[AVR单片机]
请教 HOT 大叔的 头文件
1109|2
itelectron|  楼主 | 2010-8-10 20:45 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
typedef struct {
  unsigned BIT00: 1;
  unsigned BIT01: 1;
  unsigned BIT02: 1;
  unsigned BIT03: 1;
  unsigned BIT04: 1;
  unsigned BIT05: 1;
  unsigned BIT06: 1;
  unsigned BIT07: 1;
  unsigned BIT08: 1;
  unsigned BIT09: 1;
  unsigned BIT10: 1;
  unsigned BIT11: 1;
  unsigned BIT12: 1;
  unsigned BIT13: 1;
  unsigned BIT14: 1;
  unsigned BIT15: 1;
  unsigned BIT16: 1;
  unsigned BIT17: 1;
  unsigned BIT18: 1;
  unsigned BIT19: 1;
  unsigned BIT20: 1;
  unsigned BIT21: 1;
  unsigned BIT22: 1;
  unsigned BIT23: 1;
}xdata MCUBIT24;//定义一个只能按24位域寻址的新变量类型
KEIL  报错 语法 错误  BIT10  以下 错误
itelectron|  楼主 | 2010-8-10 20:46 | 只看该作者
XX.H(451): error C141: syntax error near '0x0400'
hotpower| | 2010-8-11 00:39 | 只看该作者
typedef struct {
  unsigned BIT00: 1;
  unsigned BIT01: 1;
}MCUBIT24;//定义一个只能按24位域寻址的新变量类型
改成这样试试
可能有些编译器值支持8*N位的位域。
个人签名:MARK: zhi kan ji shu
274
