
44        9:52:17        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: d
45        9:52:17        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: .
46        9:52:17        FlashMagic.exe        IOCTL_SERIAL_SET_TIMEOUTS        MosChipSerial1        SUCCESS        RI:0 RM:0 RC:50 WM:0 WC:4000
47        9:52:17        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: .
48        9:52:17        FlashMagic.exe        IOCTL_SERIAL_SET_TIMEOUTS        MosChipSerial1        SUCCESS        RI:0 RM:0 RC:4000 WM:0 WC:4000
49        9:52:17        FlashMagic.exe        IRP_MJ_WRITE        MosChipSerial1        SUCCESS        Length 13: Synchronized. //发送波特率只适应字符串
50        9:52:17        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: S        //应答波特率只适应字符串
51        9:52:17        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: y
52        9:52:17        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: n
53        9:52:17        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: c
54        9:52:17        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: h
55        9:52:17        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: r
56        9:52:17        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: o
57        9:52:17        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: n
58        9:52:17        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: i
59        9:52:17        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: z
60        9:52:17        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: e
61        9:52:17        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: d
62        9:52:17        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: .
63        9:52:17        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: O        //波特率自适应成功。比特率以绑定
64        9:52:17        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: K
65        9:52:17        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: .
66        9:52:17        FlashMagic.exe        IOCTL_SERIAL_SET_TIMEOUTS        MosChipSerial1        SUCCESS        RI:0 RM:0 RC:50 WM:0 WC:4000
67        9:52:17        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: .
68        9:52:17        FlashMagic.exe        IOCTL_SERIAL_SET_TIMEOUTS        MosChipSerial1        SUCCESS        RI:0 RM:0 RC:4000 WM:0 WC:4000
69        9:52:17        FlashMagic.exe        IRP_MJ_WRITE        MosChipSerial1        SUCCESS        Length 6: 12000. //发送主频12000KHz(12.000MHz)
70        9:52:17        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 6: 12000. //应答主频12000KHz(12.000MHz)
71        9:52:17        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: O        //成功返回OK
72        9:52:17        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: K
73        9:52:17        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: .
74        9:52:17        FlashMagic.exe        IOCTL_SERIAL_SET_TIMEOUTS        MosChipSerial1        SUCCESS        RI:0 RM:0 RC:50 WM:0 WC:4000
75        9:52:17        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: .
76        9:52:17        FlashMagic.exe        IOCTL_SERIAL_SET_TIMEOUTS        MosChipSerial1        SUCCESS        RI:0 RM:0 RC:4000 WM:0 WC:4000
77        9:52:17        FlashMagic.exe        IRP_MJ_WRITE        MosChipSerial1        SUCCESS        Length 2: J. //发送读器件ID命令
78        9:52:17        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: J //应答读器件ID命令
79        9:52:17        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: .
80        9:52:17        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: 0 //成功返回CMD_SUCCESS
81        9:52:17        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: .
82        9:52:17        FlashMagic.exe        IOCTL_SERIAL_SET_TIMEOUTS        MosChipSerial1        SUCCESS        RI:0 RM:0 RC:50 WM:0 WC:4000
83        9:52:17        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: .
84        9:52:17        FlashMagic.exe        IOCTL_SERIAL_SET_TIMEOUTS        MosChipSerial1        SUCCESS        RI:0 RM:0 RC:4000 WM:0 WC:4000
85        9:52:17        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: 7 //Device ID = 71569451(0x0444102B)LPC1114/301
86        9:52:17        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: 1
87        9:52:17        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: 5
88        9:52:17        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: 6
89        9:52:17        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: 9
90        9:52:17        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: 4
91        9:52:17        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: 5
92        9:52:17        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: 1
93        9:52:17        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: .
94        9:52:17        FlashMagic.exe        IOCTL_SERIAL_SET_TIMEOUTS        MosChipSerial1        SUCCESS        RI:0 RM:0 RC:50 WM:0 WC:4000
95        9:52:17        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: .
96        9:52:17        FlashMagic.exe        IOCTL_SERIAL_SET_TIMEOUTS        MosChipSerial1        SUCCESS        RI:0 RM:0 RC:4000 WM:0 WC:4000
97        9:52:17        FlashMagic.exe        IRP_MJ_WRITE        MosChipSerial1        SUCCESS        Length 2: K.//发送读BootLoad代码版本命令
98        9:52:17        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: K.//应答读BootLoad代码版本命令
99        9:52:17        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: .
100        9:52:17        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: 0 //成功返回CMD_SUCCESS
101        9:52:17        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: .
102        9:52:17        FlashMagic.exe        IOCTL_SERIAL_SET_TIMEOUTS        MosChipSerial1        SUCCESS        RI:0 RM:0 RC:50 WM:0 WC:4000
103        9:52:17        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: .
104        9:52:17        FlashMagic.exe        IOCTL_SERIAL_SET_TIMEOUTS        MosChipSerial1        SUCCESS        RI:0 RM:0 RC:4000 WM:0 WC:4000
105        9:52:17        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: 0 //BootLoad 次版本号0
106        9:52:17        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: .
107        9:52:17        FlashMagic.exe        IOCTL_SERIAL_SET_TIMEOUTS        MosChipSerial1        SUCCESS        RI:0 RM:0 RC:50 WM:0 WC:4000
108        9:52:17        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: .
109        9:52:17        FlashMagic.exe        IOCTL_SERIAL_SET_TIMEOUTS        MosChipSerial1        SUCCESS        RI:0 RM:0 RC:4000 WM:0 WC:4000
110        9:52:17        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: 7 //BootLoad 主版本号7
111        9:52:17        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: .
112        9:52:17        FlashMagic.exe        IOCTL_SERIAL_SET_TIMEOUTS        MosChipSerial1        SUCCESS        RI:0 RM:0 RC:50 WM:0 WC:4000
113        9:52:17        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: .
114        9:52:17        FlashMagic.exe        IOCTL_SERIAL_SET_TIMEOUTS        MosChipSerial1        SUCCESS        RI:0 RM:0 RC:4000 WM:0 WC:4000
115        9:52:17        FlashMagic.exe        IRP_MJ_WRITE        MosChipSerial1        SUCCESS        Length 2: N. //发送读UID命令
116        9:52:17        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: N        //应答读UID命令(UID = 06061826 534E1112 4B6D7B5A F5000005)
117        9:52:17        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: .
118        9:52:17        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: 0 //成功返回CMD_SUCCESS
119        9:52:17        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: .
120        9:52:17        FlashMagic.exe        IOCTL_SERIAL_SET_TIMEOUTS        MosChipSerial1        SUCCESS        RI:0 RM:0 RC:50 WM:0 WC:4000
121        9:52:17        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: .
122        9:52:17        FlashMagic.exe        IOCTL_SERIAL_SET_TIMEOUTS        MosChipSerial1        SUCCESS        RI:0 RM:0 RC:4000 WM:0 WC:4000
123        9:52:17        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: 1 //序列号(1)101062694(0x06061826)
124        9:52:17        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: 0
125        9:52:17        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: 1
126        9:52:17        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: 0
127        9:52:17        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: 6
128        9:52:17        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: 2
129        9:52:17        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: 6
130        9:52:17        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: 9
131        9:52:17        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: 4
132        9:52:17        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: .
133        9:52:17        FlashMagic.exe        IOCTL_SERIAL_SET_TIMEOUTS        MosChipSerial1        SUCCESS        RI:0 RM:0 RC:50 WM:0 WC:4000
134        9:52:17        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: .
135        9:52:17        FlashMagic.exe        IOCTL_SERIAL_SET_TIMEOUTS        MosChipSerial1        SUCCESS        RI:0 RM:0 RC:4000 WM:0 WC:4000
136        9:52:17        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: 1 //序列号(2)1397625106(0x534E1112)
137        9:52:17        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: 3
138        9:52:17        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: 9
139        9:52:17        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: 7
140        9:52:17        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: 6
141        9:52:17        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: 2
142        9:52:17        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: 5
143        9:52:17        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: 1
144        9:52:17        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: 0
145        9:52:17        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: 6
146        9:52:17        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: .
147        9:52:17        FlashMagic.exe        IOCTL_SERIAL_SET_TIMEOUTS        MosChipSerial1        SUCCESS        RI:0 RM:0 RC:50 WM:0 WC:4000
148        9:52:17        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: .
149        9:52:17        FlashMagic.exe        IOCTL_SERIAL_SET_TIMEOUTS        MosChipSerial1        SUCCESS        RI:0 RM:0 RC:4000 WM:0 WC:4000
150        9:52:17        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: 1 //序列号(3)1265466202(0x4B6D7B5A)
151        9:52:17        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: 2
152        9:52:17        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: 6
153        9:52:17        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: 5
154        9:52:17        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: 4
155        9:52:17        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: 6
156        9:52:17        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: 6
157        9:52:17        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: 2
158        9:52:17        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: 0
159        9:52:17        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: 2
160        9:52:17        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: .
161        9:52:17        FlashMagic.exe        IOCTL_SERIAL_SET_TIMEOUTS        MosChipSerial1        SUCCESS        RI:0 RM:0 RC:50 WM:0 WC:4000
162        9:52:17        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: .
163        9:52:17        FlashMagic.exe        IOCTL_SERIAL_SET_TIMEOUTS        MosChipSerial1        SUCCESS        RI:0 RM:0 RC:4000 WM:0 WC:4000
164        9:52:17        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: 4 //序列号(4)4110417925(0xF5000005)
165        9:52:17        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: 1
166        9:52:17        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: 1
167        9:52:17        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: 0
168        9:52:17        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: 4
169        9:52:17        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: 1
170        9:52:17        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: 7
171        9:52:17        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: 9
172        9:52:17        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: 2
173        9:52:17        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: 5
174        9:52:17        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: .
175        9:52:17        FlashMagic.exe        IOCTL_SERIAL_SET_TIMEOUTS        MosChipSerial1        SUCCESS        RI:0 RM:0 RC:50 WM:0 WC:4000
176        9:52:17        FlashMagic.exe        IRP_MJ_READ        MosChipSerial1        SUCCESS        Length 1: .
177        9:52:17        FlashMagic.exe        IOCTL_SERIAL_SET_TIMEOUTS        MosChipSerial1        SUCCESS        RI:0 RM:0 RC:4000 WM:0 WC:4000
178        9:52:17        FlashMagic.exe        IOCTL_SERIAL_SET_DTR        MosChipSerial1        SUCCESS        //RST=0 Cortext-M0复位(信号跳变)
179        9:52:17        FlashMagic.exe        IOCTL_SERIAL_SET_RTS        MosChipSerial1        SUCCESS
180        9:52:17        FlashMagic.exe        IOCTL_SERIAL_SET_RTS        MosChipSerial1        SUCCESS
181        9:52:17        FlashMagic.exe        IOCTL_SERIAL_SET_DTR        MosChipSerial1        SUCCESS
182        9:52:17        FlashMagic.exe        IOCTL_SERIAL_CLR_RTS        MosChipSerial1        SUCCESS        //ISP=1 Cortext-M0运行状态(信号跳变)
183        9:52:17        FlashMagic.exe        IOCTL_SERIAL_SET_DTR        MosChipSerial1        SUCCESS
184        9:52:17        FlashMagic.exe        IOCTL_SERIAL_CLR_DTR        MosChipSerial1        SUCCESS        //RST=1 Cortext-M0工作(信号跳变)
185        9:52:17        FlashMagic.exe        IOCTL_SERIAL_CLR_RTS        MosChipSerial1        SUCCESS
186        9:52:18        FlashMagic.exe        IRP_MJ_CLEANUP        MosChipSerial1        SUCCESS
187        9:52:18        FlashMagic.exe        IRP_MJ_CLOSE        MosChipSerial1        SUCCESS //关闭串口
mcu123AD 发表于 2010-7-27 23:22 | 显示全部楼层
uid太长了。
lpcfans 发表于 2010-7-28 08:31 | 显示全部楼层
不错。有时间也弄弄。
 楼主| hotpower 发表于 2010-7-29 01:26 | 显示全部楼层
晕,长了才叫唯一码,难道要8位短的唯一码???
xuyiyi 发表于 2010-7-29 11:36 | 显示全部楼层
HOT大叔的贴子都是好贴!
都得顶!
icecut 发表于 2010-7-29 16:37 | 显示全部楼层
恩.很学术
 楼主| hotpower 发表于 2010-7-31 00:46 | 显示全部楼层
本例俺展示了如何拦截和分析串口数据,同时告诫通讯协议不加密是多么危险
testcode 发表于 2010-7-31 00:52 | 显示全部楼层
学习~~~
 楼主| hotpower 发表于 2010-7-31 10:02 | 显示全部楼层
把此搞清楚了,才能谈运程控制~~~
McuPlayer 发表于 2010-8-4 00:06 | 显示全部楼层
串口的IOCTL都是标准的,连注释都可以省略了,欧耶
Simon21ic 发表于 2010-8-13 19:53 | 显示全部楼层
协议不是公开的?
为什么要OOXX?
xixihaha0 发表于 2010-8-13 20:03 | 显示全部楼层
不加密太危险了,:L
ouxueguo 发表于 2010-11-10 10:57 | 显示全部楼层
逆向学习是不是指先从底层学习(一般学习都是来个上层应用例子)
 楼主| hotpower 发表于 2011-1-25 16:07 | 显示全部楼层
顶,准备开战
bairan168 发表于 2011-1-25 19:21 | 显示全部楼层
占位有点晚了,那也占位。
bairan168 发表于 2011-1-25 19:22 | 显示全部楼层
占位有点晚了,那也占位。
 楼主| hotpower 发表于 2011-1-26 07:11 | 显示全部楼层
本例主要友情提示任何串行及无线通讯,明文数据流是非常危险的作为,不加密或加密强度不够都是为**者提供嫁衣。
